Avnet Boards General BUFPLL in VITA CAM core
  • Subscribers 358 subscribers
  • Views 525 views
jothin
jothin over 7 years ago
In onsemi_vita_cam core it uses BUFPLL. But this is not supported for Zynq (7 Series).  Can this core work with Microzed?
Jothi
  • jafoste4
    0 jafoste4 over 7 years ago
    Hello Jothi,
    The Microzed used a Zynq (7 series device). Do you have a link to the IP core I can take a look at?
    --Josh
  • jothin
    0 jothin over 7 years ago
    this is is the link
    https://github.com/Avnet/hdl/blob/fcc684c39064c209723f38610a11d79c7c6725c3/IP/onsemi_vita_cam/hdl/iserdes_interface_s6.vhd
    Please look at line # 206.
  • jothin
    0 jothin over 7 years ago in reply to jafoste4
    Hi
    did you look at the code?
  • albertabeef
    0 albertabeef over 7 years ago
    The onsemi_vita_cam core makes use of generics to select different instantiations based on targetted architectures.
    The onsemi_vita_cam core does support MicroZed and PicoZed, which are based on the Zynq (7 series).
    Refer to the "FMC-HDMI-CAM + PYTHON-1300-C Getting Started Guide" for documentation/instructions on how to build a bare metal design that will target the following carriers:
    - ZedBoard
    - MicroZed 7020 SOM + MicroZed FMC Carrier
    - PicoZed 7030 SOM + PicoZed FMC Carrier V2
    Hope this helps !
    Mario.
