    Members
    • Avnet Boards Community
    • Choose Another Store
Project Videos
  • Project Videos
Project Videos
Documents Episode 549: Using a Teletype Machine as a USB Printer with Arduino
Project Videos requires membership for participation - click to join
  • Author Author: kellyhensen
  • Date Created: 3 May 2022 12:25 PM Date Created
  • Last Updated Last Updated: 29 Jun 2022 8:25 PM
  • Views 11774 views
  • Comments 39 comments
In a previous Episode Clem has mapped out the pinout for his 1960 Siemens S100 Teletype. Now it is time to decode its communication protocol and interface it with an Arduino to connect it over USB to a modern PC! 75Baud 5-Bit Baudot code is quite different to modern ASCII encoding. There are some bumps in the road like Baudrate calibration and recreating the Serial protocol in Arduino Code! What retro Tech would you like to revive?
Supplemental Content:
  • Clem talks through the code and schematics
  • Code for Download
Bill of Material:
"CP2102-GMR" USB to Uart converter Silicon Labs 1 Buy Now
Atmega 328 P Microship 1 Buy Now
"MAX3232CPE+" Maxim 1 Buy Now
"RZ03-1C4-D005" Schrack 1 Buy Now
"USB-B-S-RA" Multicomp 1 Buy Now
"2301843-2" DB9 TE CONNECTIVITY 1 Buy Now
Additional Parts:
Siemens T100 S (S100) teletype from 1960
Ferrules
Aviation connector 4 Pin
Patience and determination
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • clem
  • silicon labs
  • Baudot code
  • siemens
  • usb
  • Retro Tech
  • maxim
  • teletype
  • friday_release
  • e14p_CMM
  • TheJamesH
    TheJamesH 3 months ago +1
    You could possibly add a switch to the TTY to act as a synch pulse. You would then have the real frequency and could automaticaly adjust your timing in code. I'm imagining something as simply as a magnet…
  • javagoza
    javagoza 3 months ago +1
    Great, I'm working on a similar project, looking for ideas for an old Bother electronic typewriter that I found abandoned on my street last month. I already have the typewriter working as a typewriter…
  • mayermakes
    mayermakes 3 months ago +1
    Make Sure to check out the Bonus Videos of this project. with detailed walkthroughs of the schematic (Hardware) and the Arduino Code of this project:
    community.element14.com/.../episode-549-code-and-schematic…
  • mayermakes
    mayermakes 2 months ago in reply to aspork42
    doable, yes but I'm not good at realtime dataprocessing so I might not have gotten that to work in time.
    • Reply
  • aspork42
    aspork42 2 months ago
    Nice work! You could have also used a non-contact tachometer to measure the speed of the machine. Just put a piece of reflective tape on the shaft and let it spin.
    • Reply
    beacon_dave 3 months ago in reply to javagoza
    Photo of a Brother IF-60
    Photo of a Brother IF-60 opened up
    • Reply
    Looks like the IF-60 adds a data terminal mode for direct use with a modem device.
    https://archive.org/details/BrotherIF50/mode/2up
    • Reply
  • mayermakes
    mayermakes 3 months ago in reply to DAB
    thank you, its always worth overcoming obstacles!
    • Reply
    DAB 3 months ago
    Great job Clem.
    Your persistence paid off.
    • Reply
    Toy ? Haven't you got a telex to get sent off to some guy called Clem with a 1960 Siemens S100 ? Slight smile
    There appears to be an earlier Brother IF-50 interface which looks like it had similar functionality. Not sure of it was just a cosmetic change / different connector, or if there was something radically different about it. Perhaps if you can get a pin-out or schematic for the IF-50 then it may give some clues as to the protocol used for the IF-60.
    • Reply
  • javagoza
    javagoza 3 months ago in reply to javagoza
    archive.org/.../brother-if-60
    • Reply
  • javagoza
    javagoza 3 months ago in reply to beacon_dave
    Thanks for the info! It will be a fun toy. I'll look up information on that IF-60 interface.
    • Reply
  • javagoza
    javagoza 3 months ago in reply to WilliamF
    I disassembled it to take some photos. Luckily after reassembling it still works.
    • Reply
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
