    • Avnet Boards Community
Blog [CaTS] ForgetMeNot - 3D Printing: Food dispenser prototype
  • Author Author: fvan
  • Date Created: 17 Aug 2014 8:18 AM Date Created
  • Views 2436 views
  • Comments 19 comments
  • forget_me_not
  • design_challenge
  • openhab
  • tektronix
  • iot_pet_care
  • eclipse
  • internet_of_things
  • enocean
  • cats
  • raspberrypi
  • smarthome
  • challenge
  • iot
  • enocean_pi
fvan
fvan
17 Aug 2014
Previous posts for this project:
  • [CaTS] ForgetMeNot - Index
  • [CaTS] ForgetMeNot - Week 0: Project Description
  • [CaTS] ForgetMeNot - Week 1: EnOceanPi and Sensors
  • [CaTS] ForgetMeNot - Week 2: Elro CoCo and Pi Cam with OpenHAB
  • [CaTS] ForgetMeNot - Week 3: Data persistence and charts with OpenHAB
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean sensor bracket
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean rocker switch and magnet holder
  • Introduction
  • Valve
  • Assembly
  • Test
  • Improvements
Next to the persistence in OpenHAB, I've also been working on a first prototype for the food dispenser this week.
I created a valve in a piece of PVC pipe and controlled it with a servo motor. After initial testing, I made some additional improvements.
Here we go.
Valve
The first step was to create a valve which would fit inside the PVC pipe. My trusty 3D printer came in handy as usual.
I cleaned the print and glued a piece of one of the servo arms which I had cut to only leave the center part.
If this approach works out, I'll print that little bit as part of the valve.
Assembly
After drilling some holes in the PVC pipe, I was able to fit the valve and attach it to the servo.
I attached the servo temporarily (with some electrical tape) for this demo. Again, if everything works out, I'll print a bracket to better attach it.
Test
Using some simple Arduino code, I made the dispenser open and close every second.
Later on, the dispenser will only open based on a trigger coming from OpenHAB.
#include <Servo.h>
Servo myservo;
int pos = 132;
void setup() {
  myservo.attach(9);
void loop() {
  myservo.write(132);
  delay (1000);
  myservo.write(42);
  delay (1000);
The code being executed:
Finally, I loaded the dispenser with peanuts (because cat food would not be a tasty reward should this test be successful) to test if it would actually dispense anything.
Prototype #1 seems to be working! I'll have to perform some long duration tests to confirm this is a viable solution, but first ... I'll have some peanuts.
Any tips regarding alternatives are obviously welcome, as this was the first idea that came to mind.
Improvements
Because the first test was successful, I continued with the two improvements mentioned above:
  • hold servo with proper bracket instead of tape
  • incorporate servo arm into valve piece
These are the models I came up with:
Unfortunately, the servo holder print failed around the end, due to the print coming loose from the heated bed.
I cleaned up the print to try it anyway, as it could at least validate the idea works ... and it does.
I'll be attempting this print again later on, as the idea behind it seems to work.
That's enough 3D printing for today, see you next time!
  • ntewinkel
    ntewinkel over 9 years ago +3
    This is brilliant, Frederick!! (sorry I'm a little (very) late to the party) I've been thinking and wondering how to best do this but never built anything yet because I was probably overthinking it - I…
  • gadget.iom
    gadget.iom over 9 years ago in reply to ntewinkel +2
    Cats are awesome! Their whole purpose in life is to enslave their owners.
    mcb1 over 9 years ago in reply to fvan +2
    I liked this simple method of dispensing by m.ratcliffe http://www.element14.com/community/docs/DOC-76810#comment-63104 While the intention was for much smaller food, the mechanism has the abilty to be…
  • ntewinkel
    I've been thinking and wondering how to best do this but never built anything yet because I was probably overthinking it - I thought I had to build something like a gumball dispenser with a big rotary plate. Your method looks much more build-able!
    Have you found it to be reliable? Do kibbles ever get stuck in the valve to give the servo a bad time?
    I'll definitely have to try this. I don't have a 3D printer, but I'm sure I can find something to make the flappy part.
    ps, the reason for wanting to do this is because Charlie Kat has a habit of eating his food too fast and then barfing it up. Not cool, Charlie Kat! So our mission has been to slow him down - we got a "difficult dish" that makes him work for his food, but it seems like he's mastered that to the point where he can suck his food down too fast too. So right now I have to dispense a little bit at a time throughout the day. They're spoiled!
    Cheers,
    -Nico
  • fvan
    fvan over 9 years ago in reply to ntewinkel
    Hi Nico,
    even though this appeared to work at first, in the end food sometimes got stuck and wouldn't drop. I figured out a second version (without 3D printing) that got the job done and worked every time.
    You can find it here: http://www.element14.com/community/community/design-challenges/forget-me-not/blog/2014/10/20/cats-forgetmenot--final#jiv…
    While the intention was for much smaller food, the mechanism has the abilty to be scaled up ... especially with 3D printing.
    Using the auger style approach certainly solves the jamming issue.
  • m.ratcliffe
    m.ratcliffe over 9 years ago in reply to mcb1
    The designs for a 3d printed model will be up soon.
    The feeder in this blog also looks like it has some potential.
  • ntewinkel
    ntewinkel over 9 years ago in reply to m.ratcliffe
    That auger design looks pretty nifty, Michael. And with a sharp enough drill bit it'll just slice through any kibble that threatens to get stuck image
    Do you find you need the "inspection" part of the Tee? I was wondering what that was for.
  • m.ratcliffe
    m.ratcliffe over 9 years ago in reply to ntewinkel
    I use the inspection tee because it has a flat base [Resists rotation when its clearing a blocked pellet], I have never had to open the tee, but it is nice to know it is there if the need ever arises. The one in this blog looks like it could work well too with a few small updates to the "paddle".
    The first model of the 3d printed version was printed today and the designs/file will be up after some real world testing.
  • ntewinkel
    ntewinkel over 9 years ago in reply to fvan
    I finally built my own kitty treat dispenser, thanks to your advice and design!
    I bought a knock-off Meccano type set for $3 at the dollar store and used pieces from that for the valve mechanism image
    For the photo, the whole thing is temporarily being held up by my "helping hands" (for soldering).
    I'll post more details on my blog next...
    ps, I couldn't find a big enough auger bit to build Michael's design... that's still on the list.
    edit: More details, and video, in my post: Cat Treat Dispenser
    Thanks,
    -Nico
  • ntewinkel
    Thanks,
    -Nico
