    Members
    • Avnet Boards Community
    • Choose Another Store
Arduino Forum Arduino
Arduino requires membership for participation - click to join
  • Replies 7 replies
  • Subscribers 119 subscribers
  • Views 513 views
electronerd616
electronerd616 2 months ago
I started to learn arduino code not too long ago and I started this project where with a press of a button I can change the numbers on a 7-segment display, at the moment I got to the point of turning on a number with a button but I don't know how to latch the number as well as having a latch counter so the arduino could count the amount of times the button has been pushed in order output the corresponding number.
  • Reply
    Jan Cumps 2 months ago in reply to Andrew J +2
    It shows your blog's source
  • Andrew J
    Andrew J 2 months ago +1
    Can you post your code so far.
  • electronerd616
    electronerd616 2 months ago +1
  • Andrew J
    0 Andrew J 2 months ago
    • Up +1 Down
    • Reply
  • electronerd616
    0 electronerd616 2 months ago
    • Up +1 Down
    • Reply
  • Andrew J
    0 Andrew J 2 months ago in reply to electronerd616
    That's not going to work for someone to help you and it's not all the code Grinning .  The best thing to do is to highlight all the code in the Arduino IDE, copy it, and then paste it into a reply here.  When you've pasted it, select it all and using the Tools drop down at the bottom of the reply box, select Source Code, as shown below.  That should format it to make it easy to read.  TBH, I've not tried adding source code to a reply so I assume that will work: try and play around with it if not.  Anyway, the idea is that we get the code not a screenshot!
    • Up 0 Down
    • Reply
  • javagoza
    0 javagoza 2 months ago in reply to Andrew J
    For inserting source code use Insert/ </> Code option
    void setup() {
      // put your setup code here, to run once:
    void loop() {
      // put your main code here, to run repeatedly:
    • Up +1 Down
    • Reply
  • Andrew J
    0 Andrew J 2 months ago in reply to javagoza
    What does the option I show do?
    • Up 0 Down
    • Reply
    0 Jan Cumps 2 months ago in reply to Andrew J
    • Up +2 Down
    • Reply
  • Andrew J
    0 Andrew J 2 months ago in reply to Jan Cumps
    Ah!
    • Up 0 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
