    Members
    • Avnet Boards Community
    • Choose Another Store
Merry Boxes & LEDs
  • Merry Boxes & LEDs
Merry Boxes & LEDs
Blog 2D xmas tree pcb art (components INSIDE the pcb)
Merry Boxes & LEDs requires membership for participation - click to join
Blog Post Actions
  • Subscribe by email
  • Author Author: designer2k2
  • Date Created: 5 Jan 2019 8:49 AM Date Created
  • Views 458 views
  • Likes 13 likes
  • Comments 15 comments
  • gimp
  • kicad
  • merryboxesledsch
  • xmas 2018
  • pcblayout
  • github
  • holidayspecial19ch
  • xmas lights
  • xmas_tree
  • inkscape
  • github_repository
designer2k2
designer2k2
5 Jan 2019
Merry Boxes & LEDs
Enter Your Project for a chance to win a Maker Tool Kit, an Oscilloscope Grand Prize for the project that brings the Most Joy to the Heart, and Gift to Gives!
Back to The Project14 homepage
Project14 Home
Monthly Themes
Monthly Theme Poll
Hello,
my xmas gift this year, a 10x10cm pcb xmas tree
2D xmas tree animation
all the components are inside the pcb, the overall height is only 1.6mm
Castellation is used to make the connections:
CastellationCastellation with pcb
The pcb itself is using pcb art technique to give the shape of a tree covered in snow and some snowflakes and ball ornaments.
To help making the programm for the ATtiny a helper website is made to make the led addressing easier:
https://designer2k2.github.io/2d-xmas-tree/
xmas tree programming website example
All files including the KiCad project is hosted on GitHub: https://github.com/designer2k2/2d-xmas-tree
And to help with assembly a video: (in german, with english captions, turn them on)
    genebren over 3 years ago in reply to ntewinkel +5
    Nico,
    The price points on microscopes (stereo included) are all over the map.  There are toy-like models (very cheap optics) available for under $100.  There are inexpensive models available for $200 - $300…
  • designer2k2
    designer2k2 over 3 years ago in reply to dubbie +5
    Yes they are not cheap, this is the exact scope i have: https://www.ebay.de/itm/SB-1902-U-Euromex-StereoBlue-Bino-Zoom-Stereo-Blue-Schwenkarm-Mikroskop/231551764715  with the 0,5mm Barlow addon lens to…
  • designer2k2
    designer2k2 over 3 years ago in reply to dubbie +4
    thanks!
    Yes, i consider myself a hobbyist, and have done all that at home
    I use a stereo zoom (trinocular) microscope with a boom stand holding it over the workbench.  The video above was mostly shot trough…
  • designer2k2
    thanks
    • Up +2 Down
    • Reply
  • danielw
    danielw over 3 years ago
    Nice work on the soldering.  I love a bit of PCB Art!
    • Up +3 Down
    • Reply
  • designer2k2
    designer2k2 over 3 years ago in reply to luislabmo
    thanks!
    • Up +1 Down
    • Reply
  • luislabmo
    luislabmo over 3 years ago
    Nice looking project!. Well done!
    Luis
    • Up +2 Down
    • Reply
  • designer2k2
    Yes they are not cheap, this is the exact scope i have: https://www.ebay.de/itm/SB-1902-U-Euromex-StereoBlue-Bino-Zoom-Stereo-Blue-Schwenkarm-Mikroskop/231551764715  with the 0,5mm Barlow addon lens to get 160mm working distance.
    Its a bit modded with some 3d printed parts, for example a adapter to hold ikea lights: https://www.designer2k2.at/en/mods/elektronik/130-3d-printed-microscope-light-adapter-for-ikea-jansjoe
    (cheap and the most flexible light you can get)
    But its well worth it, and with some patience there are sometimes used scopes around (but most people never sell them again...)
    Basically you are looking for a stereo zoom microskope with around 0,7 - 4,5 magnification and 10x/20mm oculars and 100mm working distance. That results in a magnification from 7-45.  Then you attach a x0.5 lens and your working distance increases to around 150-160mm and your magnification drops to ~3-25  (thats not so exactly 0.5).
    In the video above you can see what this results in terms of field of view. It goes nice wide but can also zoom in to a single solder point. Where the 160mm distance gives a lot of room to solder.
    And if needed, unscrew the 0,5 and you have a very high magnification, usable for inspection of very fine details.
    There are some extensive discussion out there on what scope and so on, nearly every big brand has one with about exactly the specs from above.
    The only thing i cannot recommend are this USB-Webcam-Display things, i had one, there is no improvement against a magnification lens on a 3rd arm, it just looks fancy.   If, then you want to go for the stereo thing
    • Up +5 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
