Hi~
I would like to know VGA Voltage level.
(at VGA-HS, VGA-VS, I2C SDA, I2C SCL)
In case of ZED, it is designed by 3.3V level.
(at VGA-HS, VGA-VS)
Is it generally 3.3V level or 5V level?
Thanks you.
Hi~
(at VGA-HS, VGA-VS)
Thanks you.
I do not see any I2C SDA or SCL related to VGA on ZedBoard.
Regarding the VGA syncs, I read that these are 5V TTL signals. However, as long as the Voh > 2.7V, the voltage level is acceptable.
http://www.pyroelectro.com/tutorials/fpga_vga_resistor_dac/theory.html
https://www.linusakesson.net/hardware/beagleboard/vga.php
https://learn.sparkfun.com/tutorials/logic-levels/ttl-logic-levels
Regarding the color signals themselves, they have a 1.0V maximum.
Bryan
Hi, Bryan
Thank you for help.
I didn't see I2C SDA or SCL related to VGA on ZedBoard, too.
Regarding the I2C SDA and SCL, I saw this at below link(wiki).
https://en.wikipedia.org/wiki/VGA_connector
Thanks again.
Best Regards,
Asher
I can confirm that the SDA (Pin 12) and SCL (Pin 15) on ZedBoard are No Connect. However, in reading elsewhere online, I see "The VESA E-DDC specification specifies use of I2C at +5V."
Bryan
