    Members
    • Avnet Boards Community
    • Choose Another Store
Project Videos
  • Project Videos
Project Videos
Documents Episode 549: Using a Teletype Machine as a USB Printer with Arduino
Project Videos requires membership for participation - click to join
  • Author Author: kellyhensen
  • Date Created: 3 May 2022 12:25 PM Date Created
  • Last Updated Last Updated: 29 Jun 2022 8:25 PM
  • Views 11875 views
  • Comments 39 comments
In a previous Episode Clem has mapped out the pinout for his 1960 Siemens S100 Teletype. Now it is time to decode its communication protocol and interface it with an Arduino to connect it over USB to a modern PC! 75Baud 5-Bit Baudot code is quite different to modern ASCII encoding. There are some bumps in the road like Baudrate calibration and recreating the Serial protocol in Arduino Code! What retro Tech would you like to revive?
Supplemental Content:
  • Clem talks through the code and schematics
  • Code for Download
Bill of Material:
"CP2102-GMR" USB to Uart converter Silicon Labs 1 Buy Now
Atmega 328 P Microship 1 Buy Now
"MAX3232CPE+" Maxim 1 Buy Now
"RZ03-1C4-D005" Schrack 1 Buy Now
"USB-B-S-RA" Multicomp 1 Buy Now
"2301843-2" DB9 TE CONNECTIVITY 1 Buy Now
Additional Parts:
Siemens T100 S (S100) teletype from 1960
Ferrules
Aviation connector 4 Pin
Patience and determination
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • clem
  • silicon labs
  • Baudot code
  • siemens
  • usb
  • Retro Tech
  • maxim
  • teletype
  • friday_release
  • e14p_CMM
  • TheJamesH
    TheJamesH 3 months ago +1
    You could possibly add a switch to the TTY to act as a synch pulse. You would then have the real frequency and could automaticaly adjust your timing in code. I'm imagining something as simply as a magnet…
  • javagoza
    javagoza 3 months ago +1
    Great, I'm working on a similar project, looking for ideas for an old Bother electronic typewriter that I found abandoned on my street last month. I already have the typewriter working as a typewriter…
  • mayermakes
    mayermakes 3 months ago +1
    Make Sure to check out the Bonus Videos of this project. with detailed walkthroughs of the schematic (Hardware) and the Arduino Code of this project:
    community.element14.com/.../episode-549-code-and-schematic…
  • javagoza
    Great, I'm working on a similar project, looking for ideas for an old Bother electronic typewriter that I found abandoned on my street last month. I already have the typewriter working as a typewriter and now I was starting to understand how it works inside.
    • Reply
  • WilliamF
    WilliamF 3 months ago in reply to javagoza
    https://youtu.be/1OXD0xdS4pA It isn’t one of the ones I’m using in my demo is it? If so I have the hookup for the keyboard connector, I’ll have to detail the hookup as it isn’t in the repo linked further down in one of my other comments in the thread but I have schematics and arduino code etc in there
    • Reply
  • javagoza
    javagoza 3 months ago in reply to WilliamF
    Thanks! I'll take a look at it, great job.
    This is the one I've found abandoned.
    I haven't found the service manual yet.
    On the back there is a 12 pin circular connector
    • Reply
  • WilliamF
    Ok different model. Interfacing through the keyboard might be a bit more difficult (different UI by the looks, allows for spell check?, needs a CR/confirm to type to paper?). Guessing the connector may be for a serial device of some description. If RS232 poke with a meter to see if it has RS232 level voltages otherwise something TTL level, try poking it with some serial data, not sure if it would use handshake lines for flow control, some lines may need pulling one way or another to respond the lines that don’t have a voltage or pulling to ground hard and not ground are likely inputs
    • Reply
    beacon_dave 3 months ago in reply to javagoza
    It looks like there was a Brother IF-60 Computer Interface that gave you Centronics / RS-232 ports to turn it into a computer printer.
    • Reply
  • javagoza
    I disassembled it to take some photos. Luckily after reassembling it still works.
    • Reply
  • javagoza
    javagoza 3 months ago in reply to beacon_dave
    Thanks for the info! It will be a fun toy. I'll look up information on that IF-60 interface.
    • Reply
  • javagoza
    • Reply
  • javagoza
    javagoza 3 months ago in reply to javagoza
    archive.org/.../brother-if-60
    • Reply
    Toy ? Haven't you got a telex to get sent off to some guy called Clem with a 1960 Siemens S100 ? Slight smile
    There appears to be an earlier Brother IF-50 interface which looks like it had similar functionality. Not sure of it was just a cosmetic change / different connector, or if there was something radically different about it. Perhaps if you can get a pin-out or schematic for the IF-50 then it may give some clues as to the protocol used for the IF-60.
    • Reply
    Looks like the IF-60 adds a data terminal mode for direct use with a modem device.
    https://archive.org/details/BrotherIF50/mode/2up
    • Reply
    Photo of a Brother IF-60
    Photo of a Brother IF-60 opened up
    • Reply
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
