Ok this is more of a bather than a post. Buckle up the ride will not be smooth! The US National Highway Traffic Safety Administration (NHTSA) in April 8, 2005 said it should be on all cars by 2008 and now trucks.. ok thats cool. Commercial Aircraft have had them for years BC (Before Cars) .. But in between those 2 camps there is a huge Black Hole. Whatever you wish to call the tires, ie: rubber, skins, sneakers, and others. Tires are the most ignored, or understood part of your plane.
Your cars tires life is pretty easy compared to an aircraft tire. You could use your car's tires to take off.. But landing is a whole nother kettle of fish. You, that is your wheels hit the runway at 70 to 200 knots. Try this stunt with car tires and they will shred. And then you most likely will die. Game over. No do overs. Why is this you ask? Well it has to do with several factors: strong centrifugal forces, and Traction Waves. Every time you land your tires distort. The forces on a Boeing 747 is about 6,000G. This has to do with the weight of the plane and the speed that you touch down.. Even a light aircraft landing at 100kn you tires will take a wallop.
Analysis: Ok now what do we need? Ok lets use a car's TPMS as a model.
- We need the sensor in the tire with a transponder.. The data that we need and would like to capture:
- Tire Pressure.. most of the damage is to under inflation.
- Tire Temperature..
- Tire mounted accelerometers to generate X and Y This tell you the amount of defection in the tire.
- We need a rf receiver at 428Mhz to acquire the data
- We need a rf transmitter near each wheel sending 127Khz to be the initiator.
- The receiver should send data to the embedded microprocessor via a bus, ie. CAN, TCPIP etc.
- The display system and master caution will receive its data from the embedded microprocessor via a bus.
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
Comment-
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
