CDU TYPE 813H-1 / Number 792-6301-001 |
![]() for a better view please see E14/NexGen:Componets/CDU:813H/images/CloseUPfrontview.png |
FAA-RD-79-1 - FAA-RD-79-2 - 3D/4D AREA NAVIGATION SYSTEM DESIGN, DEVELOPMENT, AND IMPLEMENTATION -> -1 information on operations of 813-1 CDU are covered in Sections 2, 3.3.x, 4.3.x -> -2 contains the listing of the flight plan editor. I think this is written in AGOL -ch |
N76-11072 / CR-137704 - RNAV Noise Abatement Approach System Interface Wiring for the DC-8-61 Aircraft Wiring information on 813-1 CDU is covered on pages 119-134 Installation Drawings Appendix 6 pages 192 -197 |
Inboard I/O Connector DL60H-20-41PN |
Outboard Test Connector DBC50H-20-41SN |
| A29 | A29P3 | |
5. Line Alpha IN 6. Line Bravo IN 11. Day / Night Select 17. Index 20. Ground 23. CDU Valid 26. 5VAC 400Hz 12Wmax 27. 5VAC RTN 28., 115VAC 400Hz 25Wmax 29. 115VAC RTN 30. Chassis Ground 38. Line Alpha OUT 39. Line Bravo OUT 40. Faults Control |
G HOR POS CLK (ATE) e Y (ATE) d 88Hz (ATE) J RCVR CLK (ATE) b 1 Hz (ATE) F ΔX (ATE) A CATH (ATE) R +30VDC (ATE) U -12VDC (ATE) M INTLK 2 W -30VDC (ATE) |
K KEY DATA (ATE) f DISPLAY DATA (ATE) c X (ATE) E ΔY (ATE) H LM DATA (ATE) Y I/O CLOCK (ATE) D HV MON Z PHASE 2 (ATE) B 55V CONT (ATE) a VIDEO (ATE) C GRID #1 (ATE) X +55VDC (ATE) N +5VDC (ATE) V -15VDC (ATE) T +15VDC (ATE) S +500VDC (ATE) L P +5VDC (ATE) |
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
Comment-
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
