The Learning Circuit
  • The Learning Circuit
Documents How Transistors Work -- The Learning Circuit 27
  • Date Created: 8 Oct 2018 4:06 PM Date Created
  • Last Updated Last Updated: 24 Oct 2018 7:24 AM
  • Views 11697 views
  • Likes 12 likes
  • Comments 27 comments
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
In today's Episode Karen discusses transistors. Rather than using a physical, mechanical switch, a transistor can act as an electronic switch, using signals to turn it on or off.  She'll go over what they are, how they work, and some types of transistors.  She'll cover Bipololar junction transistors (BJT), NPN transistors, PNP transistors, and darlington transistors.
The Learning Circuit 37: Community Feedback: Revisiting Transistors
Transistors eBook Part 1
  • stem_projects
  • tlc
  • vbe
  • mosfets
  • base-emitter voltage
  • e14presents_makerkaren
  • switches
  • pnp transistors
  • circuit
  • jfet
  • field-effect transistors
  • battery
  • npn transistors
  • collector-emitter voltage
  • vce
  • diodes
  • darlington transistors
  • thelearningcircuit
  • darlington pair
  • jc2048
    jc2048 over 7 years ago +5
    There's some good information in this episode but there are a few things I think you might want to review. 4:24 "Leaving 8.3V as your VCE." The VCE with the transistor on, assuming that there's enough…
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    Great stuff. The graphics add a lot for understanding. -Sean
  • jc2048
    jc2048 over 7 years ago in reply to jc2048 +4
    Anyone looking at this episode might like to know that Karen and James Lewis revisted this topic in The Learning Circuit 37: Community Feedback: Revisiting Transistors so it's worth watching that one too…
  • jc2048
    4:24 "Leaving 8.3V as your VCE." The VCE with the transistor on, assuming that there's enough collector current to pull the load right down, will be a couple of hundred millivolts, so there will be something like 8.8V across the LED and resistor.  [The collector voltage really does come down below the base voltage. Look on a datsheet for the figures for 'saturation'.] The VCE is the voltage between collector and emitter, not that between the supply and collector.
    4.47 The PNP behaves the same as the NPN except for all the voltages being reversed in polarity. The VBE with the transistor on will be a similar 0.7V, just the other way round (so you'd measure -0.7V rather than 0.7V). You're muddling exactly where it is you're measuring the voltages between and complicating things too much.
    4:57 If you were to force the Vbe to 8.3V, the dissipation in the transistor would be such that it would get very hot inside and fail.
    • Vote Up +5 Vote Down
  • jc2048
  • jc2048
    so it's worth watching that one too.
