    Members
    • Avnet Boards Community
    • Choose Another Store
Project Videos
  • Project Videos
Project Videos
Documents Episode 409: Commodore SX-64 Restoration
Project Videos requires membership for participation - click to join
Author: kellyhensen
Date Created: 27 Aug 2019 2:59 PM
Last Updated: 17 Mar 2022 4:56 PM
Comments: 15
Matt enjoys working with retro computer and gaming platforms, so when a friend asked if he wanted to come to take an "old Commodore laptop" off his hands, he jumped at the chance! The machine had obviously seen its better days, but Matt would not be deterred from such an extreme restoration challenge! Will the SX-64 come back to life? Watch as Matt repairs and rebuilds a relative retro computing rarity, restoring it to its former glory so he can finally play Planet X2!
Supplemental Content:
  • Are You Keeping Up With The Commodore?
  • Commodore 64 AV Cable
  • Commodore SX-64 Blank Screen Fix
  • Commodore SX-64 Keyboard Repair
  • Commodore SX-64 1541 Floppy Drive Repair
  • Replacement Transit Card for Commodore 64/VIC-1540/1541/1571
Bill of Material:
DIN Audio / Video Connector, 5 Contacts, Plug, Cable Mount, Solder, Tin Plated Contacts, Metal Body SwitchCraft 2 Buy Now
DIN Audio / Video Connector, 6 Contacts, Plug, Cable Mount, Solder, Tin Plated Contacts, Metal Body SwitchCraft 2 Buy Now
Computer Cable, D-Sub Plug to D-Sub Receptacle, 6 ft, 1.8 m, Black Tripp-Lite 1 Buy Now
Computer Cable, D-Sub Plug to D-Sub Receptacle, 2.5 ft, 760 mm, Black L-COM 1 Buy Now
D Sub Connector, DB25, Standard, Plug, AMPLIMITE HD-20 Series, 25 Contacts, DB, Solder AMP-TC Connectivity 1 Buy Now
Mains Power Cord, NEMA 5-15P to IEC 60320 C13, 1.2 m, 10 A, 125 VAC, Black Tripp-Lite 1 Buy Now
Audio / Video Cable Assembly, Stereo Audio Patch, Dual RCA Plugs to Dual RCA Plugs, 6 Ft, 1.8 M Stellar Labs 1 Buy Now
Premium Female/Male Extension Jumper Wires, 40 x 6" (150mm) Adafruit 1 Buy Now
Extraction Tool, DIP/IC OK Industries 1 Buy Now
Additional Parts:
Product Name
Commodore SX-64
Bondo Automotive Filler Compound
Rustoleum Metallic Satin Nickel Finish paint
Commodore 906114-01
Commodore VIC-1540
element14 presents  |  About Matt |  Project Videos
  • commodore 1541 repair
  • vic-1540 repair
  • sx-64 disk drive repair
  • commodore 64 chip replacement
  • sx-64 blank screen
  • commodore keyboard repair
  • switchcraft
  • sx-64 keyboard doesn't work
  • commodore 64 serial cable
  • sx-64 keyboard cable
  • matt eargle
  • commodore 64 av cable
  • sx-64 repair
  • commodore 64 restoration
  • sx-64 restoration
  • sx-64 keyboard repair
  • friday_release
  • tripp-lite
  • commodore 64 repair
  • commodore disk drive repair
    DAB over 2 years ago +3
    Great job of refurbishing the Commodore.
    I sometimes think about refurbishing my old Commodore PET 2000, but it would be a lot of work.
  • clem57
    clem57 over 2 years ago +2
    Got really excited when the screen worked.
  • mayermakes
    mayermakes over 2 years ago +2
    Wow a metric ton of additional content!
    I laso got some old computers that need refurbishing, maybe I whip them out some day.
  • d3bug
    d3bug over 2 years ago
    Good except for a couple of suggestions:
    1. You should have checked the alignment of the drive instead of replacing the mechanism.  It is dead simple to write a small BASIC program to do so.
    2. You should consider re-capping the entire board's electrolytic capacitors as they leak over time and cause issues.
    3. You should probably add a heat sink to the chips to prevent further damage long term.
    Have a look at this book:  Inside Commodore DOS (PDF)
    • Up 0 Down
    • Reply
  • airbornesurfer
    airbornesurfer over 2 years ago in reply to d3bug
    I appreciate the suggestions, and believe me when i say, I tried everything to get that drive working (We often don't show every specific failed attempt due to time constraints).
    1. Drive alignment was the first and most obvious answer, but it wasn't the problem. The problem stemmed from a combination of a worn-out mechanism and a malfunctioning read/write head. It was faster and easier to swap the drive wholesale. I'll revisit the original drive with the standalone 1541 another day.
    2. Yes, of course, but that was not within the scope of this video.
    3. Heat management on the old PLA chips is a problem, and a heatsink will solve that problem, correct.
    I actually have that book on my shelf! It's a great resource!
    Cheers
    • Up +1 Down
    • Reply
  • airbornesurfer
    Cheers
    • Up +1 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
