      • Japan
      • Vietnam
Blog 1958 Turntable from the Black Forest - Bonus 1a: Remote Light Organ with WiFI pt. 1
  • Date Created: 13 Jun 2015 8:02 AM Date Created
  • Views 1689 views
  • Comments 8 comments
  • wifi
  • mqtt
  • yun
  • iot
13 Jun 2015
This is my first installment in the BONUS series where I'm tapping into the turntable's audio spectrum data that I'm publishing on the internet.
My first bonus design is a remote light organ. I'm building it with an Arduino Yún, the Infineon RGB Led Shield and a bunch of LEDs.
Part 1 is my log on the build, and trying out if the Arduino-to-Infineon-toLEDs works.
Re-use and Re-purpose
I have kind of a head start here. For a previous element14 event, I have been using the RGB shield before.
That enabled me to just pull up the sketch that I used back then.
(I'll be able to do the same when building an MQTT listener on the Yun - been there done that.)
It's been a day of old school electronics. I pulled out the trusty soldering iron from my school days and did some trough-hole work.
The remote organ will fit in a little shoe box, so I cut out a plate of carton to mount everything on.
I've connected the things up and tidied the layout a bit.
Sketch loaded - and it works. At the moment it's animating each of the 3 rows in 4 intensities.
That 'll change in part 2, where I'll tap into the MQTT data and turn this into a light organ.
    Jan Cumps over 10 years ago +1
    Strange, I can add video to the comment, but not to the blog post www.youtube.com/watch
  • fvan
    fvan over 10 years ago +1
    Stretch goals, nice
    DAB over 10 years ago +1
    Good build. DAB
    Workshopshed over 10 years ago
    How does it work with iot.eclipse.org, do they have a service you subscribe to? How does it distinguish your messages from other peoples?
    Jan Cumps over 10 years ago in reply to Workshopshed
    It's standard MQTT. Their server is free to use for development/proto activities.Check conditions here: iot.eclipse.org — Getting Started.
    I distinguish based on topic and sender. Security is possible, but I hope that someone else finds that out for me image
