    Members
    • Avnet Boards Community
    • Choose Another Store
WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Workbench Wednesday 24: No-Contact Current Measurements
WorkBench Wednesdays requires membership for participation - click to join
  • Date Created: 28 May 2020 5:39 PM Date Created
  • Last Updated Last Updated: 19 Aug 2020 2:05 PM
  • Views 976 views
  • Comments 13 comments
element14 Presents  |  Bald Engineer: James Lewis' VCP Profile |  Workbench Wednesdays
One of the safest ways to measure current is with a clamp. Clamps do not require you to break the circuit and they safely measure wires with thousands of amps. In this video, we measure DC current in the lab, AC current of a reflow oven controller, and the DC current in a car using a Tenma 72-722672-7226 True RMS Clamp Meter.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
72-722672-7226 - Clamp Meter, Auto, True RMS, 600 A AC, 600 V AC, 600 V DC, 28 mm Jaw Opening Max.Tenma1Buy NowBuy Now
  • current clamp
  • ac current
  • clamp meter
  • baldengineer
    baldengineer over 2 years ago in reply to koudelad +3
    Hey David, for low currents, that is a good way to improve the overall measurement accuracy. I did not mention it in this video because I was focused on getting closer to the meter's maximum current.…
    jw0752 over 2 years ago +3
    Hi James,
    Your blog inspired me to run an experiment. I had in stock this current measuring board with a ACS712T ECL20 Chip on it.
    I cut a notch in a ferrite core that was just big enough to slip over the…
    Hi James,
    I purchased one of these meters from Newark and I have been quite happy with it. I have also found another use for it. Over the years my experiments have often involved magnets. Sometimes the…
    Hi James,
    Nice episode. I would think it would be relatively easy to build a centering bushing for the clamp.
    I assume that centering is only crucial for the DC current measurement, is this so?
    How do you think they are getting a DC current measurement? Perhaps integration of multiple Hall effect devices in the clamp?
    How did the meter do for accuracy below 1 Amp in the DC mode?
    • Reply
    Hi James,
    • Reply
  • baldengineer
    baldengineer over 2 years ago in reply to jw0752
    Hi John, here are my thoughts.
    As far as I knew, it should apply to both AC and DC. But I could be wrong.
    It's inhereint to the hall effect sensor works. It is just measure the strength of the magnetic field in the gap of the core.
    I haven't really used clamp meters for less than 1 amp. My guess would be, they aren't very effective.
    I have used the hall effect for my oscilloscope on stuff in the 100 mA to 1 A range. I know that below 10 mA, it the measurement gets into the noise floor of the probe.
    • Reply
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
