The Learning Circuit
  • The Learning Circuit
Documents How Transistors Work -- The Learning Circuit 27
  • Date Created: 8 Oct 2018 4:06 PM Date Created
  • Last Updated Last Updated: 24 Oct 2018 7:24 AM
  • Views 11666 views
  • Likes 12 likes
  • Comments 27 comments
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
In today's Episode Karen discusses transistors. Rather than using a physical, mechanical switch, a transistor can act as an electronic switch, using signals to turn it on or off.  She'll go over what they are, how they work, and some types of transistors.  She'll cover Bipololar junction transistors (BJT), NPN transistors, PNP transistors, and darlington transistors.
The Learning Circuit 37: Community Feedback: Revisiting Transistors
Transistors eBook Part 1
  • stem_projects
  • tlc
  • vbe
  • mosfets
  • base-emitter voltage
  • e14presents_makerkaren
  • switches
  • pnp transistors
  • circuit
  • jfet
  • field-effect transistors
  • battery
  • npn transistors
  • collector-emitter voltage
  • vce
  • diodes
  • darlington transistors
  • thelearningcircuit
  • darlington pair
  • jc2048
    jc2048 over 7 years ago +5
    There's some good information in this episode but there are a few things I think you might want to review. 4:24 "Leaving 8.3V as your VCE." The VCE with the transistor on, assuming that there's enough…
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    Great stuff. The graphics add a lot for understanding. -Sean
  • jc2048
    jc2048 over 7 years ago in reply to jc2048 +4
    Anyone looking at this episode might like to know that Karen and James Lewis revisted this topic in The Learning Circuit 37: Community Feedback: Revisiting Transistors so it's worth watching that one too…
  • aragao
    aragao over 6 years ago
    I understand how it works, but something isn't right: The main current from the colector to the emiter, on an NPN transistor, is going against the diode that points in that direction.
    How is this possible ? It's one of those different diodes ?
  • aragao
    jw0752 over 6 years ago in reply to aragao
    Remember that in reality it is electrons that flow but the convention (diagrams and mathematics) is to treat the positive charges as the carriers and not the electrons. Blame Benjamin Franklin, he guessed at whether it was the positive or negative charges and he got it wrong. Another confusing thing is that the arrows on an enhanced MOSFETs point in for the N Channel types and Out of the P Channel types which is the opposite of the standard BJT (transistors) devices.
    beacon_dave over 6 years ago in reply to aragao
    You may find this animation on YouTube helpful to visualise what happens:
    Transistors, How do they work ?
