    • Avnet Boards Community
Blog [CaTS] ForgetMeNot - 3D Printing: Food dispenser prototype
  • Author Author: fvan
  • Date Created: 17 Aug 2014 8:18 AM Date Created
  • Views 2455 views
  • Comments 19 comments
  • forget_me_not
  • design_challenge
  • openhab
  • tektronix
  • iot_pet_care
  • eclipse
  • internet_of_things
  • enocean
  • cats
  • raspberrypi
  • smarthome
  • challenge
  • iot
  • enocean_pi
fvan
fvan
17 Aug 2014
Previous posts for this project:
  • [CaTS] ForgetMeNot - Index
  • [CaTS] ForgetMeNot - Week 0: Project Description
  • [CaTS] ForgetMeNot - Week 1: EnOceanPi and Sensors
  • [CaTS] ForgetMeNot - Week 2: Elro CoCo and Pi Cam with OpenHAB
  • [CaTS] ForgetMeNot - Week 3: Data persistence and charts with OpenHAB
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean sensor bracket
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean rocker switch and magnet holder
  • Introduction
  • Valve
  • Assembly
  • Test
  • Improvements
Next to the persistence in OpenHAB, I've also been working on a first prototype for the food dispenser this week.
I created a valve in a piece of PVC pipe and controlled it with a servo motor. After initial testing, I made some additional improvements.
Here we go.
Valve
The first step was to create a valve which would fit inside the PVC pipe. My trusty 3D printer came in handy as usual.
I cleaned the print and glued a piece of one of the servo arms which I had cut to only leave the center part.
If this approach works out, I'll print that little bit as part of the valve.
Assembly
After drilling some holes in the PVC pipe, I was able to fit the valve and attach it to the servo.
I attached the servo temporarily (with some electrical tape) for this demo. Again, if everything works out, I'll print a bracket to better attach it.
Test
Using some simple Arduino code, I made the dispenser open and close every second.
Later on, the dispenser will only open based on a trigger coming from OpenHAB.
#include <Servo.h>
Servo myservo;
int pos = 132;
void setup() {
  myservo.attach(9);
void loop() {
  myservo.write(132);
  delay (1000);
  myservo.write(42);
  delay (1000);
The code being executed:
Finally, I loaded the dispenser with peanuts (because cat food would not be a tasty reward should this test be successful) to test if it would actually dispense anything.
Prototype #1 seems to be working! I'll have to perform some long duration tests to confirm this is a viable solution, but first ... I'll have some peanuts.
Any tips regarding alternatives are obviously welcome, as this was the first idea that came to mind.
Improvements
Because the first test was successful, I continued with the two improvements mentioned above:
  • hold servo with proper bracket instead of tape
  • incorporate servo arm into valve piece
These are the models I came up with:
Unfortunately, the servo holder print failed around the end, due to the print coming loose from the heated bed.
I cleaned up the print to try it anyway, as it could at least validate the idea works ... and it does.
I'll be attempting this print again later on, as the idea behind it seems to work.
That's enough 3D printing for today, see you next time!
  • ntewinkel
    ntewinkel over 9 years ago +3
    This is brilliant, Frederick!! (sorry I'm a little (very) late to the party) I've been thinking and wondering how to best do this but never built anything yet because I was probably overthinking it - I…
  • gadget.iom
    gadget.iom over 9 years ago in reply to ntewinkel +2
    Cats are awesome! Their whole purpose in life is to enslave their owners.
    mcb1 over 9 years ago in reply to fvan +2
    I liked this simple method of dispensing by m.ratcliffe http://www.element14.com/community/docs/DOC-76810#comment-63104 While the intention was for much smaller food, the mechanism has the abilty to be…
    mcb1 over 10 years ago
    Nice job.
    I'm guessing the angled Tee is so you can mount it.
  • fvan
    fvan over 10 years ago in reply to mcb1
    The angled Tee was mainly for testing purposes to avoid having to buy a full length piece of pipe and have some visibility while testing.
    I will probably stick with it as some kind of inspection point that could be closed with a removable cap of some sort.
    Frederick
  • m.ratcliffe
    m.ratcliffe over 9 years ago in reply to fvan
    The tee could be the reason you are getting relatively little jamming, I tried a similar feeder with a straight pipe and it jammed a lot. The tee might be reducing the pressure of the food on the return stroke.
    Good Project!
  • m.ratcliffe
    Good Project!
