      • Japan
      • Vietnam
WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Slew Rate vs Rise Time measurements for Op Amps - Workbench Wednesdays 67
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 23 Jan 2023 9:31 PM Date Created
  • Last Updated Last Updated: 25 Jan 2023 8:24 AM
  • Views 26953 views
Slew rate shows how fast an operational amplifier can respond to an input signal’s change. The “slew rate limit” is an important consideration. However, when looking at some signals, only their rise time is specified. So then, are they the same? This video explains how slew rate and rise time are different AND how they are related using measurements in an op amp circuit.
Watch the Video:
Bonus Content:
  • USB PD - CC decoding adventures by wolfgangfriedrich
  • The Learning Circuit 68: How Op Amps Work
  • DC to Daylight 14: Explore Working Applications of 8 Different Op-Amp Circuits
  • Workbench Wednesdays 66: How to Program Test Tools with Python
  • Workbench Wednesdays 42: Compare Ideal vs. Real Filter with an LCR Mete
Bill of Material:
TL081 - JFET General Purpose, 4 MHz SOIC-8 ST Microelectronics 1 Buy Now
MXO4 - 4 Channel Oscilloscope 200 MHz Rohde & Schwarz 1 Buy Now
Arbitrary Waveform Generator - 2 Channel, 160 MHz Multicomp Pro 1 Buy Now
3786-C-36 Minigrabber, Hook to 4mm Double Plug, 914mm Pomona 1 Buy Now
HMC8043 Bench Power Supply, Programmable, 3 Output, 0 V, 32 V, 3 A Rohde & Schwarz 1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • rise time
  • Slew rate
  • op amp
  • operational amplifier
  • Slew rate limited
    dougw over 3 years ago +1
    The missing link.... RE: What’s an example of where you picked the wrong Op-Amp … and why?
    DAB over 3 years ago
    Good episode.
  • baldengineer
    baldengineer over 3 years ago in reply to DAB
    Thanks DAB!
  • baldengineer
    Thanks DAB!
