      • Japan
      • Vietnam
Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog The Picorder. A Star Trek style Tricorder.  Day 11
  • Author Author: saturnv
  • Date Created: 4 May 2015 3:37 AM Date Created
  • Views 579 views
  • Comments 5 comments
  • star_trek
  • raspberry_pi
  • handheld_sensor
  • sci_fi_your_pi
  • tricorder
saturnv
saturnv
4 May 2015
{gallery} My Gallery Title
PCD8544: Front of PCD8544 LCD Display. Back of Nokia 5110 LCD Display
Nokia 5110/3110: Front of LCD Display
Speaker Assembly: Component removal
Stereo Speakers: With amplifier
R2D2: Helper, Butler, and confidante'image
It has been busy this week, although the blog has taken some time to put together. I've been gathering a few more supplies necessary for the construction of the container for the "Picorder". While that is in progress, I've set in motion some basic tests of the device. I've been working on the display functions mainly at the moment. I've attached some more photos and video of some of their results. If you'll notice the display pin outs are very different so determining the correct pin out to program the Pi correctly was 'interesting'. In the meantime, I've been disassembling some more devices for parts. The speaker assembly had a damaged plug so I decided to use it's components for the Picorder. The original Tricorder has sound features so I intend to have it here also. In my last blog I stated I would be doing some sketches for the housing unit, however, I have a couple selections en route that I found online so I may not need to completely construct the case. I'm tracking the code I'm using to so it'll be published at a later date in its entirety along with a completed parts list. Enjoy the image gallery and video! image
  • Former Member
    Former Member over 10 years ago +1
    Here's a link to the video: http://www.element14.com/community/videos/16164/l/the-picorder-nokia-5110-display-test
  • element14Dave
    element14Dave over 10 years ago in reply to saturnv +1
    If you want the video in the blog you'll need to "edit" blog "insert video" and select the uploaded video under the "from your videos" tab. Let me know if you have any questions.
  • saturnv
    saturnv over 10 years ago
    Well  I don't understand what happened to the video. It says its published, however I cannot view it for some reason.
  • saturnv
  • element14Dave
  • saturnv
    saturnv over 10 years ago in reply to element14Dave
    Thanks Dave. I did ll that but maybe something else had happened with my PC. Says it's 'embedded' in my post for Day 11 but all I had found was my gallery photos. The link lucie shows here works. Thanks both.
