      • Japan
      • Vietnam
NexGen Flight Simuator NexGen: The Lab: Found More Test Equipment: SMD Rework Station 853D
  • Author Author: phoenixcomm
  • Date Created: 5 Feb 2021 11:31 PM Date Created
  • Views 803 views
  • flight simulator
  • nexgen
  • smd hot air station
  • my lab
  • yihua 853d
phoenixcomm
phoenixcomm
5 Feb 2021
This unit is most likely made by YIHUA.  The 853D is broken down into three functional blocks.image
  1. SMD Rework Wand. This has a digital temperature control and has interchangeable tips. image
  2. Solder Station Wand. This has a digital temperature control and it is removable via a 5-pin Din Plug. (I intend to buy a solder removal gun with vacuum)
  3. Power Supply (0-15vdc) with Digital Voltage Readout but set with a potentiometer. It also has an analog current meter.
  4. The Test Switch has two positions:
    1. The Test position is a  misnomer as in the Test position you can now use it as a DVM (volts only).
    2. Normal Power Supply output.
Pinouts on ProsKit 33-331 Gun
between pins
1 & 2
500 ohms @
  room temp.
Heating Element
3 & 4
25 ohms @
  room temp.
Trigger
5 & 6
0 ohms
Trigger ON
Shaking Gun
7 & 2
0 ohms
Shaking Gun
Armed with this info it looks like the adapter will be cake.
I will also relocate the main power switch from the rear to the front.
Coupler for Gun to 853D Description
853DSS-332Adapter / Stand
Thermocouple +11n/a
Thermocouple -22
n/a
Heater33
Solid State Relay
Heater Pass through
Heater44
Ground2n/a
Trigger5
Triggers SS relay
normal relay for Vacuum.
Trigger6
Shaking7turn on/off SS Relay
Shaking2
Note the picture of the ProsKit Gun and the Rework Station are images from the net.
    DAB over 4 years ago +1
    I am just not set up for working with these ity-bity components. DAB
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to DAB +1
    DAB Dab, Me neither but I have a stereo 10x inspection microscope without a stand its nice for hand-holding. but when I get some more money I will get the unsoldering gun and that's what I really will…
  • phoenixcomm
    DAB Dab, Me neither but I have a stereo 10x inspection microscope without a stand its nice for hand-holding. but when I get some more money I will get the unsoldering gun and that's what I really will use this for. Plus removal and soldering SMD components.  Its a pain to use the plunger thing to unsolder multi-layer boards. I have used the PACE system before and it is really nice but lots of $$$$$. And I can always use the hot air wand for heat shrink tubing. image This saves me from breaking out my Big Red Heat Gun.
    ~~Cris
  • phoenixcomm
    ~~Cris
