Wireless Protocol III: Near Field Communication (NFC)
The element14 ESSENTIALS of Near Field Communication (NFC) cover the fundamentals of NFC, including features, operating modes, applications, and key use cases. To extend the knowledge covered in the main module, this supplementary guide discusses the types of related components or development boards available for prototyping new products or building projects.
Integrated Components
The NT3H2111W0FHKH is an NTAG I2C plus reader in an XQFN-8 package, combining a passive NFC interface with a contact I2C interface. It's designed for entry-level NFC in home-automation and consumer applications. As the second generation of NXP's connected-tag technology, these devices maintain full backward compatibility with first-generation NTAG I2C products, while adding new, advanced features for password protection, full memory-access configuration from both interfaces, and an originality signature for protection against cloning.
NT3H2211W0FHKH - NFC Forum Type 2 Tag Compliant IC, 13.56 MHz, Reader, 40 mA, 0.7 V to 3.6 V input, XQFN-8
Buy NowBuy Now
The NT3H2211W0FHKH is an NFC Forum Type 2 Tag Compliant Reader IC in an XQFN-8 package. This NTAG I2C plus device combines a passive NFC interface with a contact I2C interface.
Maintains full backward compatibility with first-generation NTAG I2C |
PN7150B0HN/C11002YPN7150B0HN/C11002Y - RFID IC, 13.56 MHz, NFC Controller, Read, Write, FeliCa PCD Mode, 1.65 V to 1.95 V supply, HVQFN-40
Buy NowBuy Now
The PN7150B0HN/C11002YPN7150B0HN/C11002Y is a NFC Read/Write Controller in an HVQFN-40 package. The PN7150 is a full NFC controller with integrated firmware and NCI interface designed for contactless communication at 13.56 MHz. It is designed for integrating NFC technology into any application, especially those running Linux and Android. The contactless front-end design brings a major performance step-up, with on one hand a higher sensitivity and on the other hand the capability to work in active load modulation communication enabling the support of small form factor antennae.
Development Boards
OM23221ARD Antenna Board, NTAG I2C plus, NFC Forum Type 2 Tag, I2C Interface, Arduino Pinout
Buy NowBuy Now
The NTAG I2C plus kit is suitable for any boards featuring an Arduino-compatible header, including LPCXpresso, Kinetis, and i.MX boards. It is designed to emulate using an NTAG I2C plus tag chip in an embedded electronic system. The NTAG I2C plus antenna board is mounted on an adapter board with an Arduino-compatible header.
Bluetooth pairing example based on NXP KW41Z Library for NTAG I2C plus available through MCUXpresso for FRDM-KW41ZFRDM-KW41Z Connectivity to any device with Arduino pinout such as NXP Freedom board family (Kinetis) |
OM5578/PN7150ARDM - Evaluation Board, PN7150S NFC Controller Board, Arduino Interface Board, NFC sample card
Buy NowBuy Now
The OM5578/PN7150ARDOM5578/PN7150ARD kit is a high performance, fully NFC-compliant expansion board compatible with Arduino Compatible Interface platforms.
The OM5578/PN7150BBBOM5578/PN7150BBB is a PN7150 NFC controller Single Board Computer (SBC) kit with a BeagleBone Black interface board. It enables the development of an NFC solution based on PN7150 in a Linux, Android or Windows for IoT environment or in a system based on RTOS, or without OS. It meets compliance with Reader mode, P2P mode and card emulation mode standards and supports NFC forum type 1/2/3/4/5 tags. The board features an integrated high performance RF antenna to ensure a high interoperability level with NFC devices. It also provides high RF output power with up to 4.75V, 180mA, as well as low power modes for portable devices.
OM5578/PN7150RPIM -Demonstration Kit, PN7150S NFC Controller Board, Raspberry Pi Interface Board, NFC sample card
Buy NowBuy Now
The OM5578/PN7150RPIM kit is a high performance, fully NFC-compliant expansion board for Raspberry Pi. It meets compliance with Reader mode, P2P mode and Card emulation mode standards. The board features an integrated high performance RF antenna to insure high interoperability level with NFC devices. The kit is comprised of an OM5578/PN7150S NFC Controller Board, an OM29110RPI Raspberry Pi Interface Board, and an NFC sample card.
OM27462CDKP - Development Kit, PN7462 NFC Controller, NFC Cockpit Compatible, EMVco Development
Buy NowBuy Now
The OM27462CDKP is a flexible and easy to use controller development kit for the PN7462 family. It contains a PNEV7462C board, fully supported by the NFC Cockpit and the NFC Reader Library, with a 65x65mm2 antenna optimized for EMVCo applications and a 30x50 mm2 antenna optimized for Access Management applications. The kit comes with a multitude of application examples in source code to begin software development.
OM5569/NT322ERM - Development Kit, NTAG I2C plus, Energy Harvesting Connected Tag, NFC Interfaces
Buy NowBuy Now
The NTAG I2C plus Explorer Kit is an all-in-one demonstration and development resource for NFC-connected tags. Designed to emulate using an NTAG I2C plus tag chip in an embedded electronic system, the kit centers around a multi-purpose microprocessor-based development/demo board, and includes a full complement of hardware and software tools to support investigation of the NTAG I2C chip operation, the NFC RF communication link, and the I2C serial bus connected link. This kit includes all components of OM5569-NT322E and on top an NFC reader.
*Trademark. NXP is a trademark of NXP Corp. Other logos, product and/or company names may be trademarks of their respective owners.
