WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Getting Started with the Grove System from SEEED Studio! - Workbench Wednesdays 62
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: cstanton
  • Date Created: 11 Oct 2022 1:13 PM Date Created
  • Last Updated Last Updated: 12 Oct 2022 7:24 AM
  • Views 188812 views
  • Comments 13 comments
In episode 62 of Workbench Wednesday, James takes a look at Seeed Studio’s Grove System! Which is a set of modules with specific sizes that connect together with simple cables. No soldering is required to add sensors or displays or many other devices to a microcontroller board. So specifically in this video, we look at several Grove modules and how they work with an Arduino and the Raspberry Pi!
Watch the Video
Supplemental Content
  • Information on the Grove Connectors for including in your projects
  • JST Manufacturer Page (Japan Solderless Terminal)
  • RoadTest for the Grove Inventor Kit and BBC micro:bit
Bill of Materials
Grove Beginner Kit Arduino Modules Uno Seeed Studio Buy Now
Grove Connector Pack (2.0mm 4-pin) Seeed Studio Buy Now
Lotus (Arduino + Base connectors) (This is M0+, not 328p) Seeed Studio Buy Now
Grove Cable, Buckled, 4 Pin, 30 cm, 5 PCs Pack Seeed Studio Buy Now
Base HAT Interface, Grove, 3.3 V in, Raspberry Pi, Digital/Analog/I2C/PWM/UART Port Seeed Studio Buy Now
Grove System Board, MS8607, Digital Pressure, Humidity and Temperature Sensor, I²C TE Connectivity Buy Now
element14 presents
element14 Presents  |  About James|  Workbench Wednesdays
  • temperature sensor
  • grove connector pack
  • seeed studio
  • digital pressure
  • ms8607
  • grove
    dougw over 3 years ago
    I really wish they had used a more standard connector. It has slowed my use of Grove modules. Maybe an adapter interconnect is an acceptable kludge.
  • ralphjy
    ralphjy over 3 years ago in reply to dougw
    Which connector would you have preferred?
    dougw over 3 years ago in reply to ralphjy
    Personally I like MTA connectors, but I can also get other 1" headers anywhere. When I first tried to get Grove connectors, I couldn't find a dimensions drawing or a source for PCB mount connectors. Now at least I know where to get them and documentation is available. But by the time I got it all figured out I had accumulated a stock of sensor modules that used .1" headers.
  • ralphjy
    Oh, okay.  I was just wondering.  I guess I got used to using JST connectors because Adafruit and Sparkfun use them and I have a lot of their boards.  And now there are a lot of Grove adapter boards and shields.
    The only real problem I've had with them is that there are two "standards" for the two pin JST connectors used for LiPo batteries.  Adafruit uses one +/- orientation in the housing and some RC toys reverse that connection.  Can make for some magic smoke if you buy the wrong battery type.
    I do have a box of adapter cables for the JST-PH (Grove, Stemma) and JST-SH (Stemma-QT,QWIIC) 4 pin connectors and also have the discrete sockets for breadboarding.  I'll admit that I've never tried to crimp pins to build my own cables.
  • ralphjy
    If you use all Grove parts, it works nicely together. I was designing PCBs that had a variety of sensors and peripherals and I wanted to stock standard headers to fit them all. Grove used an "oddball" connector that I didn't have in stock so it was tough to find reasons to use their sensors. At the time Grove didn't have as complete a set of sensors.
