Avnet Boards General Simple LED_ON Code Does Not Work (Zedboard Green PCB)
  • Subscribers 358 subscribers
  • Views 673 views
  • Using Xilinx Tools
  • ZedBoard General Questions
  • Zedboard Hardware Design
  • Software Application Development
aimar500
aimar500 over 6 years ago
Hello, I have following very simple code trying to turn on a LED (LD9), but it does not work... would you help to point the error out, please?
There is no PL hardware design, a boot.bin image has been generated from elf output, and the bin file has been copied on SD card.
The jumpers have been set properly (MIO4 and MIO5 High), but the LED was not turned on.
Thank you very much in advance,
P.S.  attachment includes all source code and boot.bin file.
##################################### boot.s ################################################################
.org 0
.text
.global _boot
.section .boot, "axS"
_boot:
            LDR     R0,=0x0F800071C     @ MIO_PIN_07 address
            LDR     R1,=0x0FFFFF600
            STR     R1,[R0]
            LDR     R0,=0xE000A204     @ DIRM_0 address
            MOV     R1,#0x00000080
            STR     R1,[R0]
            LDR     R0,=0xE000A208     @ OEN_0 address
            MOV     R1,#0x00000080
            STR     R1,[R0]
            LDR     R0,=0xE000A040     @ DATA_0 address
            MOV     R1,#0x00000080     @Turn On LED
            STR     R1,[R0]
MAIN_LOOP:
            B       MAIN_LOOP
.end
##################################### linker file #############################################################
SECTIONS
.boot 0x00000000: {
   *(.boot)
   *(.text)
   *(.gnu.linkonce.t.*)
##################################### bif file #############################################################
the_ROM_image:
[bootloader] led_on.elf
6102.led_on.zip
  • jafoste4
    0 jafoste4 over 6 years ago
    Please take a look at Issue 10 and 11 of the MicroZed Chronicles.
    http://adiuvoengineering.com/microzed-chronicles/
    -Josh
  • aimar500
    0 aimar500 over 6 years ago in reply to jafoste4
    Hi Josh, Thank you very much for your reply. I don't think the posts you mentioned are related to my issues. I doubt my problem is related to the PS booting procedure. The code is linked to the address 0x00000000, but probably it is not executed properly. I can't find the problem even I had spent a certain amount of time on it ....
  • jafoste4
    0 jafoste4 over 6 years ago in reply to aimar500
    Hi Peng,
    Does your application work over JTAG? Looking at your notes, it looks like your either booting from QSPI or SD Card.
    May I ask why your not using a hardware platform in your design? Are you at the very least using the default one built into SDK so it know the ARM processors available to it on your Zedboard?
    -Josh
  • aimar500
    Hi Josh,
    very nice to hear from you again. I wrote this simple code is to test whether my understanding of booting procedure is correct or not. From my point of view, after the zed board powered up, it first executes the code from BootROM (Stage-0 Boot) which will find the valid image according to the Jumper settings. In my situation, my image (bootloader or boot.bin, generated by led_on.elf) is in SD card. Then, the image (located in SD card) will be loaded to OCM and execute the first instructor from address 0x00000000. In my code, I linked the function (turn on the LED) at 0x00000000 and then, loop the CPU (without ).  I believe the LED should be turned on except my understanding on the procedure of booting is wrong....  Please kindly let me know any of my understanding mistakes. Thank you very much.
  • bhfletcher
    0 bhfletcher over 6 years ago in reply to aimar500
    If you would like a deeper dive explanation of the Zynq-7000 boot procedure, you can certainly read the Zynq TRM. You may also find this presentation from X-Fest 2014 interesting:
    Zynq Boot and Configuration Procedures
    Nasser Poureh
    http://avnet.me/ZynqBootXF2014
    Bryan
