    Members
    • Avnet Boards Community
    • Choose Another Store
14rhb's blog Software Defined Radio (SDR) - My First Design
  • Blogs
Blog Post Actions
  • Subscribe by email
  • Author Author: 14rhb
  • Date Created: 3 Feb 2019 5:51 PM Date Created
  • Views 474 views
  • Likes 16 likes
  • Comments 20 comments
  • fm radio
  • rfradiofrequencych
  • gnu radio
  • software defined radio
  • sdr
  • nooelec
14rhb
14rhb
3 Feb 2019
This is a quick blog post about using my NooElec SDR for the first time.
Back last year I was luckily chosen to roadtest three Molex Antennas Molex 2.4GHz / 5GHz Antenna Kit - Review  and that re-kindled my interest in RF work at home. Wanted to have a 'play around' I bought myself a low-cost SDR for fun and it arrived today. It cost me just over £20 (UK) and plugs into the USB port of my computer plus it has a SMA connector for the antenna. I actually made a misjudgment and bought the basic unit before realising I didn't really have the bits to make a decent antenna but I have many plans to address that.
I initially ran this on my Linux machine - having downloaded the drivers and installed rtl-sdr and another package called Gqrx. That all ran really well and with a basic wire antenna I was able to tune to local FM radio stations and hear the music etc.
I then tried using the SDR with my Windows 10 laptop and installed the software described on the NooElec website called CubeSDR. That too was fun and I was able to scan the airwaves - looking at the signals in the frequency domain. The Digital Audio Broadcast (DAB) band looked particularly regimented - as shown below:
That was all fun but the SDR was being configured using the software and I had also read an article that mentioned I could make my own designs using the GNU Radio software.
I downloaded and installed that from their website and was met with a very interesting window....it then dawned on me how great this software was. I was going to be able to draw out the various block parts of my receiver to do exactly as I wanted. As a newbie I was going to struggle and so followed a useful online article https://www.instructables.com/id/RTL-SDR-FM-radio-receiver-with-GNU-Radio-Companion/  and, after some tweaks, I ended up with this:
And even using an out-of-band antenna (the Molex 433MHz from my kit) I was able to demodulate and hear a local radio station on my PC's speakers
All I can say is, I'm now hooked. I need a decent outside antenna (or two ) and a few connectors /cable length.
Browsing around at what I can pick up threw up some interesting links; apparently I can even receive the meteorological photos from an orbiting weather satellite. This needs a bespoke antenna but the design looks quite simple.
Rod
  • neuromodulator
    neuromodulator over 3 years ago +8
    I've played a bit with it... Its fun stuff... With the right antennas and equipment you can get weather sat images. There are many interesting things that are being transmited in air waves. For instance…
    shabaz over 3 years ago in reply to 14rhb +6
    Hi Rod,
    Great idea! Looking forward to seeing it.
    By coincidence I started some work on an RF amp recently, although it's hard finding time to finish.. It is to be a 1W amp, intended for transmit. I've only…
    shabaz over 3 years ago +5
    Hi Rod,
    Great to see your radio experiments!
    It is really addictive, and so much to explore - I can see why radio hams enjoy their hobby.
    Hi Rod,
    • Up +5 Down
    • Reply
    Hi Rod,
    • Up +5 Down
    • Reply
  • 14rhb
    14rhb over 3 years ago in reply to shabaz
    Hi Shabaz,
    Your recent article on Minicircuits also helped get me interested in this area again. I'd like to follow your article to make a head-amplifier in the bands I decide to look closely at.
    Rod
    • Up +5 Down
    • Reply
    Hi Rod,
    By coincidence I started some work on an RF amp recently, although it's hard finding time to finish.. It is to be a 1W amp, intended for transmit. I've only partially laid out the PCB.
    If you want to look at one for ideas (good or bad - this one didn't quite meet the spec!), I have a spare PCB and bits for this one, which I built a few years ago - this one is low-power, intended as a preamp):
    It uses MGA-30889 (obsolete now, but I still have a few of those).
    I've almost used up all the PCBs, but if you send me your address in a private message, I can spare one if you want it, plus the bits to be soldered on.
    If you're comfortable soldering 0402 sized then I can mail the bits, otherwise I can assemble it if you like.
    It was flat from 100MHz to 2GHz, although with better layout it should have reached 2.6GHz according to the MGA-30889 datasheet.
    • Up +6 Down
    • Reply
  • 14rhb
    Very impressive - that is a quality output at only 1dB variance.
    Thank you for your really helpful offer, PM on its way.
    Rod
    • Up +2 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
