    Members
    • Avnet Boards Community
    • Choose Another Store
Project Videos
  • Project Videos
Project Videos
Documents Episode 549: Using a Teletype Machine as a USB Printer with Arduino
Project Videos requires membership for participation - click to join
  • Author Author: kellyhensen
  • Date Created: 3 May 2022 12:25 PM Date Created
  • Last Updated Last Updated: 29 Jun 2022 8:25 PM
  • Views 11881 views
  • Comments 39 comments
In a previous Episode Clem has mapped out the pinout for his 1960 Siemens S100 Teletype. Now it is time to decode its communication protocol and interface it with an Arduino to connect it over USB to a modern PC! 75Baud 5-Bit Baudot code is quite different to modern ASCII encoding. There are some bumps in the road like Baudrate calibration and recreating the Serial protocol in Arduino Code! What retro Tech would you like to revive?
Supplemental Content:
  • Clem talks through the code and schematics
  • Code for Download
Bill of Material:
"CP2102-GMR" USB to Uart converter Silicon Labs 1 Buy Now
Atmega 328 P Microship 1 Buy Now
"MAX3232CPE+" Maxim 1 Buy Now
"RZ03-1C4-D005" Schrack 1 Buy Now
"USB-B-S-RA" Multicomp 1 Buy Now
"2301843-2" DB9 TE CONNECTIVITY 1 Buy Now
Additional Parts:
Siemens T100 S (S100) teletype from 1960
Ferrules
Aviation connector 4 Pin
Patience and determination
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • clem
  • silicon labs
  • Baudot code
  • siemens
  • usb
  • Retro Tech
  • maxim
  • teletype
  • friday_release
  • e14p_CMM
  • TheJamesH
    TheJamesH 3 months ago +1
    You could possibly add a switch to the TTY to act as a synch pulse. You would then have the real frequency and could automaticaly adjust your timing in code. I'm imagining something as simply as a magnet…
  • javagoza
    javagoza 3 months ago +1
    Great, I'm working on a similar project, looking for ideas for an old Bother electronic typewriter that I found abandoned on my street last month. I already have the typewriter working as a typewriter…
  • mayermakes
    mayermakes 3 months ago +1
    Make Sure to check out the Bonus Videos of this project. with detailed walkthroughs of the schematic (Hardware) and the Arduino Code of this project:
    community.element14.com/.../episode-549-code-and-schematic…
  • TheJamesH
    You could possibly add a switch to the TTY to act as a synch pulse. You would then have the real frequency and could automaticaly adjust your timing in code. I'm imagining something as simply as a magnet on a shaft with a nearby Hall effect switch.
    • Reply
  • TheJamesH
    • Reply
  • mayermakes
    mayermakes 3 months ago in reply to TheJamesH
    yes, for that sort of feature a soution without moving parts would be best like you describe with a hall effect sensor. this also needs soem calibration to create the right timing for sync pulses, so I would not think of it as the easier solution compared to tuning it again every now and then.
    the main problem I see now is missing characters and how to replace them with combinations without messing up everything else or keeping combatibility with widely used Busses.
    • Reply
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
