    • Avnet Boards Community
Blog Design for a Cause - Smart Voice Synthesizer, Visualizer- Demo
  • Author Author: prashanth.nagendrappa
  • Date Created: 14 Sep 2018 7:41 PM Date Created
  • Views 1335 views
  • Comments 5 comments
  • this week on element14
  • design for a cause - design challenge
  • design for a cause design challenge
14 Sep 2018
#Blog10_A
Hello Everyone!
It's great to be chosen for the Design for a Cause' Design Challenge, I am thankful to #Element14 Community, #Arduino, and the sponsors.
Here is the Final Project demo!
I am very much thank full to prasannag1993 (Prasanna Kumar)vinyasa.mv , genebren Gene Breniman Sir, gkbhat95 ,  dixonselvan and all my friends for their encouragement and support.
The Code :
// Headers for Audio Circuit
#include <SD.h>
#include <SPI.h>
#include <AudioZero.h>
// Headers for Display
#include <Wire.h>
#include <ACROBOTIC_SSD1306.h>
// Defining the Sentence to be told
String T3 ="Can you Switch on the fan";
String T4 ="Its Difficult but possible";
String T5=" Hi I am prashanth Kumar g n, the participant for the ELEMENT14 design contest ";
String T6 ="Its Boring Lets play some games";
String T7 ="I want some food";
String T8 ="Shall we have dinner";
String T9 ="I want to go to rest room";
String T10 ="All the best";
String T11 ="Yes I won the Game";
String T12 ="Lets Be Friends";
String T13 ="If you sweat more in Peace, You bleed less in war";
String T14 ="Work hard in Silence, Let your success makes noice";
int a,b,c,d,e;
int d1 = 1000;
int d2 = 4000;
int d3 = 4000;
void setup() {
  // initialize serial communication at 9600 bits per second:
  Serial.begin(9600);
  if (!SD.begin(4)) {
    Serial.println(" failed!");
    while(true);
  Serial.println(" done.");
  // 44100kHz stereo => 88200 sample rate
  AudioZero.begin(32000);
  Wire.begin();
  oled.init();
  oled.clearDisplay();
// the loop routine runs over and over again forever:
void loop() {
 //read the Data from flex sensors
  int s0 = analogRead(A1);
  int s1 = analogRead(A2);
  int s2 = analogRead(A3);
  int s3 = analogRead(A4);
  int s4 = analogRead(A2);
 // print out the value you read:
//  Serial.print(" s0: ");
//  Serial.print(s0);
//  Serial.print(", s1: ");
//  Serial.print(s1);
//  Serial.print(", s2: ");
//  Serial.print(s2);
//  Serial.print(", s3: ");
//  Serial.print(s3);
//  Serial.print(", s4: ");
//  Serial.println(s4);
// Digitalising the Bend values
// Getting a
  {if(s0<=530)
    a=1;
   Serial.print(" *a:   ");
  Serial.print(a);
  else
    a=0;
  Serial.print(a);
// Getting b
   if(s1<=512)
    b=1;
   Serial.print(" *b:   ");
  Serial.print(b);
  else
    b=0;
  Serial.print(b);
// Getting c
   if(s2<=481)
    c=1;
   Serial.print("  *c:    ");
  Serial.print(c);
  else
    c=0;
  Serial.print(c);
// Getting d
  if(s3<=484)
    d=1;
   Serial.print(" *d:   ");
  Serial.print(d);
  else
    d=0;
  Serial.print(d);
// Getting e
  if(s4<=440)
    e=1;
   Serial.print(" *e:   ");
    Serial.println(e);
  else
    e=0;
  Serial.println(e);
  delay(d1);
//Sending Text on Appropriate hand sign
int z =(a*16)+(b*8)+(c*4)+(d*2)+(e*1);
Serial.println(z);
switch (z) {
    case 4:
     Serial.println(T3);
     test_t3();
      delay(d2); z=0; delay(d3);
      break;
    case 2:
     Serial.println(T4);
         test_t4();
      break;
    case 1:
      Serial.println(T5);
          test_t5();
      break;
  case 24:
      Serial.println(T6);
          test_t6();
      break;
    case 20:
      Serial.println(T7);
          test_t7();
      break;
    case 18:
     Serial.println(T8);
         test_t8();
      break;
    case 17:
     Serial.println(T9);
         test_t9();
      break;
    case 28:
      Serial.println(T10);
          test_t10();
      break;
    case 30:
      Serial.println(T11);
          test_t11();
      break;
    case 6:
      Serial.println(T12);
          test_t12();
      break;
    case 7:
      Serial.println(T13);
          test_t13();
      break;
    case 15:
      Serial.println(T14);
          test_t14();
      break;
      default:
      Serial.println("******");
      break;
  delay(1200);        // delay in between reads for stability
void test_t3()
//Display Text
  oled.setTextXY(0,0);
  oled.putString(T3);
//Play correspodning voice
  File myFile2 = SD.open("test3.wav");
  if (!myFile2) {
    while (true);
  AudioZero.play(myFile2);
void test_t4()
//Display Text
  oled.putString(T4);
  File myFile2 = SD.open("test4.wav");
  if (!myFile2) {
    while (true);
void test_t5()
//Display Text
  oled.putString(T5);
  File myFile2 = SD.open("test5.wav");
  if (!myFile2) {
    while (true);
void test_t6()
//Display Text
  oled.putString(T6);
  File myFile2 = SD.open("test6.wav");
  if (!myFile2) {
    while (true);
void test_t7()
//Display Text
  oled.putString(T7);
  File myFile2 = SD.open("test7.wav");
  if (!myFile2) {
    while (true);
void test_t8()
//Display Text
  oled.putString(T8);
  File myFile2 = SD.open("test8.wav");
  if (!myFile2) {
    while (true);
void test_t9()
//Display Text
  oled.putString(T9);
  File myFile2 = SD.open("test9.wav");
  if (!myFile2) {
    while (true);
void test_t10()
//Display Text
  oled.putString(T10);
  File myFile2 = SD.open("test10.wav");
  if (!myFile2) {
    while (true);
void test_t11()
//Display Text
  oled.putString(T11);
  File myFile2 = SD.open("test11.wav");
  if (!myFile2) {
    while (true);
void test_t12()
//Display Text
  oled.putString(T12);
  File myFile2 = SD.open("test12.wav");
  if (!myFile2) {
    while (true);
void test_t13()
//Display Text
  oled.putString(T13);
  File myFile2 = SD.open("test13.wav");
  if (!myFile2) {
    while (true);
void test_t14()
//Display Text
  File myFile2 = SD.open("test14.wav");
  if (!myFile2) {
    while (true);
Thanks for the opportunity.
  • krishnal
    krishnal over 6 years ago +2
    Nice demo Good idea smart voice synthesizer visualizer Prashanth Kumar G N
  • pranjalranjan299
    pranjalranjan299 over 6 years ago +1
    Great demo Prashanth Kumar G N ! Your blog on AudioZero helped me as well
  • swapnil2512
    swapnil2512 over 5 years ago
    HELLO SIR,COULD YOU HELP ME WITH THIS PROJECT THAT YOU HAVE DEMONSTRATED , COULD YOU PROVIDE EFFECTIVE PROCEDURE TO PHYSICALLY INPLEMENT THE PROJECT ON MY OWN. AND COULD YOU PROVIDE ME WITH YOUR EMIAL ID .. prashanth.nagendrappa
  • swapnil2512
