Avnet Boards General Linux + FPGA on the zedboard
  • Replies 12 replies
  • Subscribers 364 subscribers
  • Views 1929 views
The Zedboard seems very interesting, it has an ARM processor on which a user can run a linux system, it is tightly coupled to an FPGA, and it includes several peripherals and an FMC connector.
I plan to run linux on the zedboard, and I want to stick the zedboard on a network and access the zedboard remotely using an ethernet connection, will that just work?
OK next, I want to create an FPGA application, I will want to use an external clock, is there an input for that?  I also want to use an external trigger input, do I use the XADC for that?  What is the XADC?
How about moving data back and forth between linux and the FPGA, what will be involved to make that work?
Thanks.
  • ashutosh.kumar086@gmail.com
    0 ashutosh.kumar086@gmail.com over 8 years ago
    Can I use Zedboards Zynq FPGA as a DataNode in a multi-node Hadoop Clustering on Linux(Ubuntu)?
  • jafoste4
    0 jafoste4 over 8 years ago
    Hi Ashuntosh,
    It appears possible refering to this document
    http://xanadu.cs.sjsu.edu/~drtylin/classes/cs157A/Project/10000_documents/CS257_Textfiles/18_Srividhya_textFiles/text/BD2013%231622_417_06718411.pdf.txt
    For any future questions please ask them over at the digilent forum as they are the main point of contact for educational support.
    https://forum.digilentinc.com/
    Josh
