Experimenting with Polymer Capacitors
  • Experimenting with Polymer Capacitors
Blog Switched-Capacitor used in a Filter
  • Author Author: barsznica
  • Date Created: 16 Apr 2019 12:55 PM Date Created
  • Views 1469 views
  • experimenting with polymer capacitors
barsznica
barsznica
16 Apr 2019
Hi all,
My name is Pete and I have been a maker for many years. Well, I have been a "Breaker" for much longer!
I though I could turn my passion into a job, so I completed a Degree in Electrical and Electronic Engineering.
My experiment is to investigate Polymer Capacitors used in switched capacitor active filters.
The experiment will investigate the accuracy of a switched-capacitor filter over different temperatures and how the frequency response changes with switching frequency.
It would be interesting to see how the switched-capacitor filter circuit accuracy compares to a traditional RC (resistor-capacitor) filter with temperature variation.
  • barsznica
    barsznica over 7 years ago in reply to dougw +1
    Yes, I guess I overlooked that they are polarised! The input signal would be relatively simple to bias, but the feedback cap is more difficult. I could use a non-polarised cap for the feedback, but the…
    dougw over 7 years ago in reply to barsznica
    I think I've seen polarized caps used in back-to-back pairs where the junction is pulled to a rail that is never exceeded by the signal using a megaohm resistor. It might be interesting to find out if it works.
  • barsznica
    I could use a non-polarised cap for the feedback, but the temperature coefficient of both caps should match, so they track.
    Maybe I should change my experiment to measure the the effectiveness of ripple reduction on the output of a switching regulator, and compare the polymer with traditional caps?
    I could plot the ripple comparisons over temperature and current.
    When using polarized caps in a switched capacitor filter, do you need to somehow bias the caps so they never see reverse polarity?
