I tried by making new blog but same problem remains there
Hi abhishek2018 ,
I can see that there's a problem here with the image gallery that you have embedded under 'Unboxing'.
Having looked at the blog post in question, and edited the blog post, I can see that the problem resides with how the image gallery has been put together.
When you insert an image gallery, it has placeholder text that you must replace.
This starts with "Replace this with your image" where you insert the image, but then you must also replace the following text that is underneath it:
"IMAGE TITLE: THEN IMAGE DESCRIPTION"
In the image gallery you inserted, you do not have an image title, and image description after each image.
I have edited your blog post and inserted an image gallery table with this information and you should now be able to see that the image gallery renders properly.
Please go through your inserted image galleries and ensure this information is there and replaced with what you want it to say.
Thanks lot Christopher for the help and till date, I was blindly removing both and uploading but getting the desired gallery.
Now I would insert as it should be.
