The Learning Circuit
  • The Learning Circuit
Documents How Transistors Work -- The Learning Circuit 27
  • Date Created: 8 Oct 2018 4:06 PM Date Created
  • Last Updated Last Updated: 24 Oct 2018 7:24 AM
  • Views 11522 views
  • Likes 12 likes
  • Comments 27 comments
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
In today's Episode Karen discusses transistors. Rather than using a physical, mechanical switch, a transistor can act as an electronic switch, using signals to turn it on or off.  She'll go over what they are, how they work, and some types of transistors.  She'll cover Bipololar junction transistors (BJT), NPN transistors, PNP transistors, and darlington transistors.
The Learning Circuit 37: Community Feedback: Revisiting Transistors
Transistors eBook Part 1
  • stem_projects
  • tlc
  • vbe
  • mosfets
  • base-emitter voltage
  • e14presents_makerkaren
  • switches
  • pnp transistors
  • circuit
  • jfet
  • field-effect transistors
  • battery
  • npn transistors
  • collector-emitter voltage
  • vce
  • diodes
  • darlington transistors
  • thelearningcircuit
  • darlington pair
  • jc2048
    jc2048 over 7 years ago +5
    There's some good information in this episode but there are a few things I think you might want to review. 4:24 "Leaving 8.3V as your VCE." The VCE with the transistor on, assuming that there's enough…
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    Great stuff. The graphics add a lot for understanding. -Sean
  • jc2048
    jc2048 over 7 years ago in reply to jc2048 +4
    Anyone looking at this episode might like to know that Karen and James Lewis revisted this topic in The Learning Circuit 37: Community Feedback: Revisiting Transistors so it's worth watching that one too…
  • miles90
    miles90 over 5 years ago
    Thank you very much Karen.
    I wish I had a teacher like you at high school. Learning physics at that time was really painful. No one but you on youtube mentions the fact that the arrow points toward the N-type region of the transistor.
    I remember, a few weeks ago, I was trying to find out how to memorize the polarity of a diode’s anode. Now I know that the anode is where the P-type material is located and it is the positive terminal while the cathode is where the N-type material is located and it is the negative terminal.  It makes sense actually with electrochemistry as we have the same inverse relationship.  In an electrochemical cell, the anode (where the anions gather) is the positive terminal and the cathode (where the cations gather) is the negative terminal.
    Also, in circuits diagrams,  the diode’s arrow points in the direction of the current flow. But here, this is the direction of the conventional current, that is the direction of positive charges, not electrons. So electrons move in the opposite direction. That means that the arrow points toward the electron donor, the N-type material, which is consistent. It is all clear now.
    Good job Karen.
  • makerkaren
    makerkaren over 5 years ago in reply to miles90
    Hurray! Glad you found it helpful.
    Yeah, it all started with diodes. Or you can think of LEDs (which are also diodes) many 5mm LEDs have a flat side at the cathode, so if you remember the diode symbol has a line on the cathode side, then you can remember that the flat side of the LED is the negative lead.
    Also for the anions and cations, I love when other areas of science come into play and those mental connections really help solidify a concept. Glad you made that connection. I'm sure that's why the leads are named that way.
  • miles90
    miles90 over 5 years ago in reply to makerkaren
    Will you please work on transistor biasing and amplifiers (class A, B, C, D amplifiers ...) ? That would be great.
  • miles90
