WorkBench Wednesdays
  • WorkBench Wednesdays
Documents UPS ESR Battery Measurements - Workbench Wednesdays 32
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: Matt
  • Date Created: 15 Dec 2020 6:19 PM Date Created
  • Last Updated Last Updated: 16 Dec 2020 8:24 AM
  • Views 3181 views
  • Comments 6 comments
As batteries age, their ESR goes up. Eventually, they will no longer be serviceable. A battery measurement tool like the Hioki BT3554 lets field service technicians monitor the help of batteries over time. In this video, see how it can be used to measure a live UPS battery.
Supplemental Content:
  • The effect of a BMS when measuring LIBs
  • Digital Pure Sine Wave Uninterruptible Power Supply (UPS) Reference Design
  • Hioki BT3554 RoadTest (see James' review in the "Video Review" tab)
Bill of Materials
Product Name Manufacturer Quantity Buy Now
Battery Tester, 6V & 60V, 3 mOhm to 3 Ohm, with Angled Pin type Lead L2020 & Bluetooth Technology Hioki 1 Buy Now
Workbench Wednesday
element14 presents  |  About James |  Workbench Wednesdays
  • ups
  • battery esr
  • workbench_wednesdays
  • e14presents_baldengineer
  • uninterruptible power supply
  • battery measurements
  • hioki tester
    DAB over 5 years ago +1
    Good episode James. I had not thought of using that meter for a battery back up system. I picked up a dead one at a garage sale for a buck. The batteries were toast, but I figured that there were enough…
  • baldengineer
    baldengineer over 5 years ago in reply to DAB +1
    The commercial-grade UPSes I use (whatever Amazon or Staples sells) tend to last in the range of 3-5 years. I do buy brand new UPS units when the batteries die because the newer ones are usually quieter…
  • baldengineer
    baldengineer over 5 years ago in reply to koudelad +1
    koudelad wrote: PS: I missed the usual intro... Hmm. I have been trying to shorten the intro to "get to the point" faster. but maybe I can at least bring "Welcome Back..." back.
  • koudelad
    koudelad over 5 years ago
    Thank you for showing this interesting instrument. I haven't seen it in action before.
    I recently measured a capacity of 3 pieces of a 12 V 8 Ah batteries (which are used in a small 300 W / 500 VA UPS) using a bench power supply for charging and electronic load for discharging. The total time was between 10 to 24 hours for each battery. This battery tester can be a huge time saver. However, I have no idea, whether modern UPS have some monitoring circuitry to tell when to change the battery due to a high ESR / low capacity. In that case it would be hard to justify the cost.
    If it can be used on other chemistry types like NiCd, NiMH and Lithium cells, it makes more sense to buy it for someone working with rechargeable batteries on daily basis.
  • baldengineer
    Hmm. I have been trying to shorten the intro to "get to the point" faster. but maybe I can at least bring "Welcome Back..." back. image
  • koudelad
    koudelad over 5 years ago in reply to baldengineer
    For me is the usual 10-15 minutes format OK, you always try to explain not only a specific device/component, but many important things around, which is great. I also sometimes rewind when you are explaining faster than I am able to process.
    No need to worry, you are still thousand times "faster" then some of the 45-minute EEVblog videos where people complain that it could be said in two sentences.
  • baldengineer
    Thank you David, I appreciate the feedback.
  • baldengineer
