Avnet Boards General petalinux:Boot Pre-built images with JTAG
  • Subscribers 355 subscribers
  • Views 556 views
yangtuzi
yangtuzi over 8 years ago
我在windows上安装了vivado 2016.4 (和SDK),裸机下载程序到zedboard,能正常工作。
我安装petalinux在虚拟机上,当我照着ug977做到第9页。用jtag启动时,出现如下问题:
请问我gai如何解决呢?是不是需要什么命令让虚拟机上的petalinux正确连接到jtag_hw_server?
问题现象:
root@ubuntu:/home/project/test1/avnet-digilent-zedboard-2017.2# petalinux-boot --jtag --prebuilt 3
INFO: Append dtb - /home/project/test1/avnet-digilent-zedboard-2017.2/pre-built/linux/images/system.dtb and other options to boot zImage
INFO: Launching XSDB for file download and boot.
INFO: This may take a few minutes, depending on the size of your image.
INFO: Configuring the FPGA...
INFO: Downloading bitstream to the target.
No supported FPGA device found
    invoked from within
"::tcf::eval -progress ::xsdb::print_progress {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {process_tcf_actions_cache_client ::tcfclient#0::arg}}}"
    (procedure "::tcf::cache_eval_with_progress" line 2)
    invoked from within
"::tcf::cache_eval_with_progress [dict get $arg chan]  [list process_tcf_actions_cache_client $argvar] $progress"
    (procedure "process_tcf_actions" line 1)
    invoked from within
"process_tcf_actions $arg ::xsdb::print_progress"
    (procedure "fpga" line 429)
    invoked from within
"fpga "/home/project/test1/avnet-digilent-zedboard-2017.2/pre-built/linux/implementation/download.bit""
    (file "/tmp/tmp.mgHy8ObGav" line 5)
INFO: The XSDB log is as follows
attempting to launch hw_server
****** Xilinx hw_server v2017.2
  **** Build date : Jun 15 2017-18:45:18
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
