    Members
    • Avnet Boards Community
    • Choose Another Store
Feedback and Support
F&S Forum Replies to STEM page in Members does not seem to show on homepage, member home page
200 X-Frame-Options: SAMEORIGIN X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Sat, 04 Feb 2023 16:04:20 GMT ETag: "0x8DAFE608C13CA34" Set-Cookie: .te.csrf=j8Pjlm0bdj4sZbbUbXEnNFi6XWuFWZk4uKDjMsjV_qI; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=MqUP3czGhLHFNUjR1kGi%2fvz1mEkGYRxfIRInok1Yjg290VMWdoofv6FUD%2bGg4Hc9KVMh7k6uOyiz4JCRjCXniGV%2f5nUs5v0RH1MARwpOkLDU1oDscrYU1aQ9%2b%2ftE3KKL2KoA6UaYU4WEIrxWHvfXIMvlae45XxFcTJwu%2f95PPhd9aUpA12kqc8y87ff5%2bOfy0hqHn6cOQ6qC%2bSGyVr6ZRFlHsZ53O2FzkMjkbdMDUoeTuFg7L6GKmo32pF4THxACJgOrBSyPkxVdiEHkGIdj%2bA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=20 Server-Timing: origin; dur=29 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 13 subscribers
  • Views 828 views
  • Report Bug
Jan Cumps
Jan Cumps 1 month ago
Comments made to this page: The Gift Of STEM - STEM Group Kit Give away!, created by @e14phil (<- also: does not resolve) do not generate entries on home page, members home page or the search pages.
the e14phil  only resolves if I first publish this bug, then edit it. But that's not the reason to raise this report.
Phil's announcement is only found if you know it exists (in members -> Documents; searching only returns it if you know what the subject is, and search for some words in the title), and replies are not on the home page, not even when you drill to the Documents tab:
  • cstanton
    cstanton 1 month ago +1 suggested
    Hi Jan Cumps , Comments and replies do not cause posts on the homepage to 'bump' or 'appear' because it isn't Verint's activity feed. The widget on the homepage only shows the originating content when…
  • cstanton
    cstanton 1 month ago in reply to Jan Cumps +1
    Jan Cumps said: People do not see traffic That's definitely a broader problem. Members have to subscribe to notifications, and if you default opt people into that, there are complaints that they're…
  • cstanton
    0 cstanton 1 month ago
    Hi Jan Cumps ,
    Comments and replies do not cause posts on the homepage to 'bump' or 'appear' because it isn't Verint's activity feed. The widget on the homepage only shows the originating content when it's published. Because that giveaway was created 29th of November, I wouldn't expect it to show on the homepage in December as that's not how the widget works.
    0 Jan Cumps 1 month ago in reply to cstanton
    People do not see traffic, Christopher. What's the point of joining a community if your post goes to /dev/null ?
    That reply is root of the demise.
  • Andrew J
    0 Andrew J 1 month ago in reply to Jan Cumps
    Apparently work is going on to make the front page contain ‘recent activity’ rather than content by publish date.  Obviously I don’t know what the priority it is except that site stability has been determined to be more important to get right.  On current trend, we may not see the change for quite some time - even this morning it’s been flakey.
  • cstanton
    0 cstanton 1 month ago in reply to Jan Cumps
    Members have to subscribe to notifications, and if you default opt people into that, there are complaints that they're receiving too many messages.
    Though pages should also show at a glance the activity that's going on with the site, another design flaw of the platform is that it favours silo'd activity within groups, rather than across groups (Jive also had this problem, people also had to join groups on Jive.
    I've asked the development team if they can be more transparent with their roadmap and timeline on what they have coming up, and the information they provide in releases (there used to be regular blog posts with each release).
    I understand the frustration on this, and no one wants their efforts to seemingly go to waste. The frustration with the platform from management with the platform vendor has been similarly palpable.
    I've waited from 8 to 9 am to now (11.30) to be able to interact with the site. I'm right there with you on this.
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
  • Twitter
