WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Instrument Basics: Electronic Loads -- Workbench Wednesdays 14
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: Matt
  • Date Created: 12 Sep 2019 1:09 AM Date Created
  • Last Updated Last Updated: 18 Sep 2019 7:24 AM
  • Views 5508 views
  • Likes 10 likes
  • Comments 7 comments
element14 Presents  |  Bald Engineer: James Lewis' VCP Profile |  Workbench Wednesdays
An Electronic load can sink current from power sources such as power supplies or batteries. Loads are useful to test a power supply’s design margin or verify a battery’s capacity. See how three different instrument options from ultra low-end to midrange to high-end compare. Learn how modes like constant current and constant resistance can be used for different measurements.
Supplemental Material:
  • How Does an Electronic Load Regulate It’s Input Voltage, Current, and Resistance?
  • Rohde & Schwarz NGM202 Power Supply Launch-Day Review
  • Programmable Electronic Load
  • Programmable DC Electronic Load - First Look
  • Project14's DIY Test Equipment: DIY Constant Current Load
  • A Transistor Load
  • A Simple DC Electronic load for the experimenter's Shop.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
Raspberry Pi 4Raspberry Pi1Buy NowBuy Now
TMC2208 SILENTSTEPSTICKTrinamic/Watterott2Buy NowBuy Now
SANYO DENKI Stepper Motor, Bipolar, 0.24 N-m, 1 A, Two Phase, 7.3 ohm, 5 mHSanyo Denki2Buy NowBuy Now
PRO SIGNAL Audio / Video Cable Assembly, HDMI A Plug to Micro HDMI D Plug, 6.6 ft, 2 m, BlackPro Signal2Buy NowBuy Now
CLIFF ELECTRONIC COMPONENTS HDMI Audio / Video Adaptor, HDMI Receptacle, HDMI Receptacle, FT SeriesCLIFF2Buy NowBuy Now
VERBATIM 3D Printer Filament, 1.75mm, PLA, SilverVerbatim1Buy NowBuy Now
official MAYER MOVES PSU: XP POWER AC/DC Power Supply, ITE, 2 Output, 60 W, 5 V, 7 A, 12 V, 3 AXP Power1Buy NowBuy Now
imagedc_electronic_load_application_note.pdf
  • constant current
  • constant voltage
  • e14presents_baldengineer
  • constant resistance
  • workbench wednesdays
  • digital resistor
  • workbench
  • electronic load
  • koudelad
    koudelad over 6 years ago +1
    Thank you for this introduction to electronic loads, baldengineer I never really used one for my hobby purposes, but the battery simulation on R&S load looks great.
    DAB over 6 years ago +1
    Nice overview. DAB
  • three-phase
    three-phase over 6 years ago +1
    Nice clear demonstration of the basic functionality of an electronic load. Thanks for posting. Kind regards.
  • genewu
    genewu over 4 years ago
    Hi,  Worth watching!
    By the way, Can I have a link for python code you mentioned in the video?
    Thank you.
  • baldengineer
    baldengineer over 4 years ago in reply to genewu
    Here's the script I used on the NGM202:
    import visa
    import time
    # exepcted resource string:
    default_resource = "TCPIP0::192.168.1.176::inst0::INSTR"
    def connect_to_inst():
        found = 0
        counter = 0
        for resource in resources:
            counter = counter + 1
            print(str(counter) + "] " + resource, end="")
            if (resource == default_resource):
                found = 1
                print(" <-- Using this one")
            else:
                print("")
        return found
    def set_resistance(r):
        inst.write("SOURce:RESistance " + str(r))
        print("Resistance is now: " + inst.query("RES?"))
        # add error handling later
        return
    # create the manager
    print("Checking available resources:")
    rm = visa.ResourceManager()
    resources = rm.list_resources()
    # check if the resource is available
    if (connect_to_inst() == 0):
        print("Resource not found, exiting.")
        rm.close()
        exit()
    # open the instrument
    print("Opening instrument...")
    inst = rm.open_resource(default_resource)
    print(inst.query("*IDN?"))
    # change resistance
    inst.write("INST OUT2") # select the channel
    inst.write("SOURce:CURRent 3")
    print("Current limit is now: " + inst.query("CURR?"))
    for index in range(100):
        print(index)
        set_resistance(100)
        time.sleep(0.6)
        set_resistance(10)
        time.sleep(0.3)
        set_resistance(50)
        time.sleep(0.1)
        set_resistance(5)
        time.sleep(0.1)
    print("Closing resource...")
    rm.close()
    You'll need PyVISA installed, a Visa driver, and to change the IP address.
  • baldengineer
    import visa
    import time
        found = 0
        counter = 0
                found = 1
            else:
                print("")
        return found
        return
        rm.close()
        exit()
    # change resistance
        print(index)
        set_resistance(100)
        time.sleep(0.6)
        set_resistance(10)
        time.sleep(0.3)
        set_resistance(50)
        time.sleep(0.1)
        set_resistance(5)
        time.sleep(0.1)
    rm.close()
