Avnet Boards General JTAG not working with ZedBoard+FMC Ethernet card
  • Subscribers 356 subscribers
  • Views 1059 views
  • Zedboard Hardware Design
  • avnet_network_fmc_module
  • zedboardcmty
saajanchana_cc
saajanchana_cc over 4 years ago
I'm trying to use a ZedBoard with an Avnet FMC Ethernet card (https://www.avnet.com/shop/us/products/avnet-engineering-services/aes-fmc-netw1-g-3074457345635205181/ ), using the on-board Digilent USB-JTAG device. When the FMC card is connected, the JTAG chain seems to be broken - the Digilent target appears in Vivado Hardware Manager, but with no devices detected. When the FMC card is disconnected, everything works as it should.
ZedBoard Jumper settings:
  • JP7, JP8, JP9, JP10, JP11 - all connected to GND to select JTAG configuration.
  • J18 - 2V5 (correct for this FMC card)
All power supplies (3V3, 12V, 5V and VADJ) look good with the FMC connected.
I am using Vivado 2020.1.
Any ideas what could be going on? My guess is that this has something to do with the FMC card JTAG chain switch, but I can't see any reason this wouldn't work from the schematics.
Thank you,
Saajan
  • narrucmot
    narrucmot over 4 years ago in reply to saajanchana_cc +1
    Thank you for letting us know. I am glad you were able to get this working! --Tom
  • saajanchana_cc
    0 saajanchana_cc over 4 years ago
    Figured it out: it was nothing to do with the JTAG chain, the issue is that the FMC card is pulling the Zynq's power-on-reset low as per this PCB errata: https://www.avnet.com/opasdata/d120001/medias/docus/198/Network_FMC_Errata_200213.pdf. Even though the date code of my PCB (2019) is outside the range covered by the errata, it still seems to be a problem - removing Q1 allows the Zynq POR to go high.
  • narrucmot
    0 narrucmot over 4 years ago in reply to saajanchana_cc
    --Tom
