The Learning Circuit
  • The Learning Circuit
Documents How Thermistors Work -- The Learning Circuit 87
  • Date Created: 9 Mar 2021 4:02 PM Date Created
  • Last Updated Last Updated: 2 Dec 2020 8:24 AM
  • Views 2993 views
  • Comments 6 comments
element14 presents
The Learning Circuit | element14 presents |  Project Videos
In a previous episode, Karen talked about variable resistors, resistors that can change their resistance between 0 and an approximate maximum rating. In this video, Karen talks about a type of variable resistor that changes resistance in response to temperature changes  in its environment. Watch to find out the difference between NTC and PTC thermistors, and more.
  • the_learning_circuit
  • switching thermistor
  • ntc
  • linear
  • e14presents_karencorbeill
  • temperature fuse
  • ptc
  • temperature
  • thermistor
  • variable resistor
  • epoxy
  • non-linear
  • temperature coefficient
  • sensor
    DAB over 5 years ago +1
    Very good episode. I did not know about all of the various types of thermisters. DAB
  • gmiller40272
    gmiller40272 over 5 years ago +1
    In past 6 months, I had to back into learning about Thermocouple and Thermistors while trying to repair a 3-D Printer. Yes, it has been quite a learning experience. Six months ago, I thought they were…
  • miles90
    miles90 over 5 years ago +1
    A very interesting topic, once again. Really interesting things to know about. Thank you Karen.
  • gmiller40272
    In past 6 months, I had to back into learning about Thermocouple and Thermistors while trying to repair a 3-D Printer. Yes, it has been quite a learning experience. Six months ago, I thought they were interchangeable and discovered they are not. Two completely different approaches to measuring temperatures and in this case 55-130 degrees C for print heated bed. While the extruder Hot-End is typically 170-250 degrees C.
  • gmiller40272
