Project Videos
  • Project Videos
Project Videos
Documents Upcycling a Vintage Microphone into an Emergency Radio System -- Episode 663
Toptech-Voices
  • Author Author: cstanton
  • Date Created: 24 Apr 2025 4:19 PM Date Created
  • Last Updated Last Updated: 25 Apr 2025 10:13 AM
  • Views 4854 views
  • Comments 21 comments
Clem attempts to create an audio transmission system using two old microphones, exploring the process of converting audio into a digital signal via pulse-width modulation (PWM). He encounters difficulties in getting the analogue system to function properly, detailing the use of low-pass filters, amplifiers, and comparator circuits to modulate audio onto a carrier frequency. Clem shares his understanding of the theory behind the project but admits that the system doesn't quite work as planned.
Watch the Video
We’ve all been there—starting out in electronics, buying a bunch of random parts that seem useful at the time, and then letting them gather dust in a drawer somewhere. For Clem, this collection of forgotten RF modules was no different. After narrowly avoiding the impact of a major flood in his area, he wondered if he could create an emergency communication system with the spare parts from his electronics stash. However, Clem faced a few challenges—not only was he missing some essential components, but he was also diving headfirst into an area he had little experience with: analogue electronics. But hey, that's all part of the fun, right?
A DIY Approach: Building From Scratch
Instead of spending hours researching the perfect setup, Clem did what many of us do: he jumped straight into the project, soldering things together with whatever he had on hand. His base? A retro 1980s microphone and speaker combo, likely used in an old taxi radio system. The original housing wasn’t quite big enough to hold all the necessary components, so Clem 3D-printed an extension ring, using some Proto-pasta conductive PLA he’d received from the element14 community staff for review. This innovative material kept the housing both functional and shielded from interference.
The Antenna Hack
For the antenna, Clem went with the tried-and-true method of using 1.6mm thick tinned copper wire, which he straightened by twisting it in a drill. Classic! To keep things neat, he 3D-printed custom inserts for BNC connectors, ensuring that the antennas were well-isolated from the housing walls. While PLA didn’t quite cut it for this application, MAYER MAKES Engineering Resin was the perfect fit. It had the right tolerances and strength to replace the old nylon inserts, which couldn’t accommodate the new, thicker antenna wires.
First Test Run: Mixed Results
The first test was promising but not perfect. When Clem pressed the button, the unit did send a signal—but it wasn’t quite the sine wave he expected. Instead, it looked more like a digital signal. Curious but not discouraged, he built a second unit, hoping to establish a clear link between the two. And yes, there was a connection! However, instead of the sound he hoped for, the speakers emitted only a faint crackling noise.
Diagnosing the Problem
Armed with a signal generator, Clem injected a known frequency into the transmitter to see how the receiver would react. The result? Success! The devices did indeed communicate with one another, and the signals changed based on the input. The catch? The signals weren’t audio; they were digital pulses—essentially the duty cycle of the input signal being transmitted and received.
That’s when Clem had a light-bulb moment: these RF modules communicate only in digital signals, meaning they transmit data as discrete on/off pulses. To get audio working, Clem would need to encode, transmit, and then decode the audio into a digital format. He sketched out a schematic that combined a known PWM (Pulse Width Modulation) carrier signal with an amplified microphone input. This method would transform the sound into a digital signal that could then be sent over the RF modules.
Is It Worth It?
At this point, Clem had to ask himself: should he continue down this path? The antennas, made to full wavelength, were designed for maximum reception, but the signal range was limited to just a few meters. Plus, 433 MHz RF modules, once groundbreaking, have now been overtaken by cheaper and more efficient options like WiFi modules, which can transmit far more data over greater distances with much better reliability.
So Clem turns to the community for advice: Should he stick with the digital route, using these old RF modules to transmit voice, or go fully analogue and build a proper ham radio-style sender and receiver system? The analogue route could offer more authenticity and simplicity, but digital opens up interesting possibilities. Or perhaps, should he abandon both and pivot to using modern WiFi technology for a more robust solution?
Clem’s project is at a crossroads, and he’s keen to hear your thoughts! Would you pursue the digital RF modules, embrace the challenge of analogue radio, or leap into WiFi for a more reliable emergency communication system? Let him know your ideas and suggestions!
Supporting Links and Files
  •  Supporting Files for Episode 663 of element14 presents
Bill of Materials
MC7805CTG onsemi 2 Buy Now
MCP602 Microchip 2 Buy Now
tinned copper wire MULTICOMP PRO TCW16 500G Multicomp 1 Buy Now
Miscellaneous
Microphone, Speaker 433mhz modules, amp module
Protopasta conductive PLA → thanks to the E14 community for providing it for review!
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • Pulse Width Modulation Audio
  • Microphone audio conversion
  • analog signal processing
  • Electronics for hobbyists
  • frequency modulation diy
  • e14presents_mayermakes
  • rf communications projects
  • Square wave audio signal
  • Audio modulation techniques
  • comparator circuit design
  • Audio Signal Encoding
  • ham radio electronics
  • Analog Audio Transmission
  • Wireless Audio transmission
  • friday_release
  • DIY electronics projects
  • low-pass filter audio
    beacon_dave over 1 year ago +1
    Perhaps one issue with using this type of system as an emergency communication system is who is going to be actively listening at the far end to receive the transmission ? Another issue is that modern…
  • mayermakes
    mayermakes over 1 year ago in reply to beacon_dave +1
    thats why my attention was drawn to these modules for the pure reason, that i just had them laying around for ages. but also an analog transmission might just be picked up as interference and could at…
    beacon_dave over 1 year ago in reply to mayermakes
    After being in a similar situation in 2015, which resulted in around 61,000 homes without power, of which around 5,200 ended up being flooded, then that potentially could generate a lot of messages on an emergency system like this.
    A LoRa text based system might work as it's low power and potential to set up a mesh system to be able to extend the range. Text has the advantage that you can can have pre-formatted data in a specific format that can easily be collected in large quantities and filtered.
  • mayermakes
    mayermakes over 1 year ago in reply to dougw
    yep, that exactly the solution I described at the end of the video, of course a few other methodas with mcus ,ADCs and comparators /opamps might work to.
    dougw over 1 year ago
    If the carrier is simply off or on, converting the audio to a PWM signal before the transmitter should allow the audio to be recovered after the receiver using a simple low pass filter.
  • mayermakes
    mayermakes over 1 year ago in reply to kmikemoo
    Zafers version is not so different in schematics than my attempt (I just had an amplifier in the mix), tmk I can not verify if the modules are actually identical or if hes actually transmitting voice and not just crackle. its a bit hard to tell. TMK these modules need to have audio encoded to actually transmit it.
  • mayermakes
    thats why my attention was drawn to these modules for the pure reason, that i just had them laying around for ages. but also an analog transmission might just be picked up as interference and could at least grab someones attention even if the message does not go through, they at least could get an indication of someone needing help.
  • mayermakes
    a little bit more range ,_)
  • mayermakes
    mayermakes over 1 year ago in reply to rsc
    interesting , haven´t heard of that yet!
  • kmikemoo
    kmikemoo over 1 year ago
     mayermakes Check out Zafer Yildiz video on a method that might work for you.  https://www.youtube.com/watch?v=o1lduXJH_W4
    As far as just getting out... you could try the MadElectro_1 method I used in  The Frugal Fox .  I might be as simple as the element mic and a battery.  Maybe.  It is transmit no receive.
    Another issue is that modern communication now appears to rely so heavily on telecoms infrastructure, which tends to go off-line during the emergency, when you need it the most.
    Andreas Spiess shows you how to get a bit more range using an ESP32 module.
    36'000 km range with a simple ESP32? For sure a world record!
