    • Avnet Boards Community
In the Air Design Challenge
  • In the Air Design Challenge
Forum Subscription to AirVantage MQTT topic
  • Replies 20 replies
  • Answers 2 answers
  • Subscribers 5 subscribers
  • Views 2812 views
  • airvantage
  • in_the_air
tomaja
tomaja over 10 years ago
Hello people!
I'm having difficulties with MQTT.
Did anyone manage to "subscribe" to AirVantage MQTT server?
I never used a MQTT so I'm getting some difficulties when I try to get notifications when new data is published to AirVantage. Maybe I'm missing the point here? Should I get the updated values if I subscribe to some topic?
I call subscribe with MQTTLens or Paho test client but nothing happens after I publish new data (subscription to <SERIAL>/tasks/json appears to be successful). And I'm sure data is being published because I can see new values on Monitor -> Systems page in AirVantage control panel.
Hope someone can help.
Dragan
    Former Member over 10 years ago in reply to tomaja +1 suggested
    No, the REST API to access AirVantage is decoupled from the device protocols: you can send data to the Cloud with MQTT or REST, to access the data you must use REST.
  • tomaja
    0 tomaja over 10 years ago in reply to Former Member
    I want to have a single client that's performing the sensor data publishing (BeagleBone Black) and multiple monitoring clients (desktop and mobile applications) that should receive and present these new values.
  • tomaja
    Did you edit this message? I read it on my phone and I was under impression that it said that I should also subscribe to <SERIAL>/messages/json (not tasks/json)
    But, I did try <SERIAL>/tasks/json multiple times and never received a message...
    Dragan
    0 Former Member over 10 years ago in reply to tomaja
    To retrieve the data you sent to AirVantage, your application shall use the AirVantage REST APIs.
    A tutorial is available here: https://doc.airvantage.net/display/USERGUIDE/Use+AirVantage+API
    Example: to list historical values you sent to the system: GET https://na.airvantage.net/api/v1/systems/data/raw?targetIds={system_uid}&dataIds=machine.temperature, machine.humidity&access_token={token}
    Yes, to receive a command or setting update from AirVantage the topic is tasks/json
  • tomaja
    Oh.. I understood that I shouldn't use REST API.
    Luckily, REST API is well documented - should be easy to use image
    Thanks!
    This saves me a lot of time I would spend on trying to do impossible with MQTT.
    Do I need to make another Application with Communication Type set to REST and linked to the same System (for REST API to work)?
    Thanks again, Didier!
    Dragan
  • tomaja
    OK, it's all clear now.
    Thanks a lot for your valuable help!
    Dragan
    you're welcome! have fun !
  • tomaja
    Just an additional remark.
    SYSTEM_UID field seen in the REST API calls is the UID field that can be found on the system details page (Inventory -> Systems + Click the system name, not the serial).
    Dragan
    Yes, exactly
