WorkBench Wednesdays
  • WorkBench Wednesdays
Documents DIY Solder-In Oscilloscope Probes - Workbench Wednesdays 50
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 2 Feb 2022 6:15 PM Date Created
  • Last Updated Last Updated: 9 Feb 2022 8:24 AM
  • Views 18423 views
  • Likes 9 likes
  • Comments 12 comments
When you cannot get an oscilloscope probe into a tight spot, can you just use a piece of wire? Sometimes. When signal integrity matters, you CAN use a low-cost DIY solder-in probe. These probes attenuate the signal and use an oscilloscope’s high-bandwidth 50-ohm input. James shows how to build some solder-in probes when they work and when they do not work in this video. Special thanks to Shabaz on the element14 community for the guide used here.
Supplemental Content:
  • Building Solderable In-Circuit Oscilloscope Probes by shabaz
  • DIY $10 Solder-in Oscilloscope Probe by Jan Cumps
Bill of Material:
RF / Coaxial Cable Assembly, SMA Plug to SMA Plug, RG174, 50 ohm, 3.3 ft, 1 m, Black MULTICOMP PRO 1 Buy Now
SMD Chip Resistor, 953 ohm, ± 1%, 125 mW, 0805 [2012 Metric], Thick Film, Precision PANASONIC  1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • Solder-in probe
  • oscilloscope probe
  • Resistive divider probe
    shabaz over 4 years ago +2
    Hi baldengineer Great video! Great work on the explanation and comparisons too, and it was very interesting to see the DIY probe traces along with the very nice! R&S active probe. I'm guessing coax…
    Jan Cumps over 4 years ago in reply to Jan Cumps +2
    … additional info: bandwidth is 100 MHz capacitive compensation is placed at the scope connector, so you can compensate when other options are mounted.
  • baldengineer
    baldengineer over 4 years ago in reply to shabaz +1
    Thanks! When I saw your post, I knew I wanted to build them. And I really liked your approach with the small "lump in the cable." So I'd like to revisit doing that in the future. I'll try out some other…
    Hi baldengineer
    I'm guessing coax suppleness impacts if the SMD resistor is feasible to directly attach or not, Incidentally, there's very thin (like 1.13mm) coax which I've never tried, but I'm wondering if maybe that could make that easier, although, your results were great with the PCB anyway, and it makes it easier to repair/maintain as you mentioned!
    Hi baldengineer
  • baldengineer
    Thanks!
    When I saw your post, I knew I wanted to build them. And I really liked your approach with the small "lump in the cable." So I'd like to revisit doing that in the future. I'll try out some other coaxes. (I just didn't have time to experiment much to meet the video deadlines.)
    I've toyed with the idea of making a small PCB to better transition between the coax and board. Something like a pad on top and bottom and then a pair of through-holes for the probe wires. But, for now, I really like these probes.
    Once I went to the protoboard, it literally only took minutes to build them. And I've been using them! :)
    Of course, now I want to build an active probe... j/k. Kinda.
