    Members
    • Avnet Boards Community
    • Choose Another Store
Sustain The World - Design Challenge
  • Sustain The World - Design Challenge
Documents Sustain the World Design Challenge
  • Author Author: e14phil
  • Date Created: 21 Apr 2020 12:48 PM Date Created
  • Last Updated Last Updated: 13 Aug 2020 4:39 PM
  • Views 4425 views
  • Likes 20 likes
  • Comments 84 comments
Sustain The World Design Challenge
About this Challenge | Dates | The Judges | The Kit | The Prizes | Technical Resources | Example Application | Terms & Conditions | The Challengers
Join Us in Sustaining the World with Infineon
Ready? Then Apply Here
The Challenge
The element14 Community is pleased to introduce the Sustain the World Design Challenge with Infineon.
Infineon is challenging the element14 community to design the most creative solution utilizing the XMC4700 Relax Lite Kit, the Platform2GO XMC4200 MCU, the TL94112 Motor Controller, the DPS368 Pressure sensor, the TLV493D A1B6 MS2GO Magnetic Sensor, and a Profet+2 12 Smart Switch Shield, all from Infineon.
Infineon wants the element14 community to design solutions to make your life easier, safer, and greener. You can use the sensors provided on the board, or add your own sensors and actuators to be controlled by the Arduino Compatibility and Arduino Cloud.
Challengers are invited to use this kit to Sustain the World.
If applicants are successful, they can take advantage of the XMC4700 Relax Lite Kit, the Arduino Compatible XMC4200 MCU, 3D Motion, Pressure Sensor Motor control, and Smart Switch Challenge kit.
20 successful applicants will receive the Challenge Kit free of charge to build and blog their project with. For the chance to win one of the prizes below, you must blog your build process and the final outcome of your Challenge Kit Projects within the Sustain The World Challenge space.
What Can I Build?
You can build anything you want, as long as it uses the XMC4700 Relax Lite Kit and at least two other of the Infineon peripherals included in the kit.
Example applications could include:
  • Micro Plastics Monitoring Buoy
  • Remote fleet of ships which monitor pollution levels
  • Roadside Littering Monitor
  • Distributed CO2 Monitoring station
  • Self-compacting Trash Cans
  • Recycling Composition Tester
  • Sea Level and Levy Monitor
  • Automatic Tree Planter
  • Trash Collection Bot
The Kit Buy Kit*Buy Kit*The Specs
MCU
KIT_XMC47_RELAX_LITE_V1
Buy NowBuy Now
  • XMC4700-F144 Microcontroller based on ARMRegistered CortexRegistered-M4 @ 144MHz, 2MB Flash and 352KB RAM
  • On-Board Debugger
  • Power over USB
  • ESD and reverse current protection
  • 2 x user button and 2 x user LED
  • Arduino hardware compatible 3.3V pinout
Platform2GO XMC4200
Buy NowBuy Now
  • Arm Cortex M4
  • 256 kB Flash Memory
  • 2x Shield2Go Connectors
  • Arduino Compatible Connectors
  • 5v Power
Motor Controller
TLE94112 for Arduino
Buy NowBuy Now
  • DC Motor Control Sheild
  • Arduino Uno compatible
  • 12 x Half Bridge
  • Each can drive up to 0.9A
  • Polarity protection
Sensors
Pressure Sensor - DPS368
Buy NowBuy Now
  • Shield2Go Format
  • Pressure or Temperature
  • I2C or SPI
  • FIFO capable of holding 21 readings
Magnetic Sensor - TLV493D A1B6 MS2GO
Buy NowBuy Now
  • Shield2Go Format
  • X,Y, Z Magnetic Field
  • Linear Travel and 360 Degree Rotation
  • Arduino Library
  • 2Wire I2C
Smart Switch
Profet+2 12v Shield for Arduino Shield
Buy NowBuy Now
  • Arduino Uno Format
  • 12v
  • 12a
  • PWM
  • Open Load Detection
  • Under voltage Protection
Be Rewarded on the Community
For entering and taking part in the Design Challenge competition, you'll be rewarded the following badges:
imageApply to join the Design Challenge and receive a badge and points for applying! Make sure you've thought your application through, made it original and your own work. If you are building upon someone else's work, make sure you cite your sources. Direct copies of work will not be accepted.
imagePost your first blog! We expect updates on how your Design Challenge project is going, so don't hold back, tell us your thoughts, difficulties, and how you're progressing. Remember you're assessed based upon your updates, and don't be afraid - other challengers and members are there to help you with any problems you have, and it helps the staff to keep an eye on you!
image10 blogs! Wow, has it really been that long? We hope you'll keep us updated about your project at least once a week, for 10 weeks. We'll not be impressed if you only put a one-liner in there, that's what messages are for. Blogs are to make sure you're giving us all of the juicy detail, trials and tribulations of what's going on, and it keeps everyone honest!
imageEven if you're not a challenger in the Design Challenge, we appreciate every member who joins in and gives a helping hand to applicants and members. If your messages are found to be helpful, we want to acknowledge that and reward you!
Need help? Comment and read the resources below:
Technical Resources:
Infineon For Makers Support Page
https://www.infineon.com/cms/en/tools/landing/infineon-for-makers/?redirId=57262#overview
XMC4200 Platform2GO
Support Page
https://www.infineon.com/cms/en/product/evaluation-boards/kit_xmc_plt2go_xmc4200/
User Manual
https://www.infineon.com/dgdl/Infineon-XMC4200_Platform2Go-UserManual-v01_00-EN.pdf
PROFET +2 12V Arduino Shield
Data Sheet
http://www.farnell.com/datasheets/2876414.pdf
TLE94112ELShield
Data Sheet
http://www.farnell.com/datasheets/2256917.pdf
DPS368 Pressure Shield
Data Sheet
http://www.farnell.com/datasheets/2818769.pdf
3D Sense Shield2Go
Data Sheet
http://www.farnell.com/datasheets/2611872.pdf
The Dates
Project PhasesDates
Applications Open1st May 2020
Applications Close (1 Month)
25th May 2020
Challengers Announced
22nd July 2020
Projects Due
7th October 202
Winners Announced
Electronica 2020
Prizes Shipped
Early November 2020
The Prizes
PrizePrize Category
Grand Prizes
  • $500 USD Donated to the Environmental Charity of your Choice
  • 100 Trees Planted in your Name
  • Envirocycle Home Composter
  • Click and Grow Home Smart IoT Garden
  • Reusable Metal Straw and Cutlery Set
Runner up
  • $250 USD Donated to the Environmental Charity of your Choice
Finisher Prize
For anyone who completes 10 Blogs and a project with the featured product.
  • Solar USB Charger Battery Bank
  • 10 Trees Planted Per Finisher
*Or local equivalent
The Judges
Infineon
Technical Judge Team
element14 Community Judges
element14 Community Team
The Terms
Selected official applicants will be chosen to receive the "Kit" listed above. These successful applicants will be our sponsored challengers, and they must use at least 3 of the items of kit provided within their project. Those not chosen as sponsored challengers may also join the competition, but they must base their projects around the kit listed above and adhere to all terms and conditions of the challenge.
They need to post their progress and final project as at least 10 blog posts before the closing date. Posts which are media rich with photos, videos, and code samples will be viewed more favorably in the judging process.
Please read the full terms and conditions of the challenge, attached below.
Ready to join the challenge? Then Apply Here
If you are not successful in becoming a sponsored challenger but still want to enter, all you need to do is use the Kit as described above in your project and adhere to the same Terms and Conditions for a chance to be our winner! Non sponsored challengers are eligible for the Finisher and Winner Prizes as well.
imageSustain the World Terms and Conditions 70220.pdf
  • infineon
  • sustain_the_world
  • sustain the world
  • cgsolutions
    cgsolutions over 2 years ago +2
    This is very confusing. Apparently I am a Challenger selected as my kit is on the way. I am really unsure about how to make my entry work, but I will give it a try. There's got to be a change of dates…
  • jd_tech_support_ifx
    jd_tech_support_ifx over 2 years ago in reply to wanfp97 +2
    Hey Fook Peng, yes, Mr. Brew was referring to the enable pin. But if you put that pin on HIGH that should be fine as well. As far as I can see the SPI settings you chose should be fine. Do you have any…
    Hey Fook Peng, in the example the standard SPI-Pins of the Arduino are used, you can see the configuration here: https://github.com/Infineon/XMC-for-Arduino/wiki/XMC4700-Relax-Kit They are configured inside…
  • rati89
    rati89 over 2 years ago in reply to lesmalave
    Thats right, the P2Go should be used with DAVE and the XMC4700 Relax Kit can be used with both, Dave and/or Arduino IDE, as well as Platform.IO (recommended for bigger projects, instead of Arduino IDE)
  • lesmalave
    lesmalave over 2 years ago in reply to robogary
    Arduino is not supported at this time. The XMC4700 does have arduino support
  • shirishbharde
    shirishbharde over 2 years ago in reply to rati89
    ok, will do that
  • rati89
    rati89 over 2 years ago in reply to shirishbharde
    Please reach out to community@infineon.com and describe your case also. Thanks!
  • rati89
    I am sorry to hear that!
    We will clarify the case and reach out to you asap.
    BR
    brew
  • shirishbharde
    I had requested for update on the shipment a couple of times earlier but have not received any response on the same.
  • rati89
    Hello Bharde,
    the challenge is already on going since over 1.5 months. We started the challenge shortly after the Kits were sent out and received by all challengers.
    Now I am wondering, why you didn't tell it earlier, because people are posting since weeks in the platform here and also E14 sent out several emails already.
    The challenge will end by next week. I will ask E14 what happened with your shipment, but unfortunately, I do not think you will receive it early enough and also the time is already nearly over.
    I try that you will get your kits, but for the challenge I think it is too late now.
    I am sorry!
    BR
    Ratimir
  • shirishbharde
    "20 successful applicants will receive the Challenge Kit free of charge to build and blog their project with"
    It is mentioned that the challenger shall receive a development kit to build the project, I have not yet got this development kit
  • rati89
    Hello Shirish,
    what do you mean by you did not receive it?
    BR
    Brew
  • shirishbharde
    shirishbharde over 2 years ago in reply to e14phil
    I have not yet received my Development Kit, I have tried my codes on Arduino but will need time to port and ETA on when i will receive my Kit
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
  • Twitter
