WorkBench Wednesdays
  • WorkBench Wednesdays
Documents DIY Solder-In Oscilloscope Probes - Workbench Wednesdays 50
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 2 Feb 2022 6:15 PM Date Created
  • Last Updated Last Updated: 9 Feb 2022 8:24 AM
  • Views 18420 views
  • Likes 9 likes
  • Comments 12 comments
When you cannot get an oscilloscope probe into a tight spot, can you just use a piece of wire? Sometimes. When signal integrity matters, you CAN use a low-cost DIY solder-in probe. These probes attenuate the signal and use an oscilloscope’s high-bandwidth 50-ohm input. James shows how to build some solder-in probes when they work and when they do not work in this video. Special thanks to Shabaz on the element14 community for the guide used here.
Supplemental Content:
  • Building Solderable In-Circuit Oscilloscope Probes by shabaz
  • DIY $10 Solder-in Oscilloscope Probe by Jan Cumps
Bill of Material:
RF / Coaxial Cable Assembly, SMA Plug to SMA Plug, RG174, 50 ohm, 3.3 ft, 1 m, Black MULTICOMP PRO 1 Buy Now
SMD Chip Resistor, 953 ohm, ± 1%, 125 mW, 0805 [2012 Metric], Thick Film, Precision PANASONIC  1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • Solder-in probe
  • oscilloscope probe
  • Resistive divider probe
    shabaz over 4 years ago +2
    Hi baldengineer Great video! Great work on the explanation and comparisons too, and it was very interesting to see the DIY probe traces along with the very nice! R&S active probe. I'm guessing coax…
    Jan Cumps over 4 years ago in reply to Jan Cumps +2
    … additional info: bandwidth is 100 MHz capacitive compensation is placed at the scope connector, so you can compensate when other options are mounted.
  • baldengineer
    baldengineer over 4 years ago in reply to shabaz +1
    Thanks! When I saw your post, I knew I wanted to build them. And I really liked your approach with the small "lump in the cable." So I'd like to revisit doing that in the future. I'll try out some other…
    There is a popular type of probes that opens up another avenue of options: the HP-9100.
    These are generics, sold by several companies under their brand name (bitscope, or like mine: Velleman).
    What's specific about them, is that you can remove the tip - just by pulling - and it exposes a coaxial connector:
    If only we find a fitting counterpart, this could turn into a probe that's easily customisable.
    Some measurements:
    • the coax is 300 Ω
    • the existing tip, in x10 mode, is almost 9 MΩ
    I'm working on an alternative alternative :). Just finished building this - a bit frankenstein, turns the probe in a solder-in one, without phusically altering it.
  • baldengineer
    baldengineer over 4 years ago in reply to Jan Cumps
    Yes! THIS is exactly what I pictured when I saw your picture. There are so many connections where a square-pin style header is good enough (and very quick to do.)
    Jan Cumps over 4 years ago in reply to baldengineer
    Here's my take on the design. Thanks for the inspiring Wednesday!
    … same measurement on the Arduino UNO crystal:
