Avnet Boards General Lab 6 giving error for system_stub.v file at line 87 ([HDLCompiler 267] Cannot find port LED_DutyCycle on this module)
  • Subscribers 353 subscribers
  • Views 206 views
While trying to do the Lab 6 from this website (URL: http://www.zedboard.org/course/introduction-zynq, under "Download Labs"), I get this error at Step 37 "[HDLCompiler 267] Cannot find port LED_DutyCycle on this module)" when I do Generate BitStream.
system_stub.v file is pasted below, any help would be highly appreciated.
// system_stub.v
module system_stub
    processing_system7_0_MIO,
    processing_system7_0_PS_SRSTB_pin,
    processing_system7_0_PS_CLK_pin,
    processing_system7_0_PS_PORB_pin,
    processing_system7_0_DDR_Clk,
    processing_system7_0_DDR_Clk_n,
    processing_system7_0_DDR_CKE,
    processing_system7_0_DDR_CS_n,
    processing_system7_0_DDR_RAS_n,
    processing_system7_0_DDR_CAS_n,
    processing_system7_0_DDR_WEB_pin,
    processing_system7_0_DDR_BankAddr,
    processing_system7_0_DDR_Addr,
    processing_system7_0_DDR_ODT,
    processing_system7_0_DDR_DRSTB,
    processing_system7_0_DDR_DQ,
    processing_system7_0_DDR_DM,
    processing_system7_0_DDR_DQS,
    processing_system7_0_DDR_DQS_n,
    processing_system7_0_DDR_VRN,
    processing_system7_0_DDR_VRP,
    //LED_DutyCycle,
    //processing_system7_0_FCLK_CLK0_pin
    LEDS,
    InputButtons
  inout [53:0] processing_system7_0_MIO;
  input processing_system7_0_PS_SRSTB_pin;
  input processing_system7_0_PS_CLK_pin;
  input processing_system7_0_PS_PORB_pin;
  inout processing_system7_0_DDR_Clk;
  inout processing_system7_0_DDR_Clk_n;
  inout processing_system7_0_DDR_CKE;
  inout processing_system7_0_DDR_CS_n;
  inout processing_system7_0_DDR_RAS_n;
  inout processing_system7_0_DDR_CAS_n;
  output processing_system7_0_DDR_WEB_pin;
  inout [2:0] processing_system7_0_DDR_BankAddr;
  inout [14:0] processing_system7_0_DDR_Addr;
  inout processing_system7_0_DDR_ODT;
  inout processing_system7_0_DDR_DRSTB;
  inout [31:0] processing_system7_0_DDR_DQ;
  inout [3:0] processing_system7_0_DDR_DM;
  inout [3:0] processing_system7_0_DDR_DQS;
  inout [3:0] processing_system7_0_DDR_DQS_n;
  inout processing_system7_0_DDR_VRN;
  inout processing_system7_0_DDR_VRP;
//  output [31:0] LED_DutyCycle;
//  output processing_system7_0_FCLK_CLK0_pin;
  wire [31:0] LED_DutyCycle;
  wire processing_system7_0_FCLK_CLK0_pin;
  output [7:0] LEDS;
  input [4:0] InputButtons;
  wire [4:0] Pushbuttons;
  (* BOX_TYPE = "user_black_box" *)
  system
    system_i (
      .processing_system7_0_MIO ( processing_system7_0_MIO ),
      .processing_system7_0_PS_SRSTB_pin ( processing_system7_0_PS_SRSTB_pin ),
      .processing_system7_0_PS_CLK_pin ( processing_system7_0_PS_CLK_pin ),
      .processing_system7_0_PS_PORB_pin ( processing_system7_0_PS_PORB_pin ),
      .processing_system7_0_DDR_Clk ( processing_system7_0_DDR_Clk ),
      .processing_system7_0_DDR_Clk_n ( processing_system7_0_DDR_Clk_n ),
      .processing_system7_0_DDR_CKE ( processing_system7_0_DDR_CKE ),
      .processing_system7_0_DDR_CS_n ( processing_system7_0_DDR_CS_n ),
      .processing_system7_0_DDR_RAS_n ( processing_system7_0_DDR_RAS_n ),
      .processing_system7_0_DDR_CAS_n ( processing_system7_0_DDR_CAS_n ),
      .processing_system7_0_DDR_WEB_pin ( processing_system7_0_DDR_WEB_pin ),
      .processing_system7_0_DDR_BankAddr ( processing_system7_0_DDR_BankAddr ),
      .processing_system7_0_DDR_Addr ( processing_system7_0_DDR_Addr ),
      .processing_system7_0_DDR_ODT ( processing_system7_0_DDR_ODT ),
      .processing_system7_0_DDR_DRSTB ( processing_system7_0_DDR_DRSTB ),
      .processing_system7_0_DDR_DQ ( processing_system7_0_DDR_DQ ),
      .processing_system7_0_DDR_DM ( processing_system7_0_DDR_DM ),
      .processing_system7_0_DDR_DQS ( processing_system7_0_DDR_DQS ),
      .processing_system7_0_DDR_DQS_n ( processing_system7_0_DDR_DQS_n ),
      .processing_system7_0_DDR_VRN ( processing_system7_0_DDR_VRN ),
      .processing_system7_0_DDR_VRP ( processing_system7_0_DDR_VRP ),
      .LED_DutyCycle ( LED_DutyCycle ),
      .processing_system7_0_FCLK_CLK0_pin ( processing_system7_0_FCLK_CLK0_pin ),     // output processing_system7_0_FCLK_CLK0_pin;
      .Pushbuttons ( Pushbuttons )     // input [4:0] axi_gpio_0_GPIO2_IO_I_pin;
    PWM_Controller pwm1(
    .Clk (processing_system7_0_FCLK_CLK0_pin),
    .DutyCycle (LED_DutyCycle),
    .PWM_out (LEDS)
     debouncer db1(t
        .Buttons_in (InputButtons),
        .Buttons_out (Pushbuttons),
endmodule
  • bhfletcher
    0 bhfletcher over 12 years ago
    Did you miss the instructions to uncomment the lines related to LED_DutyCycle?
    Bryan
