    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
Project Videos
  • Project Videos
Project Videos
Documents Room-Sized Studio Light Speakers Combo -- Episode 431
Project Videos requires membership for participation - click to join
  • Date Created: 27 Jan 2020 12:32 AM Date Created
  • Last Updated Last Updated: 31 Jan 2020 8:24 AM
  • Views 1648 views
  • Likes 9 likes
  • Comments 7 comments
Clem likes to hear Podcasts and Music while working on element14presents videos but he’s not keen on using headphones and does not want to pump the volume to max to hear his speakers across the room. So he turns the ceiling of his workshop into a giant speaker, by building Studio panels. These Panels also reduce room noise for better audio recordings and by adding small LED lights act as soft light boxes for filming. Dragging around big lights with softboxes is not needed anymore for a lot of shots and the right background music helps keep the groove. All in the name of better, faster project videos! Praise the everlasting Din5_180 Connector for its versatility!
Download the files in the attachment below!
Bill of Material:
DELTRON COMPONENTS DIN Audio / Video Connector, Screened, 180°, 5 Contacts, Plug, Cable Mount, Solder DELTRON COMPONENTS 5 Buy Now
DELTRON COMPONENTS DIN Audio / Video Connector, Screened, 180°, 5 Contacts, Jack, Panel Mount, Solder DELTRON COMPONENTS 5 Buy Now
VISATON Speaker, Structure-Born Driver, 45 cm, 10 W, 8 ohm VISATON 4 Buy Now
LEDXON MODULAR LED Strip, 1 m, 60 LEDs, Cool White, 24 VDC, 14.4 W, IP20 LEDXON MODULAR 8 Buy Now
IDEAL POWER AC/DC Power Supply, ITE, 1 Output, 150 W, 24 V, 6.25 A IDEAL POWER 1 Buy Now
LAPP KABEL Multicore Cable, UnitronicRegistered LiYCY, Screened, 4 Core, 24 AWG, 0.25 mm², 164 ft, 50 m LAPP KABEL depends on spacing b/w panels & power source Buy Now
1.2V to 37V, 1.5A Adjustable Positive Voltage Regulator in TO-220-3 Package ON SEMICONDUCTOR 4 Buy Now
Additional Parts:
Product Name Quantity
XPS sheet 2cm (Extruded polystyrene used for insulating cellars from the outside)
1
Plywood for lasercutting
1
optional Lathe to make the holes bigger, but should be possible to do with a drillpress
1
StudioLights_Resources.zip
element14 Presents  |  About Clem  |  Project Videos
  • audiophile
  • deltron
  • ceiling mounted
  • lm317t
  • homemade filming lights
  • videography
  • room sized speakers
  • voltage regulator
  • clem
  • filmmaking tutorial
  • video lights
  • e14presents_mayermakes
  • room echo
  • diy
  • wall mounted
  • silder poti
  • videopgraphy diy
  • tudio equipment diy
  • studio panels
  • led
  • filming lights
  • visaton
  • giant speakers
  • noise reduction
  • film hacks
  • how to record audio
  • filmmaking
  • on semiconductor
  • music
  • how to remove echo
  • av connector
  • noise cancelling
  • friday_release
  • Speakers
  • mayermakes
  • podcasts
  • studio lights
  • laser cutting
  • e14p_CMM
  • mayermakes
    mayermakes over 3 years ago in reply to kmikemoo +2
    thank you, I learned that the behavoiur in case of sound can be utilized in both ways, if you'd build a membrane to make a cartain frwquency, that membran would also absorb that same frequency(for the…
    DAB over 3 years ago +2
    Very good project Clem. Well done. DAB
  • mayermakes
    mayermakes over 3 years ago in reply to DAB +2
    Thanks DAB! Glad to have earned a fourth star from you!
  • kmikemoo
    kmikemoo over 3 years ago
    Very cool.  Ingenious that the same material I would use to dampen sound you are using as the cone to make sound. imageimage
    Thanks also for addressing the flicker.  I would have probably just put a large electrolytic on it and been unhappy with the result.
  • mayermakes
    thank you, I learned that the behavoiur in case of sound can be utilized in both ways, if you'd build a membrane to make a cartain frwquency, that membran would also absorb that same frequency(for the most part)
    Most cone speakers can also be used as microphones, Imay try to utilize the panels as microphones in a follow up segment on a future video.
  • mayermakes
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
