    Members
    • Avnet Boards Community
    • Choose Another Store
Project Videos
  • Project Videos
Project Videos
Documents Episode 536: Interactive Light-Up Window with Pose Detection using a Raspberry Pi and Micro:bit
Project Videos requires membership for participation - click to join
  • Author Author: kellyhensen
  • Date Created: 2 Feb 2022 1:52 PM Date Created
  • Last Updated Last Updated: 28 Jun 2022 10:46 PM
  • Views 10835 views
  • Comments 16 comments
Snow and really wet weather ruined Lorraine’s capacitive touch buttons on her last element14 video. This time she was determined to find multiple weatherproof solutions to allow her neighbors to control RGB lights in her sitting-room window. Lorraine built a motion distance sensor using a time of flight sensor and a micro:bit. The neighbors can now control the color of the lights by moving their hands back and forward in front of the sensor. Then, using a Raspberry Pi and an infrared camera, Lorraine tracked whole body movement using pose detection. Raising the right hand changes the lights to red, raising the left hand changes to lights to blue.
What other moves or actions would you add?
Supplemental Content:
  • Episode 536:  Bonus Video - Pose Detection Code
  • Episode 536: Bonus Video: Pose Detection Road Blocks
  • Makecode
  • Time of flight sensor library
  • Pose Estimation Library
  • Resources
  • Episode 527:  Interactive Light Up Window using a Raspberry Pi and Micro:bit
  • Episode 527: Bonus Video: Digital Window
Bill of Material:
RASPBERRY PI 4 Raspberry Pi 1 Buy Now
Raspberry Pi Power Supply, USB C Raspberry Pi 1 Buy Now
SD Card TRANSCEND 1 Buy Now
Premium Female/Female Jumper Wires, 40 x 6" Adafruit 1 Buy Now
Raspberry Pi NOIR camera Raspberry Pi 1 Buy Now
VL53L0X time of flight sensor DFROBOT 1 Buy Now
Additional Parts:
Product Name
Infrared lights
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • micro:bit
  • time of flight sensor
  • e14p_LU
  • pose detection
  • lorraine
  • e14presents_lorraineunderwood
  • raspberry pi noir camera
  • raspberry pi
  • friday_release
    beacon_dave 6 months ago in reply to beacon_dave +1
    Perhaps if you created a low resolution LED matrix across the window frame, then you could show the pose as a stick figure. You could then either mimic the captured pose in real time on the matrix or alternatively…
    beacon_dave 6 months ago in reply to dougw
    In that case perhaps replace the control box with a mannequin head wearing sunglasses. 'DJ Cool Santa is in da house and checkin' out your moves...'
    Go one step further - animatronic Santa showing the recognised gestures to follow along to. ( 9months, plenty of build time Slight smile )
    • Reply
    dougw 6 months ago
    I might try anti-glare or anti-reflective film to minimize reflections. Maybe even cheap sunglasses that have an anti-glare coating.
    • Reply
    DAB 6 months ago
    Nice project.
    Impressive results for just a simple video capture.
    You could do Green when you cross your arms above your head.
    Turn on white if you stand on one leg.
    You can have all kinds of combinations.
    To extend the range, you could mount your IR LED's further out in the yard, though you might get beyond the range of the simple IR camera lens resolution ability.
    • Reply
  • kmikemoo
    kmikemoo 6 months ago
    lorrainbow  Nice project upgrade.  One of the things that I liked about the VL53 was that it even reflected off of water.  My guess is that every lens will have an impact.
    You might consider going lower tech with it.  Use the lens ring from the broken NoIR camera to mount the VL53.  Mount the lens ring in the knockout opening and let the VL53 have a clear shot at the world.  Maybe add an awning over the knockout opening so the rain would have to fall almost sideways to hit the sensor.
    During Build Inside The Box, I also learned that ambient light dramatically affected the perceived range.  This leads me to the recommendation of "Leave it as is".
    It is to be played with.  One meter or one centimeter isn't the important thing.  Changing lights is.  00-32=one color.  33-66=second color.  67-99=third color.  Only look at the last two digits.  Lather. Rinse. Repeat.
    • Reply
    Just wondering, with the pose detection, how will participants know which poses / gestures are recognised by the system ?
    Is there going to be an aerobics instructor style voice-over emitted from the box on the wall ?
    'move to the left... move to the right... now raise both your hands... and wave...'  Slight smile
    Or perhaps just giving hints if a specific gesture hasn't been recognised recently.
    • Reply
    You could perhaps try improving the optical isolation between the transmitter and the receiver on the ToF device when placing behind the tape 'window'.
    Page 27 of this paper from Texas Instruments may help:
    https://www.ti.com/lit/an/sbau305b/sbau305b.pdf?ts=1643965029568#page=27
    Perhaps try moving the sensor closer to the window and having separate windows. Or try using something like O-rings between the window and each half of the sensor to provide better Tx to Rx leakage isolation.
    • Reply
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
