WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Learn Three Ways You Can Create Bode Plots - Workbench Wednesdays 64
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 9 Nov 2022 6:10 PM Date Created
  • Last Updated Last Updated: 23 Nov 2022 8:24 AM
  • Views 23586 views
  • Comments 19 comments
Creating a bode plot from a simulation (or transfer function) is easy. But what if you want to create a bode plot for a REAL op-amp circuit or filter? One way is to measure a few parameters with an oscilloscope and function generator and then put those into a spreadsheet. Another is to use network analysis or frequency response analysis to do it automatically!
Watch the Video:
Supplemental Content:
  • Workbench Wednesdays 42: Compare Ideal vs. Real Filter with an LCR Meter
  • Workbench Wednesday 17: Instrument Basics: Function Generator
  • Workbench Wednesdays 54: How Oscilloscope Acquisition Modes Work
  • Workbench Wednesday 18: Digilent Analog Discovery Review
  • Workbench Wednesdays 49: Instrument Basics: Vector Network Analyzer (VNA) with PicoVNA
  • DC to Daylight 13: How Operational Amplifiers Work
  • The Learning Circuit 68: How Op Amps Work
  • Voltage Feedback Op-Amp Gain and Bandwidth App Note
Bill of Material:
LM358 - Audio TI 1 Buy Now
TL081 - JFET General Purpose, 4 MHz SOIC-8 ST Microelectronics 1 Buy Now
Bench Oscilloscope - 200 MHz, 1 GSa/s, 14-bit, AFG, DMM Multicomp Pro 1 Buy Now
[Bundle] Development Kit, Analog Discovery 2 Pro Bundle, 30MHz Oscilloscope, 12MHz Waveform Generator Digilent 1 Buy Now
MXO4 - 4 Channel Oscilloscope 200 MHz Rohde & Schwarz 1 Buy Now
element14 presents
element14 Presents  |  About James|  Workbench Wednesdays
  • bode plot
  • network analyzer
  • Network analysis
  • oscilloscope
  • function generator
  • frequency response analysis
  • FRA
  • scottiebabe
    scottiebabe over 3 years ago in reply to jc2048 +3
    I think BE just had bad luck with the intern/murphy . The TL081 spice model doesn't include any capacitance on its input, let alone the parasitic capacitance on a breadboard. Green: No cf, Red: Cf…
  • jc2048
    jc2048 over 3 years ago in reply to baldengineer +1
    Here's a possible theory you might test. The TL081 has a pair of offset pins which you appear to have left unconnected. As well as using them to adjust the offset, which you wouldn't need to worry about…
  • baldengineer
    baldengineer over 3 years ago in reply to scottiebabe +1
    Cool! My plan is to solder a duplicate circuit to a perfboard (with generous solder) and do the sweep/plot again when I talk about how to automate the measurement in python (for those that don’t have an…
  • scottiebabe
    I think the intern is playing a cruel joke on you, something isn't right there:
  • baldengineer
    I didn't pay the distortion much mind. 2.5 MHz into an LM358 in a breadboard while the oscilloscope is in averaging mode is going to get a funky waveform.
    Or, maybe averaging wasn't on in this case. I cannot remember if the MCP's FRA tool changes the acquisition settings. (I do not think it does.)
  • scottiebabe
    scottiebabe over 3 years ago in reply to baldengineer
    The output waveform shouldn't dance around. I think if you look at an FFT of the output, the amplitude of your test tone will be the correct amplitude. And, you will also see and there is also something else present. I don't know if its oscillating at a lower frequency...
    If you were to probe your op-amp's output with a 1x scope probe, the measured bode plot with gain peaking is entirely plausible. But, I am pretty sure you are using 10x probes.
    Still, I blame the intern Slight smile and great video!
    *had to delete to edit*
  • baldengineer
    On the LM358, there was peaking with X1 probes. The TL081 peaked with both X1 and X10.
    I'll give the output a little more scrutiny next time I'm in the lab. You have me curious about what I missed. I had several setups going on, so I might be mixing up scenarios.
  • baldengineer
