Avnet Boards General Memory Interface Generator on XZ7100?
  • Subscribers 357 subscribers
  • Views 438 views
  • mini-module
  • minimodule
  • zynq
  • mini-module_plus
gaochangw
gaochangw over 8 years ago
We are considering design an accelerator that make use of the Xilinx DDR controller IP so that the PL can access DRAM directly without AXI-DMA; however we just found from the manual that the DDR interface on Zynq MMP is connected to Bank 502, which is only connected to the PS. Is it possible to use the Memory Interface Generator on Zynq MMP XZ7100? Thanks a lot!
Best,
Chang
    0 Former Member over 8 years ago
    The DDR3 on the Zynq MMP uses the PS hard IP memory controller and cannot be used with a PL based MIG design. If you need DDR3 connected to the PL, you may want to take a look at Avnet Zynq Mini-ITX platform www.zedboard.org/product/mini-itx-board.
  • gaochangw
    0 gaochangw over 8 years ago in reply to Former Member
    I wonder what the difference between these items?
    AES-MINI-ITX-7Z100-G
    AES-MINI-ITX-7Z100-SYS-G
    AES-MINI-ITX-7Z100-BAS-G
    Does AES-MINI-ITX-7Z100-G include a power module and necessary accessories to be ready to use out of box? Thank you!
    1) The AES-MINI-ITX-7Z100-G consists of  the board + power module, but not the ATX power supply.
    2) The AES-MINI-ITX-7Z100-BAS-G consists of the board, power module, and the ATX power supply (ready to be used out of box).
    3) The AES-MINI-ITX-7Z100-SYS-G consists of the board, power module, and the ATX power supply in a MIni-ITX chassis.
