    Members
    • Avnet Boards Community
    • Choose Another Store
The Learning Circuit
  • The Learning Circuit
Documents The Learning Circuit 72: How to Generate a Clock Signal with a 555 Timer
The Learning Circuit requires membership for participation - click to join
  • Date Created: 12 May 2020 5:53 PM Date Created
  • Last Updated Last Updated: 15 Jul 2020 1:36 PM
  • Views 895 views
  • Comments 7 comments
The Learning Circuit | element14 presents |  Project Videos
Karen has been digging into 555 timers for a bit now. In a previous video, she did an overview of the 3 different modes in which a 555 timer can be used. In this video, Karen goes into further detail about one of those modes: Astable. In astable mode, a 555 timer can be used as an oscillator where the output automatically switches between high and low at a consistent rate as long as the 555 timer is connected to power.This is often the most common use of a 555 timer as it can be used to create the clock signal for other ICs. Karen explains what is happening inside the 555 to make this work, as well as creating the circuit on a breadboard to show how it works in a practical example.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
Breadboard, MCM 60 rows, ABS, 8.5mm, 165mm x 56mmMulticomp1Buy NowBuy Now
LM555CN - Timer, Oscillator & Pulse Generator IC, TTL Compatible, Astable, Monostable, 4.5 V to 16 V, DIP-8On Semiconductor1Buy NowBuy Now
Ceramic Disc Capacitor, 0.01 µF, 100 V, ± 20%, 5 mmVishay1Buy NowBuy Now
140 Pc. Jumper Wire Kit, 22 AWG, Solid, Assorted Lengths and ColorsTwin Industries1Buy NowBuy Now
Through Hole Resistor, 220 ohm, 400 mW, ± 1%Vishay1Buy NowBuy Now
Through Hole Resistor, 1 kohm, 500 mW, ± 1%TT ELECTRONICS / WELWYN2Buy NowBuy Now
Red LED, Through Hole, 5mm, 20 mA, 2.1 VLED TECHNOLOGY1Buy NowBuy Now
Tactile Switch, 12mm, Yellow, Top Actuated, Through Hole, Round Button, 24 VDC, 50mAOmron1Buy NowBuy Now
Tactile Switch, 12mm, Red, 12 VDC, 50mAMulticomp1Buy NowBuy Now
Additional Parts:
Product Name
Desktop Power Supply
  • tlc
  • e14presents_makerkaren
  • tactile switch
  • the learning circuit
  • 555 timer
  • led
  • hawkinselect
    hawkinselect over 2 years ago +3
    Fantastic demonstration of the internal workings of a 555 timer Karen. Great work!!! I've been kicking around the electronics industry for about 30 years and don't ever recall anyone giving such concise…
    jw0752 over 2 years ago +2
    If you don't believe DAB  just ask Bill:
    DAB over 2 years ago +1
    Good episode Karen.
    Just one nit, please do not poke around a circuit with a conductive screwdriver. Use a nonconductive stylus, pencil or straw anything that is non-conductive.
    I realize that you probably…
  • hawkinselect
    Fantastic demonstration of the internal workings of a 555 timer Karen. Great work!!! I've been kicking around the electronics industry for about 30 years and don't ever recall anyone giving such concise and professional example of the popular timer.
    As for the comments on the screwdriver, let's be realist people. The circuit was off. The circuit is very low voltage. The presenter is clearly a very intelligent person. Simply no harm done and it's not really an issue.
    Regards
    Darb.
    • Up +3 Down
    • Reply
  • makerkaren
    makerkaren over 2 years ago in reply to hawkinselect
    Thanks so much! That's my goal. To create a clear and concise resource to understand individual components.
    • Up 0 Down
    • Reply
  • makerkaren
    • Up 0 Down
    • Reply
  • hawkinselect
    hawkinselect over 2 years ago in reply to makerkaren
    No worries. Your efforts are definitely appreciated!
    • Up 0 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
