Avnet Boards General Ultra96 JTAG/UART Pod step file
  • Replies 7 replies
  • Subscribers 357 subscribers
  • Views 712 views
  • zedboardcmty
mindaugas
mindaugas over 5 years ago
I wanted to ask is it possible to get Ultra96 JTAG/UART Pod step file? I want to connect pod to ultra96 board and put in custom enclosure. It would be really nice to have step file when designing enclosure. Thank you
  • drozwood90
    drozwood90 over 5 years ago +1
    Hi there, Probably not, but if you make contact with your local FAE, we can investigate further. --Dan
  • narrucmot
    narrucmot over 5 years ago +1
    There is a mechanical drawing and step models for the Ultra96-V2 here: https://www.element14.com/community/community/designcenter/zedboardcommunity/ultra96#e14tab3 8741.contentimage_192080.png Hopefully…
  • drozwood90
    Hi there,
    --Dan
  • narrucmot
    Hopefully this will get you close to what you need.
    --Tom
  • mindaugas
    Thank you for replies. drozwood90 could you please guide me how to contact my local FAE? I only found general contacts in Avnet website.
  • drozwood90
    drozwood90 over 5 years ago in reply to mindaugas
    Hi there,
    We are working on getting the files posted, but there seems to be an error in the webpages and that can take time to get corrected.
    The easiest way that I would suggest locating your local FAE is to pop in to here:
    https://www.avnet.com/wps/portal/us/about-avnet/locations/
    From there, select your region and you should get the local office(s) to your area.
    --Dan
  • mindaugas
    mindaugas over 5 years ago in reply to drozwood90
    Thank you! I will try to contact my local Avnet FAE
  • mindaugas
    Hi drozwood90,
    I have tried to contact my local Anvnet FAE but got no response from last Friday. Could it be related to  Covid-19 or because I am writting from personal (not company) email? Thank you
  • drozwood90
    Hi there,
    It is quite possible it is a little of both.
    I'll send you a DM and we can talk your details so I can help you locate your local FAE.
    --Dan
