WorkBench Wednesdays
  • WorkBench Wednesdays
Documents How to Program Test Tools with Python - Workbench Wednesdays 66
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 28 Dec 2022 7:30 PM Date Created
  • Last Updated Last Updated: 14 Jun 2024 5:21 PM
  • Views 36452 views
  • Comments 57 comments
If your test tools have a USB or LAN port, there is a good chance that they support SCPI. Using pyVISA, you can write automated test programs for most equipment without expensive software. This video explains terms like VISA, SCPI, and USBTMC. Then it shows how to use Python and pyVISA to connect to test equipment with a Raspberry Pi (or any Linux computer.)
Watch the Video:
Bonus Content:
  • PyVISA
  • RsInstrument, R&S Python Implementation (also uses pyvisa!)
  • Keysight IO Suite
  • R&S VISA
  • Standard Commands for Programmable Instruments (SCPI) Syntax. (web archive mirror IVI Foundation)
  • SCPI Specification
  • Blog post, Early peak at bode plot script
  • Snapshot of Code
  • Github link for code
Bill of Material:
34465A Bench Multimeter, Truevolt, 6.5 digit Keysight 1 Buy Now
TL081 - JFET General Purpose, 4 MHz SOIC-8 ST Microelectronics 1 Buy Now
Bench Oscilloscope - 200 MHz, 1 GSa/s, 14-bit, AFG, DMM Multicomp Pro 1 Buy Now
MXO4 - 4 Channel Oscilloscope 200 MHz Rohde & Schwarz 1 Buy Now
HMC8043 Bench Power Supply, Programmable, 3 Output, 0 V, 32 V, 3 A Rohde & Schwarz 1 Buy Now
RPI400-KIT-US Raspberry Pi 400 Kit, BCM2711, Quad-Core, 64bit, ARM, Cortex-A72, US PSU, US Keyboard Layout Raspberry Pi 1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • Remote Programming
  • VXI
  • gpib
  • USBTMC
  • visa
  • lxi
  • IVI
  • scpi
  • baldengineer
    baldengineer over 2 years ago in reply to zack_el +3
    For some reason, posting these instructions here causes errors. You need to create a udev rule. Here's how to do it: www.baldengineer.com/accessing-usb-instruments-with-pyvisa-on-linux.html
  • mayermakes
    mayermakes over 3 years ago +1
    ohoh..I sense some automation i have to implement....
  • mayermakes
    mayermakes over 3 years ago in reply to baldengineer +1
    if anyone has a gripe with using a pi, I can warmly recommend doing it with a Beaglebone black. this also gave me the idea of maybe developing some sort of plug and play box with a pocketbeagle that reads…
  • zack_el
    zack_el over 2 years ago
    a excellent video. My goal is to program and control the Rigol DP832 DC power supply using a Raspberry Pi 5 and Python via the USB interface. This requires the NI-VISA driver. However, the driver could not be installed on the Raspberry Pi because it is not compatible with the ARM architecture. Now I am wondering how you managed to control your device via USB and LAN interfaces. Do you not need the NI-VISA driver for that?"
  • zack_el
  • baldengineer
    The DP832 does not require NI's VISA. None of Rigol's tools do. Any VISA driver can connect to to the DP832.
  • zack_el
    zack_el over 2 years ago in reply to baldengineer
    knowledge.ni.com/KnowledgeArticleDetails
  • zack_el
    zack_el over 2 years ago in reply to zack_el
    I was able to communicate with the RIGOL DL3021 using the RS232 interface and program it with the Raspberry Pi 5 and Python. Unfortunately, it does not work over the USB interface because the Raspberry Pi cannot identify the instrument.
  • baldengineer
    So keep in mind that a driver for the device and the "VISA driver" are separate things. The VISA driver talks to the OS drivers. So,if the OS cannot enumerate a device and provide a handle, then the VISA driver doesn't matter. So, this is not a NI-VISA issue.
    Regardless, I am fairly certain Rigol uses either a libusb-based interface or emulates a USB-Serial device when connected by USB for all of their devices. I have never encountered one that does not work with Linux.
    Compare the output of lsusb and what the pyvisa resource manager finds to verify what is getting enumerated.
    Also, the R&S VISA drivers work great on Raspberry Pi. I've found their driver worked slightly better than pyvisa-py, regardless of the vendor's instrument.
  • zack_el
    I tried to control both devices (DL3021 and DP832) via the USB interface, but I always receive the following error message:
    Exception: VisaIOError VI_ERROR_TMO (-1073807339): Timeout expired before operation completed. In the file "/home/pi/my_project/env/PowerSupply_test.py", line 15, in <module>
    print(supply.query("*IDN?"))
    ^^^^^^^^^^^^^^^^^^^^^ pyvisa.errors.VisaIOError: VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.image
  • baldengineer
    I cover multiple ways to can be solved in the video (timestamped):
    https://youtu.be/1HQxnz3P9P4?t=638
    First add a query delay and then second try changing the line terminators.
  • zack_el
    Unfortunately, this method does not work, or I have done something wrong!image
  • baldengineer
    Specifying a baud rate shouldn't matter since it is a VCP connection.
    Did you try just with the query delay?
    In general, you shouldn't need to change the line terminations on VCP connections, so you should only try that if adding a query delay alone doesn't help.
  • zack_el
    Yes, I have already tried that, but it doesn't work. I don't know what could be the reason. Is there another method?
  • baldengineer
    I think you're using the wrong resource string.
    This works for me on a DP831. Notice how my resource string includes USB0 and the serial number:
    Connect the DP832 by USB. What does this output show:
    import pyvisa
    rm = pyvisa.ResourceManager('@py')
    print(rm.list_resources())
    And what does the output of `lsusb` on the command line show?
    (Also if you press the Utility button on the DP832, it'll show you the USB resource string, in hex.)
