Table of Contents
- Project Introduction
- Getting Started
- Communication Between Two MKR WAN 1300
- LoRaWAN System Range Testing
- Assembling and Adding LCD Display to the Transmitter
- Assembling and Adding LCD Display to the Receiver
- LoRaWAN´s Field Test with a DS18B20 Sensor
- Adding Multiple Sensors: DS18B20, DHT22 and MQ-135
- Modifying Receiver Code for Multiple Sensors
- LoRaWAN´s Field Test with Multiple Sensors
- Connecting LoRaWAN to an IoT Provider through the Arduino NANO 33 IoT
- LoRaWAN and IoT Connection with a DS18B20 Sensor
- Testing LoRaWAN and IoT Connection with a DS18B20 Sensor
- LoRaWAN and IoT Connection with Multiple Sensors
- Testing LoRaWAN and IoT Connection with Multiple Sensors
- Project Report Updated
Assembling the transmitter
In the figure below I show the lid of the box to make the marks for the drill holes.
Now below we see how this piece was after drilling.
Once the holes are large enough, then it's time to attach the connectors.
In the figure below I show you the pieces that I print on the 3D printer. These pieces are used to fix the Arduino MKR WAN 1300 board and the LCD display.
In the image below you can see how to assemble the 16x2 LCD display that comes in the gift kit.
Then we fix the Arduino MKR WAN 1300 board, the 16x2 LCD display, the DS18B20 sensor and the antenna.
The transmitter would look like the figure below.
As a power supply I used a generic 5V Portable Charger Power Bank 16800 mAh. In addition to providing more accurate voltages, this device gave me better results since it has a power button, a voltage regulator and detects when a device is connected or not.
I also recommend using a heavy-duty USB to make a good connection
Schematic diagram
After adding the 16x2 display, the wiring diagram of the receiver is as shown below.
Code
All the information needed to install the library you can get in this link: Grove-LCD RGB Backlight Library from Github
After making these changes, the transmitter code is shown below:
LoRaSender_v2.ino
// AUTHOR: GUILLERMO PEREZ GUILLEN #include <SPI.h> #include <LoRa.h> #include <OneWire.h> // DS1B20-> #include <DallasTemperature.h> #include <Wire.h> // LCD-> #include "rgb_lcd.h" rgb_lcd lcd; const int colorR = 173; const int colorG = 255; const int colorB = 47; // Data wire is plugged into port 2 on the Arduino #define ONE_WIRE_BUS 2 // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) OneWire oneWire(ONE_WIRE_BUS); // Pass our oneWire reference to Dallas Temperature. DallasTemperature sensors(&oneWire); int counter = 0; void setup() { // set up the LCD's number of columns and rows: lcd.begin(16, 2); lcd.setRGB(colorR, colorG, colorB); // Print a message to the LCD. lcd.print("ECOLOGY!"); lcd.setCursor(0, 1); // LCD lcd.print("LoRa Sender"); if (!LoRa.begin(915E6)) { lcd.setCursor(0, 1); // LCD lcd.print("Starting LoRa failed!"); while (1); } sensors.begin(); } void loop() { sensors.requestTemperatures(); //The command to read the temperature is sent int temp= sensors.getTempCByIndex(0); //The temperature is obtained in ยบC lcd.clear(); lcd.setCursor(0, 0); // LCD lcd.print("Packet:"); lcd.setCursor(8, 0); // LCD lcd.print(counter); lcd.setCursor(0, 1); // LCD lcd.print("Temp:"); lcd.setCursor(8, 1); // LCD lcd.print(temp); // send packet LoRa.beginPacket(); LoRa.print(temp); LoRa.endPacket(); counter++; delay(4000); }
Download section:
- You can get the code from this post below:
assembling_and_adding_lcd_display_to_the_transmitter.zip
- Below I attach the STL files used in this post:
