element14's The Ben Heck Show
Forum Voltage doubler for beaglebone black fan
  • Subscribers 29 subscribers
  • Views 718 views
  • icl7660
  • voltage
  • BeagleBone
  • doubler
I've been working on a circuit that will take the 5V from the beaglebones GPIO and boost it up so that I can drive a fan, I started with getting a ICL7660 chip, and found I was getting 13V and could drive a little 12V 10mA fan quite happily but I wanted to switch to a blower which takes 900mA and it wont even start, I monitored the power into the beagle and its not even close to 1A let alone the 2A PSU I'm using so I'm guessing the chip is limited to a few mA, do any of you know of a circuit that will eliminate this problem or is it the beaglebone itself?
I dont want to run this on a separate circuit as it will be used in a situation where additional plugs are impossible
As always thanks to anyone that can help
    look into using a power mosfet like this:
    N-channel power MOSFET [30V / 60A] ID: 355 - $1.75 : Adafruit Industries, Unique & fun DIY electronics and kits
    0 dougw over 12 years ago
    Hi Kevin,
    Voltage boost modules are readily available or you can build your own - here is an example based on an LM2577 - you can make your by following the example in the datasheet:
    DC DC Auto Boost Buck Step UP Step Down Converter Module Solar Voltage LM2577 | eBay
    To convert 5 Volts to 12 V at 900 mA will require at least 2160 mA from your 5 V source and probably more like 2400 mA.
    If you are getting your 5 V source from the Beaglebone Black connector it will likely not be able to supply enough current due to the size of the copper traces on the PCB.
    Thanks, ill need to runup a couple of test circuits at the weekend, I am thinking of trying to reverse the flow so I might add a power connector to the shield and power the beagle from there and your calculations on the current required is a fantastic extraimage, dont suppose you know a way for me to know the amount of current i can get through the power line? (ei I/mm width) i have an old beagle that i can test to destructionimage
    0 dougw over 12 years ago in reply to e14 Contributor
    I'm not sure I understand the question, but there are lots of online PCB trace width calculators you can use to get a feel for how much current your PCB can handle.
    Here are some examples:
    http://circuitcalculator.com/wordpress/2006/01/31/pcb-trace-width-calculator/
    ANSI PCB Track Width Calculator
    The PCB Track Width Calculator
    PCB Trace Width Calculator
    I expect the BBB has 1 oz/'2 copper thickness...so 2.4 A requires a trace about .04" wide...
    0 e14 Contributor over 12 years ago in reply to dougw
    Thanks, I knocked up this circuit and it is working like a charm though the diode is massive, and as its only drawing 0.9A, I don't think I need the 3A one that was recommended though I did go for the fixed 12V version as voltage change is not necessary.
