Hi folks,
Has anyone encountered this problem? Is there any suggestion to fix it?
I was trying to build and install the Extensible SDK for maaxboard.
I built it and when I was building I just encountered some warnings such as:
WARNING: lite-image-1.0-r0 do_sdk_depends: Manifest /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/sstate-control/manifest-x86_64_x86_64-nativesdk-kernel-devsrc.populate_sysroot not found in maaxboard_ddr4_2g_sdcard aarch64-mx8m aarch64 allarch x86_64_x86_64-nativesdk (variant '')? WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_font_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_gio_module_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_icon_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_pixbuf_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_font_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_gio_module_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_icon_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: buildtools-tarball-1.0-r0 do_populate_sdk: The postinstall intercept hook 'update_pixbuf_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/x86_64-nativesdk-pokysdk-linux/buildtools-tarball/1.0-r0/temp/log.do_populate_sdk WARNING: lite-image-1.0-r0 do_populate_sdk_ext: Manifest /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/sstate-control/manifest-x86_64_x86_64-nativesdk-kernel-devsrc.populate_sysroot not found in maaxboard_ddr4_2g_sdcard aarch64-mx8m aarch64 allarch x86_64_x86_64-nativesdk (variant '')? WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_font_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_gio_module_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_icon_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_pixbuf_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_font_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_gio_module_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_icon_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext WARNING: lite-image-1.0-r0 do_populate_sdk_ext: The postinstall intercept hook 'update_pixbuf_cache' failed, details in /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/work/maaxboard_ddr4_2g_sdcard-poky-linux/lite-image/1.0-r0/temp/log.do_populate_sdk_ext
However, When I tried to install, the result is this: so many errors
./fsl-imx-wayland-lite-glibc-x86_64-lite-image-aarch64-toolchain-ext-4.14-sumo.sh NXP i.MX Release Distro Extensible SDK installer version 4.14-sumo ================================================================== Enter target directory for SDK (default: ~/fsl-imx-wayland-lite_sdk): /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk You are about to install the SDK to "/media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk". Proceed[Y/n]? Y Extracting SDK............................................................................................................................................................done Setting it up... Extracting buildtools... Preparing build system... WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-sdk/dynamic-layers/qt5-layer/recipes-qt/qt5/gstreamer1.0-plugins-good-qt_1.14.imx.bb: Unable to get checksum for gstreamer1.0-plugins-good-qt SRC_URI entry gtk-doc-tweaks.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0_1.14.imx.bb: Unable to get checksum for gstreamer1.0 SRC_URI entry 0001-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-rtsp-server_1.14.4.bb: Unable to get checksum for gstreamer1.0-rtsp-server SRC_URI entry 0001-Don-t-hardcode-libtool-name-when-using-introspection.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-ugly_1.14.4.bb: Unable to get checksum for gstreamer1.0-plugins-ugly SRC_URI entry 0001-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-good_1.14.imx.bb: Unable to get checksum for gstreamer1.0-plugins-good SRC_URI entry gtk-doc-tweaks.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-libav_1.14.4.bb: Unable to get checksum for gstreamer1.0-libav SRC_URI entry 0001-Disable-yasm-for-libav-when-disable-yasm.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0_1.14.imx.bb: Unable to get checksum for gstreamer1.0 SRC_URI entry gtk-doc-tweaks.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.14.imx.bb: Unable to get checksum for gstreamer1.0-plugins-base SRC_URI entry 0001-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-rtsp-server_1.14.4.bb: Unable to get checksum for gstreamer1.0-rtsp-server SRC_URI entry 0001-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-ugly_1.14.4.bb: Unable to get checksum for gstreamer1.0-plugins-ugly SRC_URI entry gtk-doc-tweaks.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-libav_1.14.4.bb: Unable to get checksum for gstreamer1.0-libav SRC_URI entry workaround-to-build-gst-libav-for-i586-with-gcc.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0_1.14.imx.bb: Unable to get checksum for gstreamer1.0 SRC_URI entry 0001-gst-gstpluginloader.c-when-env-var-is-set-do-not-fal.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-rtsp-server_1.14.4.bb: Unable to get checksum for gstreamer1.0-rtsp-server SRC_URI entry gtk-doc-tweaks.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-libav_1.14.4.bb: Unable to get checksum for gstreamer1.0-libav SRC_URI entry mips64_cpu_detection.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.14.imx.bb: Unable to get checksum for gstreamer1.0-plugins-base SRC_URI entry gtk-doc-tweaks.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-libav_1.14.4.bb: Unable to get checksum for gstreamer1.0-libav SRC_URI entry 0001-configure-check-for-armv7ve-variant.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.14.imx.bb: Unable to get checksum for gstreamer1.0-plugins-base SRC_URI entry 0003-riff-add-missing-include-directories-when-calling-in.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.14.imx.bb: Unable to get checksum for gstreamer1.0-plugins-base SRC_URI entry 0004-rtsp-drop-incorrect-reference-to-gstreamer-sdp-in-Ma.patch: file could not be found WARNING: /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/layers/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-bad_1.14.imx.bb: Unable to get checksum for gstreamer1.0-plugins-bad SRC_URI entry gtk-doc-tweaks.patch: file could not be found Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:06:21 Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:18 Checking sstate mirror object availability: 100% |###########################################################################################################################################| Time: 0:00:01 WARNING: The gstreamer1.0-plugins-bad:do_fetch sig is computed to be ba83c7e62dca31af1b4b0256b1758a29, but the sig is locked to 52f2b2a5ee8bc6b7ac9d378c295d5105 in SIGGEN_LOCKEDSIGS_t-aarch64-mx8m The gstreamer1.0-libav:do_fetch sig is computed to be 76ec2c440d36fff57e1497cbabca766d, but the sig is locked to a7af1d925d094a2b20e45ab630716b8a in SIGGEN_LOCKEDSIGS_t-aarch64 The initscripts:do_fetch sig is computed to be b981d02372e52676603582199a880445, but the sig is locked to bb4bac782afc60698e7dfa75e441a1a1 in SIGGEN_LOCKEDSIGS_t-maaxboard-ddr4-2g-sdcard The gstreamer1.0-rtsp-server:do_fetch sig is computed to be b7f9135f53533c92a0bf68dee71c904e, but the sig is locked to e9b7cec3c24b03ba90046b04e5faa044 in SIGGEN_LOCKEDSIGS_t-aarch64 The gstreamer1.0-plugins-good:do_fetch sig is computed to be 84eeccd6b2b4816692eed4a677f6ac55, but the sig is locked to 27cc0d6f64bbd28e792c1c09a5da6cdf in SIGGEN_LOCKEDSIGS_t-aarch64-mx8m The gstreamer1.0-plugins-ugly:do_fetch sig is computed to be 1faa2def1348f6d6f1fa09815b5b89bf, but the sig is locked to ef2451019fb59408fd0df28f149e6fe6 in SIGGEN_LOCKEDSIGS_t-aarch64 The gstreamer1.0:do_fetch sig is computed to be 9b561a969e5561d036c7f18d63bb14cb, but the sig is locked to 5c888d8667d522a7935150ce67cfea87 in SIGGEN_LOCKEDSIGS_t-aarch64 The gstreamer1.0-plugins-base:do_fetch sig is computed to be 7de8a18e21db1c4c54e8994e1d469cc5, but the sig is locked to 3fd84b0fd76bd449e8a2487e8943fc8e in SIGGEN_LOCKEDSIGS_t-aarch64-mx8m The packagegroup-core-boot:do_package sig is computed to be 92b837b9b8091cd6b6deee461202b9ea, but the sig is locked to 91faf9bad7a5c816ad19b61913db64b4 in SIGGEN_LOCKEDSIGS_t-maaxboard-ddr4-2g-sdcard The packagegroup-core-boot:do_package_write_deb sig is computed to be 4d4f5dd34a0cacaff77b313b1fa9fc35, but the sig is locked to b27eb84b00d9a05f70f2ebe04fb9534e in SIGGEN_LOCKEDSIGS_t-maaxboard-ddr4-2g-sdcard The packagegroup-core-boot:do_package_qa sig is computed to be 0cc78d27bed8cbd999830b976aa41a4d, but the sig is locked to 331db61890f8878d63cfe8edc5e37c8d in SIGGEN_LOCKEDSIGS_t-maaxboard-ddr4-2g-sdcard ERROR: Task quilt-native.do_fetch attempted to execute unexpectedly ERROR: Task quilt-native.do_unpack attempted to execute unexpectedly ERROR: Task quilt-native.do_patch attempted to execute unexpectedly ERROR: Task quilt-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task quilt-native.do_configure attempted to execute unexpectedly ERROR: Task quilt-native.do_compile attempted to execute unexpectedly ERROR: Task quilt-native.do_install attempted to execute unexpectedly ERROR: Task quilt-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task texinfo-dummy-native.do_fetch attempted to execute unexpectedly ERROR: Task gnu-config-native.do_fetch attempted to execute unexpectedly ERROR: Task texinfo-dummy-native.do_unpack attempted to execute unexpectedly ERROR: Task texinfo-dummy-native.do_patch attempted to execute unexpectedly ERROR: Task texinfo-dummy-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task texinfo-dummy-native.do_configure attempted to execute unexpectedly ERROR: Task texinfo-dummy-native.do_compile attempted to execute unexpectedly ERROR: Task texinfo-dummy-native.do_install attempted to execute unexpectedly ERROR: Task texinfo-dummy-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gnu-config-native.do_unpack attempted to execute unexpectedly ERROR: Task gnu-config-native.do_patch attempted to execute unexpectedly ERROR: Task gnu-config-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gnu-config-native.do_configure attempted to execute unexpectedly ERROR: Task gnu-config-native.do_install attempted to execute unexpectedly ERROR: Task gnu-config-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task m4-native.do_fetch attempted to execute unexpectedly ERROR: Task autoconf-native.do_fetch attempted to execute unexpectedly ERROR: Task m4-native.do_unpack attempted to execute unexpectedly ERROR: Task m4-native.do_patch attempted to execute unexpectedly ERROR: Task m4-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task m4-native.do_configure attempted to execute unexpectedly ERROR: Task m4-native.do_compile attempted to execute unexpectedly ERROR: Task m4-native.do_install attempted to execute unexpectedly ERROR: Task m4-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task autoconf-native.do_unpack attempted to execute unexpectedly ERROR: Task autoconf-native.do_patch attempted to execute unexpectedly ERROR: Task autoconf-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task autoconf-native.do_configure attempted to execute unexpectedly ERROR: Task autoconf-native.do_compile attempted to execute unexpectedly ERROR: Task autoconf-native.do_install attempted to execute unexpectedly ERROR: Task autoconf-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task automake-native.do_fetch attempted to execute unexpectedly ERROR: Task libtool-native.do_fetch attempted to execute unexpectedly ERROR: Task automake-native.do_unpack attempted to execute unexpectedly ERROR: Task automake-native.do_patch attempted to execute unexpectedly ERROR: Task automake-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task automake-native.do_configure attempted to execute unexpectedly ERROR: Task automake-native.do_compile attempted to execute unexpectedly ERROR: Task automake-native.do_install attempted to execute unexpectedly ERROR: Task automake-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gettext-minimal-native.do_fetch attempted to execute unexpectedly ERROR: Task libtool-native.do_unpack attempted to execute unexpectedly ERROR: Task libtool-native.do_patch attempted to execute unexpectedly ERROR: Task libtool-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libtool-native.do_configure attempted to execute unexpectedly ERROR: Task libtool-native.do_compile attempted to execute unexpectedly ERROR: Task libtool-native.do_install attempted to execute unexpectedly ERROR: Task libtool-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task xz-native.do_fetch attempted to execute unexpectedly ERROR: Task gettext-minimal-native.do_unpack attempted to execute unexpectedly ERROR: Task gettext-minimal-native.do_patch attempted to execute unexpectedly ERROR: Task gettext-minimal-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gettext-minimal-native.do_configure attempted to execute unexpectedly ERROR: Task gettext-minimal-native.do_compile attempted to execute unexpectedly ERROR: Task gettext-minimal-native.do_install attempted to execute unexpectedly ERROR: Task gettext-minimal-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gmp-native.do_fetch attempted to execute unexpectedly ERROR: Task xz-native.do_unpack attempted to execute unexpectedly ERROR: Task xz-native.do_patch attempted to execute unexpectedly ERROR: Task xz-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task xz-native.do_configure attempted to execute unexpectedly ERROR: Task xz-native.do_compile attempted to execute unexpectedly ERROR: Task xz-native.do_install attempted to execute unexpectedly ERROR: Task xz-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task flex-native.do_fetch attempted to execute unexpectedly ERROR: Task zlib-native.do_fetch attempted to execute unexpectedly ERROR: Task mpfr-native.do_fetch attempted to execute unexpectedly ERROR: Task gmp-native.do_unpack attempted to execute unexpectedly ERROR: Task gmp-native.do_patch attempted to execute unexpectedly ERROR: Task gmp-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gmp-native.do_configure attempted to execute unexpectedly ERROR: Task gmp-native.do_compile attempted to execute unexpectedly ERROR: Task gmp-native.do_install attempted to execute unexpectedly ERROR: Task gmp-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task flex-native.do_unpack attempted to execute unexpectedly ERROR: Task flex-native.do_patch attempted to execute unexpectedly ERROR: Task flex-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task flex-native.do_configure attempted to execute unexpectedly ERROR: Task flex-native.do_compile attempted to execute unexpectedly ERROR: Task flex-native.do_install attempted to execute unexpectedly ERROR: Task flex-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task bison-native.do_fetch attempted to execute unexpectedly ERROR: Task binutils-cross-aarch64.do_fetch attempted to execute unexpectedly ERROR: Task zlib-native.do_unpack attempted to execute unexpectedly ERROR: Task zlib-native.do_patch attempted to execute unexpectedly ERROR: Task zlib-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task zlib-native.do_configure attempted to execute unexpectedly ERROR: Task zlib-native.do_compile attempted to execute unexpectedly ERROR: Task zlib-native.do_install attempted to execute unexpectedly ERROR: Task zlib-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libmpc-native.do_fetch attempted to execute unexpectedly ERROR: Task mpfr-native.do_unpack attempted to execute unexpectedly ERROR: Task mpfr-native.do_patch attempted to execute unexpectedly ERROR: Task mpfr-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task mpfr-native.do_configure attempted to execute unexpectedly ERROR: Task mpfr-native.do_compile attempted to execute unexpectedly ERROR: Task mpfr-native.do_install attempted to execute unexpectedly ERROR: Task mpfr-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gcc-source-7.3.0.do_fetch attempted to execute unexpectedly ERROR: Task gcc-source-7.3.0.do_unpack attempted to execute unexpectedly ERROR: Task gcc-source-7.3.0.do_patch attempted to execute unexpectedly ERROR: Task gcc-source-7.3.0.do_preconfigure attempted to execute unexpectedly ERROR: Task bison-native.do_unpack attempted to execute unexpectedly ERROR: Task bison-native.do_patch attempted to execute unexpectedly ERROR: Task bison-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task bison-native.do_configure attempted to execute unexpectedly ERROR: Task bison-native.do_compile attempted to execute unexpectedly ERROR: Task bison-native.do_install attempted to execute unexpectedly ERROR: Task bison-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task binutils-cross-aarch64.do_unpack attempted to execute unexpectedly ERROR: Task binutils-cross-aarch64.do_patch attempted to execute unexpectedly ERROR: Task binutils-cross-aarch64.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task binutils-cross-aarch64.do_configure attempted to execute unexpectedly ERROR: Task binutils-cross-aarch64.do_compile attempted to execute unexpectedly ERROR: Task binutils-cross-aarch64.do_install attempted to execute unexpectedly ERROR: Task binutils-cross-aarch64.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task pkgconfig-native.do_fetch attempted to execute unexpectedly ERROR: Task libmpc-native.do_unpack attempted to execute unexpectedly ERROR: Task libmpc-native.do_patch attempted to execute unexpectedly ERROR: Task libmpc-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libmpc-native.do_configure attempted to execute unexpectedly ERROR: Task libmpc-native.do_compile attempted to execute unexpectedly ERROR: Task libmpc-native.do_install attempted to execute unexpectedly ERROR: Task libmpc-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gcc-cross-initial-aarch64.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gcc-cross-initial-aarch64.do_configure attempted to execute unexpectedly ERROR: Task gcc-cross-initial-aarch64.do_compile attempted to execute unexpectedly ERROR: Task sqlite3-native.do_fetch attempted to execute unexpectedly ERROR: Task attr-native.do_fetch attempted to execute unexpectedly ERROR: Task pseudo-native.do_fetch attempted to execute unexpectedly ERROR: Task gcc-cross-initial-aarch64.do_gcc_stash_builddir attempted to execute unexpectedly and should have been setscened ERROR: Task pkgconfig-native.do_unpack attempted to execute unexpectedly ERROR: Task pkgconfig-native.do_patch attempted to execute unexpectedly ERROR: Task pkgconfig-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task pkgconfig-native.do_configure attempted to execute unexpectedly ERROR: Task pkgconfig-native.do_compile attempted to execute unexpectedly ERROR: Task pkgconfig-native.do_install attempted to execute unexpectedly ERROR: Task pkgconfig-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task sqlite3-native.do_unpack attempted to execute unexpectedly ERROR: Task sqlite3-native.do_patch attempted to execute unexpectedly ERROR: Task sqlite3-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task sqlite3-native.do_configure attempted to execute unexpectedly ERROR: Task sqlite3-native.do_compile attempted to execute unexpectedly ERROR: Task sqlite3-native.do_install attempted to execute unexpectedly ERROR: Task sqlite3-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task attr-native.do_unpack attempted to execute unexpectedly ERROR: Task attr-native.do_patch attempted to execute unexpectedly ERROR: Task attr-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task attr-native.do_configure attempted to execute unexpectedly ERROR: Task attr-native.do_compile attempted to execute unexpectedly ERROR: Task attr-native.do_install attempted to execute unexpectedly ERROR: Task attr-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task pseudo-native.do_unpack attempted to execute unexpectedly ERROR: Task pseudo-native.do_patch attempted to execute unexpectedly ERROR: Task pseudo-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task pseudo-native.do_configure attempted to execute unexpectedly ERROR: Task pseudo-native.do_compile attempted to execute unexpectedly ERROR: Task pseudo-native.do_install attempted to execute unexpectedly ERROR: Task pseudo-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gcc-cross-initial-aarch64.do_install attempted to execute unexpectedly ERROR: Task gcc-cross-initial-aarch64.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libgcc-initial.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libgcc-initial.do_configure attempted to execute unexpectedly ERROR: Task libgcc-initial.do_compile attempted to execute unexpectedly ERROR: Task libgcc-initial.do_install attempted to execute unexpectedly ERROR: Task unifdef-native.do_fetch attempted to execute unexpectedly ERROR: Task systemd-systemctl-native.do_fetch attempted to execute unexpectedly ERROR: Task libgcc-initial.do_multilib_install attempted to execute unexpectedly ERROR: Task glibc-initial.do_fetch attempted to execute unexpectedly ERROR: Task unifdef-native.do_unpack attempted to execute unexpectedly ERROR: Task unifdef-native.do_patch attempted to execute unexpectedly ERROR: Task unifdef-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task unifdef-native.do_configure attempted to execute unexpectedly ERROR: Task unifdef-native.do_compile attempted to execute unexpectedly ERROR: Task unifdef-native.do_install attempted to execute unexpectedly ERROR: Task unifdef-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task systemd-systemctl-native.do_unpack attempted to execute unexpectedly ERROR: Task systemd-systemctl-native.do_patch attempted to execute unexpectedly ERROR: Task systemd-systemctl-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task systemd-systemctl-native.do_configure attempted to execute unexpectedly ERROR: Task systemd-systemctl-native.do_compile attempted to execute unexpectedly ERROR: Task systemd-systemctl-native.do_install attempted to execute unexpectedly ERROR: Task systemd-systemctl-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libgcc-initial.do_extra_symlinks attempted to execute unexpectedly ERROR: Task libgcc-initial.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task glibc-initial.do_unpack attempted to execute unexpectedly ERROR: Task glibc-initial.do_patch attempted to execute unexpectedly ERROR: Task glibc-initial.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task glibc-initial.do_configure attempted to execute unexpectedly ERROR: Task glibc-initial.do_compile attempted to execute unexpectedly ERROR: Task glibc-initial.do_install attempted to execute unexpectedly ERROR: Task gperf-native.do_fetch attempted to execute unexpectedly ERROR: Task glibc.do_fetch attempted to execute unexpectedly ERROR: Task glibc-initial.do_stash_locale attempted to execute unexpectedly and should have been setscened ERROR: Task gperf-native.do_unpack attempted to execute unexpectedly ERROR: Task gperf-native.do_patch attempted to execute unexpectedly ERROR: Task gperf-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gperf-native.do_configure attempted to execute unexpectedly ERROR: Task gperf-native.do_compile attempted to execute unexpectedly ERROR: Task gperf-native.do_install attempted to execute unexpectedly ERROR: Task gperf-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task glibc.do_unpack attempted to execute unexpectedly ERROR: Task glibc.do_patch attempted to execute unexpectedly ERROR: Task glibc-initial.do_poststash_install_cleanup attempted to execute unexpectedly ERROR: Task glibc-initial.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task glibc.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task glibc.do_configure attempted to execute unexpectedly ERROR: Task glibc.do_compile attempted to execute unexpectedly ERROR: Task glibc.do_install attempted to execute unexpectedly ERROR: Task glibc.do_stash_locale attempted to execute unexpectedly and should have been setscened ERROR: Task gcc-cross-aarch64.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gcc-cross-aarch64.do_configure attempted to execute unexpectedly ERROR: Task gcc-cross-aarch64.do_compile attempted to execute unexpectedly ERROR: Task gcc-cross-aarch64.do_gcc_stash_builddir attempted to execute unexpectedly and should have been setscened ERROR: Task gcc-cross-aarch64.do_install attempted to execute unexpectedly ERROR: Task gcc-cross-aarch64.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gettext-native.do_fetch attempted to execute unexpectedly ERROR: Task gettext-native.do_unpack attempted to execute unexpectedly ERROR: Task gettext-native.do_patch attempted to execute unexpectedly ERROR: Task gettext-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gettext-native.do_configure attempted to execute unexpectedly ERROR: Task gettext-native.do_compile attempted to execute unexpectedly ERROR: Task gettext-native.do_install attempted to execute unexpectedly ERROR: Task gettext-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task ncurses-native.do_fetch attempted to execute unexpectedly ERROR: Task bzip2-native.do_fetch attempted to execute unexpectedly ERROR: Task openssl-native.do_fetch attempted to execute unexpectedly ERROR: Task gdbm-native.do_fetch attempted to execute unexpectedly ERROR: Task readline-native.do_fetch attempted to execute unexpectedly ERROR: Task python3-native.do_fetch attempted to execute unexpectedly ERROR: Task ncurses-native.do_unpack attempted to execute unexpectedly ERROR: Task ncurses-native.do_patch attempted to execute unexpectedly ERROR: Task ncurses-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task ncurses-native.do_configure attempted to execute unexpectedly ERROR: Task ncurses-native.do_compile attempted to execute unexpectedly ERROR: Task ncurses-native.do_install attempted to execute unexpectedly ERROR: Task ncurses-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task bzip2-native.do_unpack attempted to execute unexpectedly ERROR: Task bzip2-native.do_patch attempted to execute unexpectedly ERROR: Task bzip2-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task bzip2-native.do_configure attempted to execute unexpectedly ERROR: Task bzip2-native.do_compile attempted to execute unexpectedly ERROR: Task bzip2-native.do_install attempted to execute unexpectedly ERROR: Task bzip2-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task cracklib-native.do_fetch attempted to execute unexpectedly ERROR: Task libxml2-native.do_fetch attempted to execute unexpectedly ERROR: Task openssl-native.do_unpack attempted to execute unexpectedly ERROR: Task openssl-native.do_patch attempted to execute unexpectedly ERROR: Task openssl-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task openssl-native.do_configure attempted to execute unexpectedly ERROR: Task openssl-native.do_compile attempted to execute unexpectedly ERROR: Task openssl-native.do_install attempted to execute unexpectedly ERROR: Task openssl-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gdbm-native.do_unpack attempted to execute unexpectedly ERROR: Task gdbm-native.do_patch attempted to execute unexpectedly ERROR: Task gdbm-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gdbm-native.do_configure attempted to execute unexpectedly ERROR: Task gdbm-native.do_compile attempted to execute unexpectedly ERROR: Task gdbm-native.do_install attempted to execute unexpectedly ERROR: Task gdbm-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task readline-native.do_unpack attempted to execute unexpectedly ERROR: Task readline-native.do_patch attempted to execute unexpectedly ERROR: Task readline-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task readline-native.do_configure attempted to execute unexpectedly ERROR: Task readline-native.do_compile attempted to execute unexpectedly ERROR: Task readline-native.do_install attempted to execute unexpectedly ERROR: Task readline-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task python3-native.do_unpack attempted to execute unexpectedly ERROR: Task python3-native.do_patch attempted to execute unexpectedly ERROR: Task python3-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task python3-native.do_configure attempted to execute unexpectedly ERROR: Task python3-native.do_compile attempted to execute unexpectedly ERROR: Task python3-native.do_install attempted to execute unexpectedly ERROR: Task python3-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task lzo-native.do_fetch attempted to execute unexpectedly ERROR: Task elfutils-native.do_fetch attempted to execute unexpectedly ERROR: Task cracklib-native.do_unpack attempted to execute unexpectedly ERROR: Task cracklib-native.do_patch attempted to execute unexpectedly ERROR: Task cracklib-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task cracklib-native.do_configure attempted to execute unexpectedly ERROR: Task cracklib-native.do_compile attempted to execute unexpectedly ERROR: Task cracklib-native.do_install attempted to execute unexpectedly ERROR: Task cracklib-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxml2-native.do_unpack attempted to execute unexpectedly ERROR: Task libxml2-native.do_patch attempted to execute unexpectedly ERROR: Task libxml2-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxml2-native.do_configure attempted to execute unexpectedly ERROR: Task libxml2-native.do_compile attempted to execute unexpectedly ERROR: Task libxml2-native.do_install attempted to execute unexpectedly ERROR: Task libxml2-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task db-native.do_fetch attempted to execute unexpectedly ERROR: Task util-linux-native.do_fetch attempted to execute unexpectedly ERROR: Task expat-native.do_fetch attempted to execute unexpectedly ERROR: Task lzo-native.do_unpack attempted to execute unexpectedly ERROR: Task lzo-native.do_patch attempted to execute unexpectedly ERROR: Task lzo-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task lzo-native.do_configure attempted to execute unexpectedly ERROR: Task lzo-native.do_compile attempted to execute unexpectedly ERROR: Task lzo-native.do_install attempted to execute unexpectedly ERROR: Task lzo-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task elfutils-native.do_unpack attempted to execute unexpectedly ERROR: Task elfutils-native.do_patch attempted to execute unexpectedly ERROR: Task elfutils-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task elfutils-native.do_configure attempted to execute unexpectedly ERROR: Task elfutils-native.do_compile attempted to execute unexpectedly ERROR: Task elfutils-native.do_install attempted to execute unexpectedly ERROR: Task elfutils-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task autoconf-archive-native.do_fetch attempted to execute unexpectedly ERROR: Task dbus-native.do_fetch attempted to execute unexpectedly ERROR: Task file-native.do_fetch attempted to execute unexpectedly ERROR: Task e2fsprogs-native.do_fetch attempted to execute unexpectedly ERROR: Task nspr-native.do_fetch attempted to execute unexpectedly ERROR: Task popt-native.do_fetch attempted to execute unexpectedly ERROR: Task nss-native.do_fetch attempted to execute unexpectedly ERROR: Task libarchive-native.do_fetch attempted to execute unexpectedly ERROR: Task dwarfsrcfiles-native.do_fetch attempted to execute unexpectedly ERROR: Task rpm-native.do_fetch attempted to execute unexpectedly ERROR: Task db-native.do_unpack attempted to execute unexpectedly ERROR: Task db-native.do_patch attempted to execute unexpectedly ERROR: Task db-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task db-native.do_configure attempted to execute unexpectedly ERROR: Task db-native.do_compile attempted to execute unexpectedly ERROR: Task db-native.do_install attempted to execute unexpectedly ERROR: Task db-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task util-linux-native.do_unpack attempted to execute unexpectedly ERROR: Task util-linux-native.do_patch attempted to execute unexpectedly ERROR: Task util-linux-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task util-linux-native.do_configure attempted to execute unexpectedly ERROR: Task util-linux-native.do_compile attempted to execute unexpectedly ERROR: Task util-linux-native.do_install attempted to execute unexpectedly ERROR: Task util-linux-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task expat-native.do_unpack attempted to execute unexpectedly ERROR: Task expat-native.do_patch attempted to execute unexpectedly ERROR: Task expat-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task expat-native.do_configure attempted to execute unexpectedly ERROR: Task expat-native.do_compile attempted to execute unexpectedly ERROR: Task expat-native.do_install attempted to execute unexpectedly ERROR: Task expat-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task autoconf-archive-native.do_unpack attempted to execute unexpectedly ERROR: Task autoconf-archive-native.do_patch attempted to execute unexpectedly ERROR: Task dbus-native.do_unpack attempted to execute unexpectedly ERROR: Task dbus-native.do_patch attempted to execute unexpectedly ERROR: Task autoconf-archive-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task autoconf-archive-native.do_configure attempted to execute unexpectedly ERROR: Task autoconf-archive-native.do_compile attempted to execute unexpectedly ERROR: Task autoconf-archive-native.do_install attempted to execute unexpectedly ERROR: Task autoconf-archive-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dbus-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task dbus-native.do_configure attempted to execute unexpectedly ERROR: Task dbus-native.do_compile attempted to execute unexpectedly ERROR: Task dbus-native.do_install attempted to execute unexpectedly ERROR: Task dbus-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task file-native.do_unpack attempted to execute unexpectedly ERROR: Task file-native.do_patch attempted to execute unexpectedly ERROR: Task file-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task file-native.do_configure attempted to execute unexpectedly ERROR: Task file-native.do_compile attempted to execute unexpectedly ERROR: Task file-native.do_install attempted to execute unexpectedly ERROR: Task file-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task e2fsprogs-native.do_unpack attempted to execute unexpectedly ERROR: Task e2fsprogs-native.do_patch attempted to execute unexpectedly ERROR: Task nspr-native.do_unpack attempted to execute unexpectedly ERROR: Task nspr-native.do_patch attempted to execute unexpectedly ERROR: Task nss-native.do_unpack attempted to execute unexpectedly ERROR: Task popt-native.do_unpack attempted to execute unexpectedly ERROR: Task libarchive-native.do_unpack attempted to execute unexpectedly ERROR: Task popt-native.do_patch attempted to execute unexpectedly ERROR: Task nss-native.do_patch attempted to execute unexpectedly ERROR: Task libarchive-native.do_patch attempted to execute unexpectedly ERROR: Task rpm-native.do_unpack attempted to execute unexpectedly ERROR: Task dwarfsrcfiles-native.do_unpack attempted to execute unexpectedly ERROR: Task dwarfsrcfiles-native.do_patch attempted to execute unexpectedly ERROR: Task rpm-native.do_patch attempted to execute unexpectedly ERROR: Task e2fsprogs-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task e2fsprogs-native.do_configure attempted to execute unexpectedly ERROR: Task e2fsprogs-native.do_compile attempted to execute unexpectedly ERROR: Task e2fsprogs-native.do_install attempted to execute unexpectedly ERROR: Task e2fsprogs-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task nspr-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task nspr-native.do_configure attempted to execute unexpectedly ERROR: Task nspr-native.do_compile attempted to execute unexpectedly ERROR: Task nspr-native.do_install attempted to execute unexpectedly ERROR: Task nspr-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libarchive-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task popt-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task nss-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task popt-native.do_configure attempted to execute unexpectedly ERROR: Task libarchive-native.do_configure attempted to execute unexpectedly ERROR: Task nss-native.do_configure attempted to execute unexpectedly ERROR: Task popt-native.do_compile attempted to execute unexpectedly ERROR: Task libarchive-native.do_compile attempted to execute unexpectedly ERROR: Task nss-native.do_compile attempted to execute unexpectedly ERROR: Task popt-native.do_install attempted to execute unexpectedly ERROR: Task nss-native.do_install attempted to execute unexpectedly ERROR: Task libarchive-native.do_install attempted to execute unexpectedly ERROR: Task nss-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libarchive-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task popt-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task rpm-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task dwarfsrcfiles-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task rpm-native.do_configure attempted to execute unexpectedly ERROR: Task dwarfsrcfiles-native.do_configure attempted to execute unexpectedly ERROR: Task rpm-native.do_compile attempted to execute unexpectedly ERROR: Task dwarfsrcfiles-native.do_compile attempted to execute unexpectedly ERROR: Task rpm-native.do_install attempted to execute unexpectedly ERROR: Task dwarfsrcfiles-native.do_install attempted to execute unexpectedly ERROR: Task rpm-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dwarfsrcfiles-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task util-macros-native.do_fetch attempted to execute unexpectedly ERROR: Task gtk-doc-native.do_fetch attempted to execute unexpectedly ERROR: Task perl-native.do_fetch attempted to execute unexpectedly ERROR: Task shadow-native.do_fetch attempted to execute unexpectedly ERROR: Task util-macros-native.do_unpack attempted to execute unexpectedly ERROR: Task util-macros-native.do_patch attempted to execute unexpectedly ERROR: Task util-macros-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task util-macros-native.do_configure attempted to execute unexpectedly ERROR: Task util-macros-native.do_compile attempted to execute unexpectedly ERROR: Task util-macros-native.do_install attempted to execute unexpectedly ERROR: Task util-macros-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gtk-doc-native.do_unpack attempted to execute unexpectedly ERROR: Task gtk-doc-native.do_patch attempted to execute unexpectedly ERROR: Task gtk-doc-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gtk-doc-native.do_configure attempted to execute unexpectedly ERROR: Task gtk-doc-native.do_compile attempted to execute unexpectedly ERROR: Task gtk-doc-native.do_install attempted to execute unexpectedly ERROR: Task gtk-doc-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task xproto-native.do_fetch attempted to execute unexpectedly ERROR: Task libffi-native.do_fetch attempted to execute unexpectedly ERROR: Task libpcre-native.do_fetch attempted to execute unexpectedly ERROR: Task glib-2.0-native.do_fetch attempted to execute unexpectedly ERROR: Task perl-native.do_unpack attempted to execute unexpectedly ERROR: Task perl-native.do_patch attempted to execute unexpectedly ERROR: Task perl-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task perl-native.do_configure attempted to execute unexpectedly ERROR: Task perl-native.do_compile attempted to execute unexpectedly ERROR: Task perl-native.do_install attempted to execute unexpectedly ERROR: Task perl-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task re2c-native.do_fetch attempted to execute unexpectedly ERROR: Task ninja-native.do_fetch attempted to execute unexpectedly ERROR: Task libxml-parser-perl-native.do_fetch attempted to execute unexpectedly ERROR: Task intltool-native.do_fetch attempted to execute unexpectedly ERROR: Task unzip-native.do_fetch attempted to execute unexpectedly ERROR: Task python3-setuptools-native.do_fetch attempted to execute unexpectedly ERROR: Task meson-native.do_fetch attempted to execute unexpectedly ERROR: Task systemd.do_fetch attempted to execute unexpectedly ERROR: Task shadow-native.do_unpack attempted to execute unexpectedly ERROR: Task shadow-native.do_patch attempted to execute unexpectedly ERROR: Task shadow-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task shadow-native.do_configure attempted to execute unexpectedly ERROR: Task shadow-native.do_compile attempted to execute unexpectedly ERROR: Task shadow-native.do_install attempted to execute unexpectedly ERROR: Task shadow-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dbus.do_fetch attempted to execute unexpectedly ERROR: Task xproto-native.do_unpack attempted to execute unexpectedly ERROR: Task xproto-native.do_patch attempted to execute unexpectedly ERROR: Task xproto-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task xproto-native.do_configure attempted to execute unexpectedly ERROR: Task xproto-native.do_compile attempted to execute unexpectedly ERROR: Task xproto-native.do_install attempted to execute unexpectedly ERROR: Task xproto-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libffi-native.do_unpack attempted to execute unexpectedly ERROR: Task libffi-native.do_patch attempted to execute unexpectedly ERROR: Task libffi-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libffi-native.do_configure attempted to execute unexpectedly ERROR: Task libffi-native.do_compile attempted to execute unexpectedly ERROR: Task libffi-native.do_install attempted to execute unexpectedly ERROR: Task libffi-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libpcre-native.do_unpack attempted to execute unexpectedly ERROR: Task libpcre-native.do_patch attempted to execute unexpectedly ERROR: Task libpcre-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libpcre-native.do_configure attempted to execute unexpectedly ERROR: Task libpcre-native.do_compile attempted to execute unexpectedly ERROR: Task libpcre-native.do_install attempted to execute unexpectedly ERROR: Task libpcre-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task glib-2.0-native.do_unpack attempted to execute unexpectedly ERROR: Task glib-2.0-native.do_patch attempted to execute unexpectedly ERROR: Task glib-2.0-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task glib-2.0-native.do_configure attempted to execute unexpectedly ERROR: Task glib-2.0-native.do_compile attempted to execute unexpectedly ERROR: Task glib-2.0-native.do_install attempted to execute unexpectedly ERROR: Task glib-2.0-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task re2c-native.do_unpack attempted to execute unexpectedly ERROR: Task re2c-native.do_patch attempted to execute unexpectedly ERROR: Task ninja-native.do_unpack attempted to execute unexpectedly ERROR: Task ninja-native.do_patch attempted to execute unexpectedly ERROR: Task re2c-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task re2c-native.do_configure attempted to execute unexpectedly ERROR: Task re2c-native.do_compile attempted to execute unexpectedly ERROR: Task re2c-native.do_install attempted to execute unexpectedly ERROR: Task re2c-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task ninja-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task ninja-native.do_compile attempted to execute unexpectedly ERROR: Task ninja-native.do_install attempted to execute unexpectedly ERROR: Task ninja-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxml-parser-perl-native.do_unpack attempted to execute unexpectedly ERROR: Task libxml-parser-perl-native.do_patch attempted to execute unexpectedly ERROR: Task libxml-parser-perl-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxml-parser-perl-native.do_configure attempted to execute unexpectedly ERROR: Task libxml-parser-perl-native.do_compile attempted to execute unexpectedly ERROR: Task libxml-parser-perl-native.do_install attempted to execute unexpectedly ERROR: Task libxml-parser-perl-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task intltool-native.do_unpack attempted to execute unexpectedly ERROR: Task intltool-native.do_patch attempted to execute unexpectedly ERROR: Task intltool-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task intltool-native.do_configure attempted to execute unexpectedly ERROR: Task intltool-native.do_compile attempted to execute unexpectedly ERROR: Task intltool-native.do_install attempted to execute unexpectedly ERROR: Task intltool-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task unzip-native.do_unpack attempted to execute unexpectedly ERROR: Task unzip-native.do_patch attempted to execute unexpectedly ERROR: Task unzip-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task unzip-native.do_configure attempted to execute unexpectedly ERROR: Task unzip-native.do_compile attempted to execute unexpectedly ERROR: Task unzip-native.do_install attempted to execute unexpectedly ERROR: Task unzip-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task python3-setuptools-native.do_unpack attempted to execute unexpectedly ERROR: Task python3-setuptools-native.do_patch attempted to execute unexpectedly ERROR: Task python3-setuptools-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task python3-setuptools-native.do_configure attempted to execute unexpectedly ERROR: Task python3-setuptools-native.do_compile attempted to execute unexpectedly ERROR: Task python3-setuptools-native.do_install attempted to execute unexpectedly ERROR: Task python3-setuptools-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task meson-native.do_unpack attempted to execute unexpectedly ERROR: Task meson-native.do_patch attempted to execute unexpectedly ERROR: Task meson-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task meson-native.do_configure attempted to execute unexpectedly ERROR: Task meson-native.do_compile attempted to execute unexpectedly ERROR: Task meson-native.do_install attempted to execute unexpectedly ERROR: Task meson-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task systemd.do_unpack attempted to execute unexpectedly ERROR: Task systemd.do_patch attempted to execute unexpectedly ERROR: Task systemd.do_write_config attempted to execute unexpectedly ERROR: Task systemd.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task systemd.do_configure attempted to execute unexpectedly ERROR: Task systemd.do_compile attempted to execute unexpectedly ERROR: Task systemd.do_install attempted to execute unexpectedly ERROR: Task systemd.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dbus.do_unpack attempted to execute unexpectedly ERROR: Task dbus.do_patch attempted to execute unexpectedly ERROR: Task dbus.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task dbus.do_configure attempted to execute unexpectedly ERROR: Task dbus.do_compile attempted to execute unexpectedly ERROR: Task dbus.do_install attempted to execute unexpectedly ERROR: Task dbus.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task xextproto-native.do_fetch attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_fetch attempted to execute unexpectedly ERROR: Task libxdmcp-native.do_fetch attempted to execute unexpectedly ERROR: Task libpthread-stubs-native.do_fetch attempted to execute unexpectedly ERROR: Task libxau-native.do_fetch attempted to execute unexpectedly ERROR: Task xtrans-native.do_fetch attempted to execute unexpectedly ERROR: Task kbproto-native.do_fetch attempted to execute unexpectedly ERROR: Task inputproto-native.do_fetch attempted to execute unexpectedly ERROR: Task libxcb-native.do_fetch attempted to execute unexpectedly ERROR: Task libx11-native.do_fetch attempted to execute unexpectedly ERROR: Task xextproto-native.do_unpack attempted to execute unexpectedly ERROR: Task xextproto-native.do_patch attempted to execute unexpectedly ERROR: Task xextproto-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task xextproto-native.do_configure attempted to execute unexpectedly ERROR: Task xextproto-native.do_compile attempted to execute unexpectedly ERROR: Task xextproto-native.do_install attempted to execute unexpectedly ERROR: Task xextproto-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxdmcp-native.do_unpack attempted to execute unexpectedly ERROR: Task libxau-native.do_unpack attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_unpack attempted to execute unexpectedly ERROR: Task libpthread-stubs-native.do_unpack attempted to execute unexpectedly ERROR: Task libxau-native.do_patch attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_patch attempted to execute unexpectedly ERROR: Task libxdmcp-native.do_patch attempted to execute unexpectedly ERROR: Task libpthread-stubs-native.do_patch attempted to execute unexpectedly ERROR: Task kbproto-native.do_unpack attempted to execute unexpectedly ERROR: Task inputproto-native.do_unpack attempted to execute unexpectedly ERROR: Task xtrans-native.do_unpack attempted to execute unexpectedly ERROR: Task libxcb-native.do_unpack attempted to execute unexpectedly ERROR: Task kbproto-native.do_patch attempted to execute unexpectedly ERROR: Task inputproto-native.do_patch attempted to execute unexpectedly ERROR: Task libxcb-native.do_patch attempted to execute unexpectedly ERROR: Task xtrans-native.do_patch attempted to execute unexpectedly ERROR: Task libx11-native.do_unpack attempted to execute unexpectedly ERROR: Task libx11-native.do_patch attempted to execute unexpectedly ERROR: Task libxau-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxdmcp-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libpthread-stubs-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxdmcp-native.do_configure attempted to execute unexpectedly ERROR: Task libpthread-stubs-native.do_configure attempted to execute unexpectedly ERROR: Task libxau-native.do_configure attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_configure attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_compile attempted to execute unexpectedly ERROR: Task libxdmcp-native.do_compile attempted to execute unexpectedly ERROR: Task libpthread-stubs-native.do_compile attempted to execute unexpectedly ERROR: Task libxau-native.do_compile attempted to execute unexpectedly ERROR: Task libxdmcp-native.do_install attempted to execute unexpectedly ERROR: Task libxau-native.do_install attempted to execute unexpectedly ERROR: Task libpthread-stubs-native.do_install attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_install attempted to execute unexpectedly ERROR: Task xcb-proto-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxdmcp-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libpthread-stubs-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxau-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task xtrans-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task inputproto-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxcb-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task kbproto-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxcb-native.do_configure attempted to execute unexpectedly ERROR: Task kbproto-native.do_configure attempted to execute unexpectedly ERROR: Task inputproto-native.do_configure attempted to execute unexpectedly ERROR: Task xtrans-native.do_configure attempted to execute unexpectedly ERROR: Task inputproto-native.do_compile attempted to execute unexpectedly ERROR: Task libxcb-native.do_compile attempted to execute unexpectedly ERROR: Task kbproto-native.do_compile attempted to execute unexpectedly ERROR: Task xtrans-native.do_compile attempted to execute unexpectedly ERROR: Task libxcb-native.do_install attempted to execute unexpectedly ERROR: Task xtrans-native.do_install attempted to execute unexpectedly ERROR: Task kbproto-native.do_install attempted to execute unexpectedly ERROR: Task inputproto-native.do_install attempted to execute unexpectedly ERROR: Task inputproto-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task kbproto-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task xtrans-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxcb-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libx11-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libx11-native.do_configure attempted to execute unexpectedly ERROR: Task libx11-native.do_compile attempted to execute unexpectedly ERROR: Task libx11-native.do_install attempted to execute unexpectedly ERROR: Task libx11-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task renderproto-native.do_fetch attempted to execute unexpectedly ERROR: Task libxext-native.do_fetch attempted to execute unexpectedly ERROR: Task libxrender-native.do_fetch attempted to execute unexpectedly ERROR: Task libpng-native.do_fetch attempted to execute unexpectedly ERROR: Task dtc-native.do_fetch attempted to execute unexpectedly ERROR: Task randrproto-native.do_fetch attempted to execute unexpectedly ERROR: Task renderproto-native.do_unpack attempted to execute unexpectedly ERROR: Task renderproto-native.do_patch attempted to execute unexpectedly ERROR: Task libxrandr-native.do_fetch attempted to execute unexpectedly ERROR: Task libxrender-native.do_unpack attempted to execute unexpectedly ERROR: Task libxext-native.do_unpack attempted to execute unexpectedly ERROR: Task libxext-native.do_patch attempted to execute unexpectedly ERROR: Task libxrender-native.do_patch attempted to execute unexpectedly ERROR: Task libsdl-native.do_fetch attempted to execute unexpectedly ERROR: Task pixman-native.do_fetch attempted to execute unexpectedly ERROR: Task alsa-lib-native.do_fetch attempted to execute unexpectedly ERROR: Task qemu-native.do_fetch attempted to execute unexpectedly ERROR: Task renderproto-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task renderproto-native.do_configure attempted to execute unexpectedly ERROR: Task renderproto-native.do_compile attempted to execute unexpectedly ERROR: Task renderproto-native.do_install attempted to execute unexpectedly ERROR: Task renderproto-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxrender-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxext-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxext-native.do_configure attempted to execute unexpectedly ERROR: Task libxrender-native.do_configure attempted to execute unexpectedly ERROR: Task libxrender-native.do_compile attempted to execute unexpectedly ERROR: Task libxext-native.do_compile attempted to execute unexpectedly ERROR: Task libxext-native.do_install attempted to execute unexpectedly ERROR: Task libxrender-native.do_install attempted to execute unexpectedly ERROR: Task libxext-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxrender-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gobject-introspection-native.do_fetch attempted to execute unexpectedly ERROR: Task binutils-native.do_fetch attempted to execute unexpectedly ERROR: Task prelink-native.do_fetch attempted to execute unexpectedly ERROR: Task wayland-native.do_fetch attempted to execute unexpectedly ERROR: Task libpng-native.do_unpack attempted to execute unexpectedly ERROR: Task libpng-native.do_patch attempted to execute unexpectedly ERROR: Task libpng-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libpng-native.do_configure attempted to execute unexpectedly ERROR: Task libpng-native.do_compile attempted to execute unexpectedly ERROR: Task libpng-native.do_install attempted to execute unexpectedly ERROR: Task libpng-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task icu-native.do_fetch attempted to execute unexpectedly ERROR: Task dtc-native.do_unpack attempted to execute unexpectedly ERROR: Task dtc-native.do_patch attempted to execute unexpectedly ERROR: Task dtc-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task dtc-native.do_configure attempted to execute unexpectedly ERROR: Task dtc-native.do_compile attempted to execute unexpectedly ERROR: Task dtc-native.do_install attempted to execute unexpectedly ERROR: Task dtc-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task randrproto-native.do_unpack attempted to execute unexpectedly ERROR: Task randrproto-native.do_patch attempted to execute unexpectedly ERROR: Task libxrandr-native.do_unpack attempted to execute unexpectedly ERROR: Task libxrandr-native.do_patch attempted to execute unexpectedly ERROR: Task pixman-native.do_unpack attempted to execute unexpectedly ERROR: Task libsdl-native.do_unpack attempted to execute unexpectedly ERROR: Task alsa-lib-native.do_unpack attempted to execute unexpectedly ERROR: Task libsdl-native.do_patch attempted to execute unexpectedly ERROR: Task pixman-native.do_patch attempted to execute unexpectedly ERROR: Task alsa-lib-native.do_patch attempted to execute unexpectedly ERROR: Task qemu-native.do_unpack attempted to execute unexpectedly ERROR: Task qemu-native.do_patch attempted to execute unexpectedly ERROR: Task randrproto-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task randrproto-native.do_configure attempted to execute unexpectedly ERROR: Task randrproto-native.do_compile attempted to execute unexpectedly ERROR: Task randrproto-native.do_install attempted to execute unexpectedly ERROR: Task randrproto-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libxrandr-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libxrandr-native.do_configure attempted to execute unexpectedly ERROR: Task libxrandr-native.do_compile attempted to execute unexpectedly ERROR: Task libxrandr-native.do_install attempted to execute unexpectedly ERROR: Task libxrandr-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libsdl-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task pixman-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task alsa-lib-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libsdl-native.do_configure attempted to execute unexpectedly ERROR: Task pixman-native.do_configure attempted to execute unexpectedly ERROR: Task alsa-lib-native.do_configure attempted to execute unexpectedly ERROR: Task pixman-native.do_compile attempted to execute unexpectedly ERROR: Task alsa-lib-native.do_compile attempted to execute unexpectedly ERROR: Task libsdl-native.do_compile attempted to execute unexpectedly ERROR: Task pixman-native.do_install attempted to execute unexpectedly ERROR: Task alsa-lib-native.do_install attempted to execute unexpectedly ERROR: Task libsdl-native.do_install attempted to execute unexpectedly ERROR: Task libsdl-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task pixman-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task alsa-lib-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task qemu-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task qemu-native.do_configure attempted to execute unexpectedly ERROR: Task qemu-native.do_compile attempted to execute unexpectedly ERROR: Task qemu-native.do_install attempted to execute unexpectedly ERROR: Task qemu-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gobject-introspection-native.do_unpack attempted to execute unexpectedly ERROR: Task gobject-introspection-native.do_patch attempted to execute unexpectedly ERROR: Task gobject-introspection-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gobject-introspection-native.do_configure attempted to execute unexpectedly ERROR: Task gobject-introspection-native.do_compile attempted to execute unexpectedly ERROR: Task gobject-introspection-native.do_install attempted to execute unexpectedly ERROR: Task gobject-introspection-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task binutils-native.do_unpack attempted to execute unexpectedly ERROR: Task binutils-native.do_patch attempted to execute unexpectedly ERROR: Task prelink-native.do_unpack attempted to execute unexpectedly ERROR: Task prelink-native.do_patch attempted to execute unexpectedly ERROR: Task binutils-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task binutils-native.do_configure attempted to execute unexpectedly ERROR: Task binutils-native.do_compile attempted to execute unexpectedly ERROR: Task binutils-native.do_install attempted to execute unexpectedly ERROR: Task binutils-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task prelink-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task prelink-native.do_configure attempted to execute unexpectedly ERROR: Task prelink-native.do_compile attempted to execute unexpectedly ERROR: Task prelink-native.do_install attempted to execute unexpectedly ERROR: Task prelink-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task wayland-native.do_unpack attempted to execute unexpectedly ERROR: Task wayland-native.do_patch attempted to execute unexpectedly ERROR: Task wayland-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task wayland-native.do_configure attempted to execute unexpectedly ERROR: Task wayland-native.do_compile attempted to execute unexpectedly ERROR: Task wayland-native.do_install attempted to execute unexpectedly ERROR: Task wayland-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task curl-native.do_fetch attempted to execute unexpectedly ERROR: Task cmake-native.do_fetch attempted to execute unexpectedly ERROR: Task icu-native.do_unpack attempted to execute unexpectedly ERROR: Task icu-native.do_patch attempted to execute unexpectedly ERROR: Task icu-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task icu-native.do_configure attempted to execute unexpectedly ERROR: Task icu-native.do_compile attempted to execute unexpectedly ERROR: Task icu-native.do_install attempted to execute unexpectedly ERROR: Task icu-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dbus-glib-native.do_fetch attempted to execute unexpectedly ERROR: Task opkg-utils-native.do_fetch attempted to execute unexpectedly ERROR: Task dpkg-native.do_fetch attempted to execute unexpectedly ERROR: Task cross-localedef-native.do_fetch attempted to execute unexpectedly ERROR: Task linux-imx.do_fetch attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_fetch attempted to execute unexpectedly ERROR: Task curl-native.do_unpack attempted to execute unexpectedly ERROR: Task curl-native.do_patch attempted to execute unexpectedly ERROR: Task cmake-native.do_unpack attempted to execute unexpectedly ERROR: Task cmake-native.do_patch attempted to execute unexpectedly ERROR: Task curl-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task curl-native.do_configure attempted to execute unexpectedly ERROR: Task curl-native.do_compile attempted to execute unexpectedly ERROR: Task curl-native.do_install attempted to execute unexpectedly ERROR: Task curl-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task cmake-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task cmake-native.do_configure attempted to execute unexpectedly ERROR: Task cmake-native.do_compile attempted to execute unexpectedly ERROR: Task cmake-native.do_install attempted to execute unexpectedly ERROR: Task cmake-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task linux-imx.do_unpack attempted to execute unexpectedly ERROR: Task dbus-glib-native.do_unpack attempted to execute unexpectedly ERROR: Task dbus-glib-native.do_patch attempted to execute unexpectedly ERROR: Task dbus-glib-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task dbus-glib-native.do_configure attempted to execute unexpectedly ERROR: Task dbus-glib-native.do_compile attempted to execute unexpectedly ERROR: Task dbus-glib-native.do_install attempted to execute unexpectedly ERROR: Task dbus-glib-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task opkg-utils-native.do_unpack attempted to execute unexpectedly ERROR: Task opkg-utils-native.do_patch attempted to execute unexpectedly ERROR: Task opkg-utils-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task opkg-utils-native.do_configure attempted to execute unexpectedly ERROR: Task opkg-utils-native.do_compile attempted to execute unexpectedly ERROR: Task opkg-utils-native.do_install attempted to execute unexpectedly ERROR: Task opkg-utils-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dpkg-native.do_unpack attempted to execute unexpectedly ERROR: Task dpkg-native.do_patch attempted to execute unexpectedly ERROR: Task dpkg-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task dpkg-native.do_configure attempted to execute unexpectedly ERROR: Task dpkg-native.do_compile attempted to execute unexpectedly ERROR: Task dpkg-native.do_install attempted to execute unexpectedly ERROR: Task dpkg-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task cross-localedef-native.do_unpack attempted to execute unexpectedly ERROR: Task cross-localedef-native.do_patch attempted to execute unexpectedly ERROR: Task cross-localedef-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task cross-localedef-native.do_configure attempted to execute unexpectedly ERROR: Task cross-localedef-native.do_compile attempted to execute unexpectedly ERROR: Task cross-localedef-native.do_install attempted to execute unexpectedly ERROR: Task cross-localedef-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task linux-imx.do_patch attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_unpack attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_patch attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_configure attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_compile attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_install attempted to execute unexpectedly ERROR: Task shared-mime-info-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task libjpeg-turbo-native.do_fetch attempted to execute unexpectedly ERROR: Task gdk-pixbuf-native.do_fetch attempted to execute unexpectedly ERROR: Task protobuf-native.do_fetch attempted to execute unexpectedly ERROR: Task kmod-native.do_fetch attempted to execute unexpectedly ERROR: Task bc-native.do_fetch attempted to execute unexpectedly ERROR: Task lzop-native.do_fetch attempted to execute unexpectedly ERROR: Task libjpeg-turbo-native.do_unpack attempted to execute unexpectedly ERROR: Task libjpeg-turbo-native.do_patch attempted to execute unexpectedly ERROR: Task gdk-pixbuf-native.do_unpack attempted to execute unexpectedly ERROR: Task gdk-pixbuf-native.do_patch attempted to execute unexpectedly ERROR: Task libjpeg-turbo-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libjpeg-turbo-native.do_configure attempted to execute unexpectedly ERROR: Task libjpeg-turbo-native.do_compile attempted to execute unexpectedly ERROR: Task libjpeg-turbo-native.do_install attempted to execute unexpectedly ERROR: Task libjpeg-turbo-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task gdk-pixbuf-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gdk-pixbuf-native.do_configure attempted to execute unexpectedly ERROR: Task gdk-pixbuf-native.do_compile attempted to execute unexpectedly ERROR: Task gdk-pixbuf-native.do_install attempted to execute unexpectedly ERROR: Task gdk-pixbuf-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task protobuf-native.do_unpack attempted to execute unexpectedly ERROR: Task protobuf-native.do_patch attempted to execute unexpectedly ERROR: Task kmod-native.do_unpack attempted to execute unexpectedly ERROR: Task kmod-native.do_patch attempted to execute unexpectedly ERROR: Task protobuf-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task protobuf-native.do_configure attempted to execute unexpectedly ERROR: Task protobuf-native.do_compile attempted to execute unexpectedly ERROR: Task protobuf-native.do_install attempted to execute unexpectedly ERROR: Task protobuf-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task kmod-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task kmod-native.do_configure attempted to execute unexpectedly ERROR: Task kmod-native.do_compile attempted to execute unexpectedly ERROR: Task kmod-native.do_install attempted to execute unexpectedly ERROR: Task kmod-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task bc-native.do_unpack attempted to execute unexpectedly ERROR: Task bc-native.do_patch attempted to execute unexpectedly ERROR: Task bc-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task bc-native.do_configure attempted to execute unexpectedly ERROR: Task bc-native.do_compile attempted to execute unexpectedly ERROR: Task bc-native.do_install attempted to execute unexpectedly ERROR: Task bc-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task lzop-native.do_unpack attempted to execute unexpectedly ERROR: Task lzop-native.do_patch attempted to execute unexpectedly ERROR: Task lzop-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task lzop-native.do_configure attempted to execute unexpectedly ERROR: Task lzop-native.do_compile attempted to execute unexpectedly ERROR: Task lzop-native.do_install attempted to execute unexpectedly ERROR: Task lzop-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task linux-imx.do_copy_defconfig attempted to execute unexpectedly ERROR: Task linux-imx.do_preconfigure attempted to execute unexpectedly ERROR: Task linux-imx.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task linux-imx.do_configure attempted to execute unexpectedly ERROR: Task linux-imx.do_compile attempted to execute unexpectedly ERROR: Task orc-native.do_fetch attempted to execute unexpectedly ERROR: Task groff-native.do_fetch attempted to execute unexpectedly ERROR: Task orc-native.do_unpack attempted to execute unexpectedly ERROR: Task orc-native.do_patch attempted to execute unexpectedly ERROR: Task orc-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task orc-native.do_configure attempted to execute unexpectedly ERROR: Task orc-native.do_compile attempted to execute unexpectedly ERROR: Task orc-native.do_install attempted to execute unexpectedly ERROR: Task orc-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task nasm-native.do_fetch attempted to execute unexpectedly ERROR: Task avahi.do_fetch attempted to execute unexpectedly ERROR: Task python-native.do_fetch attempted to execute unexpectedly ERROR: Task yasm-native.do_fetch attempted to execute unexpectedly ERROR: Task kern-tools-native.do_fetch attempted to execute unexpectedly ERROR: Task openssh.do_fetch attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_fetch attempted to execute unexpectedly ERROR: Task groff-native.do_unpack attempted to execute unexpectedly ERROR: Task groff-native.do_patch attempted to execute unexpectedly ERROR: Task groff-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task groff-native.do_configure attempted to execute unexpectedly ERROR: Task groff-native.do_compile attempted to execute unexpectedly ERROR: Task groff-native.do_install attempted to execute unexpectedly ERROR: Task groff-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task nasm-native.do_unpack attempted to execute unexpectedly ERROR: Task nasm-native.do_patch attempted to execute unexpectedly ERROR: Task nasm-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task nasm-native.do_configure attempted to execute unexpectedly ERROR: Task nasm-native.do_compile attempted to execute unexpectedly ERROR: Task nasm-native.do_install attempted to execute unexpectedly ERROR: Task nasm-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task avahi.do_unpack attempted to execute unexpectedly ERROR: Task avahi.do_patch attempted to execute unexpectedly ERROR: Task python-native.do_unpack attempted to execute unexpectedly ERROR: Task python-native.do_patch attempted to execute unexpectedly ERROR: Task avahi.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task avahi.do_configure attempted to execute unexpectedly ERROR: Task avahi.do_compile attempted to execute unexpectedly ERROR: Task avahi.do_install attempted to execute unexpectedly ERROR: Task python-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task python-native.do_configure attempted to execute unexpectedly ERROR: Task python-native.do_compile attempted to execute unexpectedly ERROR: Task python-native.do_install attempted to execute unexpectedly ERROR: Task python-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task tcl-native.do_fetch attempted to execute unexpectedly ERROR: Task swig-native.do_fetch attempted to execute unexpectedly ERROR: Task pulseaudio.do_fetch attempted to execute unexpectedly ERROR: Task tzcode-native.do_fetch attempted to execute unexpectedly ERROR: Task cwautomacros-native.do_fetch attempted to execute unexpectedly ERROR: Task yasm-native.do_unpack attempted to execute unexpectedly ERROR: Task yasm-native.do_patch attempted to execute unexpectedly ERROR: Task yasm-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task yasm-native.do_configure attempted to execute unexpectedly ERROR: Task yasm-native.do_compile attempted to execute unexpectedly ERROR: Task yasm-native.do_install attempted to execute unexpectedly ERROR: Task yasm-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task kern-tools-native.do_unpack attempted to execute unexpectedly ERROR: Task kern-tools-native.do_patch attempted to execute unexpectedly ERROR: Task kern-tools-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task kern-tools-native.do_configure attempted to execute unexpectedly ERROR: Task kern-tools-native.do_compile attempted to execute unexpectedly ERROR: Task kern-tools-native.do_install attempted to execute unexpectedly ERROR: Task kern-tools-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task openssh.do_unpack attempted to execute unexpectedly ERROR: Task openssh.do_patch attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_unpack attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_patch attempted to execute unexpectedly ERROR: Task openssh.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task openssh.do_configure attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_configure attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_compile attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_install attempted to execute unexpectedly ERROR: Task update-rc.d-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task chrpath-native.do_fetch attempted to execute unexpectedly ERROR: Task avahi.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task tcl-native.do_unpack attempted to execute unexpectedly ERROR: Task tcl-native.do_patch attempted to execute unexpectedly ERROR: Task swig-native.do_unpack attempted to execute unexpectedly ERROR: Task swig-native.do_patch attempted to execute unexpectedly ERROR: Task tcl-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task tcl-native.do_configure attempted to execute unexpectedly ERROR: Task tcl-native.do_compile attempted to execute unexpectedly ERROR: Task tcl-native.do_install attempted to execute unexpectedly ERROR: Task tcl-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task swig-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task swig-native.do_configure attempted to execute unexpectedly ERROR: Task swig-native.do_compile attempted to execute unexpectedly ERROR: Task swig-native.do_install attempted to execute unexpectedly ERROR: Task swig-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task pulseaudio.do_unpack attempted to execute unexpectedly ERROR: Task pulseaudio.do_patch attempted to execute unexpectedly ERROR: Task pulseaudio.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task pulseaudio.do_configure attempted to execute unexpectedly ERROR: Task pulseaudio.do_compile attempted to execute unexpectedly ERROR: Task pulseaudio.do_install attempted to execute unexpectedly ERROR: Task tzcode-native.do_unpack attempted to execute unexpectedly ERROR: Task tzcode-native.do_patch attempted to execute unexpectedly ERROR: Task makedepend-native.do_fetch attempted to execute unexpectedly ERROR: Task python3-mako-native.do_fetch attempted to execute unexpectedly ERROR: Task cwautomacros-native.do_unpack attempted to execute unexpectedly ERROR: Task cwautomacros-native.do_patch attempted to execute unexpectedly ERROR: Task tzcode-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task tzcode-native.do_configure attempted to execute unexpectedly ERROR: Task tzcode-native.do_compile attempted to execute unexpectedly ERROR: Task tzcode-native.do_install attempted to execute unexpectedly ERROR: Task tzcode-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task cwautomacros-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task cwautomacros-native.do_configure attempted to execute unexpectedly ERROR: Task cwautomacros-native.do_compile attempted to execute unexpectedly ERROR: Task cwautomacros-native.do_install attempted to execute unexpectedly ERROR: Task cwautomacros-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task openssh.do_configure_ptest_base attempted to execute unexpectedly ERROR: Task openssh.do_compile attempted to execute unexpectedly ERROR: Task chrpath-native.do_unpack attempted to execute unexpectedly ERROR: Task chrpath-native.do_patch attempted to execute unexpectedly ERROR: Task chrpath-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task chrpath-native.do_configure attempted to execute unexpectedly ERROR: Task chrpath-native.do_compile attempted to execute unexpectedly ERROR: Task chrpath-native.do_install attempted to execute unexpectedly ERROR: Task chrpath-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task python3-mako-native.do_unpack attempted to execute unexpectedly ERROR: Task makedepend-native.do_unpack attempted to execute unexpectedly ERROR: Task python3-mako-native.do_patch attempted to execute unexpectedly ERROR: Task makedepend-native.do_patch attempted to execute unexpectedly ERROR: Task lzip-native.do_fetch attempted to execute unexpectedly ERROR: Task rpcbind.do_fetch attempted to execute unexpectedly ERROR: Task makedepend-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task python3-mako-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task python3-mako-native.do_configure attempted to execute unexpectedly ERROR: Task makedepend-native.do_configure attempted to execute unexpectedly ERROR: Task makedepend-native.do_compile attempted to execute unexpectedly ERROR: Task python3-mako-native.do_compile attempted to execute unexpectedly ERROR: Task makedepend-native.do_install attempted to execute unexpectedly ERROR: Task python3-mako-native.do_install attempted to execute unexpectedly ERROR: Task makedepend-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task python3-mako-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task glslang-native.do_fetch attempted to execute unexpectedly ERROR: Task pulseaudio.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task nfs-utils.do_fetch attempted to execute unexpectedly ERROR: Task openssh.do_compile_ptest_base attempted to execute unexpectedly ERROR: Task openssh.do_install attempted to execute unexpectedly ERROR: Task python-scons-native.do_fetch attempted to execute unexpectedly ERROR: Task glslang-native.do_unpack attempted to execute unexpectedly ERROR: Task glslang-native.do_patch attempted to execute unexpectedly ERROR: Task cronie.do_fetch attempted to execute unexpectedly ERROR: Task lzip-native.do_unpack attempted to execute unexpectedly ERROR: Task lzip-native.do_patch attempted to execute unexpectedly ERROR: Task rpcbind.do_unpack attempted to execute unexpectedly ERROR: Task rpcbind.do_patch attempted to execute unexpectedly ERROR: Task apt.do_fetch attempted to execute unexpectedly ERROR: Task lzip-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task lzip-native.do_configure attempted to execute unexpectedly ERROR: Task lzip-native.do_compile attempted to execute unexpectedly ERROR: Task lzip-native.do_install attempted to execute unexpectedly ERROR: Task lzip-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task rpcbind.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task rpcbind.do_configure attempted to execute unexpectedly ERROR: Task rpcbind.do_compile attempted to execute unexpectedly ERROR: Task rpcbind.do_install attempted to execute unexpectedly ERROR: Task nfs-utils.do_unpack attempted to execute unexpectedly ERROR: Task nfs-utils.do_patch attempted to execute unexpectedly ERROR: Task python-scons-native.do_unpack attempted to execute unexpectedly ERROR: Task python-scons-native.do_patch attempted to execute unexpectedly ERROR: Task cronie.do_unpack attempted to execute unexpectedly ERROR: Task cronie.do_patch attempted to execute unexpectedly ERROR: Task nfs-utils.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task nfs-utils.do_configure attempted to execute unexpectedly ERROR: Task nfs-utils.do_compile attempted to execute unexpectedly ERROR: Task nfs-utils.do_install attempted to execute unexpectedly ERROR: Task openssh.do_install_ptest_base attempted to execute unexpectedly ERROR: Task debianutils-native.do_fetch attempted to execute unexpectedly ERROR: Task apt.do_unpack attempted to execute unexpectedly ERROR: Task apt.do_patch attempted to execute unexpectedly ERROR: Task glslang-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task glslang-native.do_generate_toolchain_file attempted to execute unexpectedly ERROR: Task python-scons-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task glslang-native.do_configure attempted to execute unexpectedly ERROR: Task python-scons-native.do_configure attempted to execute unexpectedly ERROR: Task python-scons-native.do_compile attempted to execute unexpectedly ERROR: Task glslang-native.do_compile attempted to execute unexpectedly ERROR: Task python-scons-native.do_install attempted to execute unexpectedly ERROR: Task glslang-native.do_install attempted to execute unexpectedly ERROR: Task python-scons-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task glslang-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task cronie.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task cronie.do_configure attempted to execute unexpectedly ERROR: Task cronie.do_compile attempted to execute unexpectedly ERROR: Task cronie.do_install attempted to execute unexpectedly ERROR: Task mklibs-native.do_fetch attempted to execute unexpectedly ERROR: Task pbzip2-native.do_fetch attempted to execute unexpectedly ERROR: Task apt-native.do_fetch attempted to execute unexpectedly ERROR: Task ldconfig-native.do_fetch attempted to execute unexpectedly ERROR: Task pigz-native.do_fetch attempted to execute unexpectedly ERROR: Task makedevs-native.do_fetch attempted to execute unexpectedly ERROR: Task apt.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task apt.do_configure attempted to execute unexpectedly ERROR: Task apt.do_compile attempted to execute unexpectedly ERROR: Task apt.do_install attempted to execute unexpectedly ERROR: Task debianutils-native.do_unpack attempted to execute unexpectedly ERROR: Task debianutils-native.do_patch attempted to execute unexpectedly ERROR: Task ldconfig-native.do_unpack attempted to execute unexpectedly ERROR: Task mklibs-native.do_unpack attempted to execute unexpectedly ERROR: Task pbzip2-native.do_unpack attempted to execute unexpectedly ERROR: Task pigz-native.do_unpack attempted to execute unexpectedly ERROR: Task apt-native.do_unpack attempted to execute unexpectedly ERROR: Task makedevs-native.do_unpack attempted to execute unexpectedly ERROR: Task makedevs-native.do_patch attempted to execute unexpectedly ERROR: Task mklibs-native.do_patch attempted to execute unexpectedly ERROR: Task pigz-native.do_patch attempted to execute unexpectedly ERROR: Task apt-native.do_patch attempted to execute unexpectedly ERROR: Task ldconfig-native.do_patch attempted to execute unexpectedly ERROR: Task pbzip2-native.do_patch attempted to execute unexpectedly ERROR: Task debianutils-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task debianutils-native.do_configure attempted to execute unexpectedly ERROR: Task debianutils-native.do_compile attempted to execute unexpectedly ERROR: Task debianutils-native.do_install attempted to execute unexpectedly ERROR: Task debianutils-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task mklibs-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task pbzip2-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task pigz-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task ldconfig-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task makedevs-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task apt-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task apt-native.do_configure attempted to execute unexpectedly ERROR: Task pbzip2-native.do_configure attempted to execute unexpectedly ERROR: Task ldconfig-native.do_configure attempted to execute unexpectedly ERROR: Task mklibs-native.do_configure attempted to execute unexpectedly ERROR: Task makedevs-native.do_configure attempted to execute unexpectedly ERROR: Task pigz-native.do_configure attempted to execute unexpectedly ERROR: Task ldconfig-native.do_compile attempted to execute unexpectedly ERROR: Task mklibs-native.do_compile attempted to execute unexpectedly ERROR: Task makedevs-native.do_compile attempted to execute unexpectedly ERROR: Task pigz-native.do_compile attempted to execute unexpectedly ERROR: Task apt-native.do_compile attempted to execute unexpectedly ERROR: Task pbzip2-native.do_compile attempted to execute unexpectedly ERROR: Task ldconfig-native.do_install attempted to execute unexpectedly ERROR: Task apt-native.do_install attempted to execute unexpectedly ERROR: Task pigz-native.do_install attempted to execute unexpectedly ERROR: Task mklibs-native.do_install attempted to execute unexpectedly ERROR: Task makedevs-native.do_install attempted to execute unexpectedly ERROR: Task pbzip2-native.do_install attempted to execute unexpectedly ERROR: Task pbzip2-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task pigz-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task apt-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task ldconfig-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task mklibs-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task makedevs-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task parted-native.do_fetch attempted to execute unexpectedly ERROR: Task libtirpc-native.do_fetch attempted to execute unexpectedly ERROR: Task dosfstools-native.do_fetch attempted to execute unexpectedly ERROR: Task mtools-native.do_fetch attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_fetch attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_fetch attempted to execute unexpectedly ERROR: Task unfs3-native.do_fetch attempted to execute unexpectedly ERROR: Task parted-native.do_unpack attempted to execute unexpectedly ERROR: Task mtools-native.do_unpack attempted to execute unexpectedly ERROR: Task dosfstools-native.do_unpack attempted to execute unexpectedly ERROR: Task mtools-native.do_patch attempted to execute unexpectedly ERROR: Task dosfstools-native.do_patch attempted to execute unexpectedly ERROR: Task parted-native.do_patch attempted to execute unexpectedly ERROR: Task libtirpc-native.do_unpack attempted to execute unexpectedly ERROR: Task libtirpc-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task libtirpc-native.do_patch attempted to execute unexpectedly ERROR: Task libtirpc-native.do_configure attempted to execute unexpectedly ERROR: Task libtirpc-native.do_compile attempted to execute unexpectedly ERROR: Task libtirpc-native.do_install attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_unpack attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_unpack attempted to execute unexpectedly ERROR: Task libtirpc-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task unfs3-native.do_unpack attempted to execute unexpectedly ERROR: Task unfs3-native.do_patch attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_patch attempted to execute unexpectedly ERROR: Task unfs3-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_patch attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task mtools-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_configure attempted to execute unexpectedly ERROR: Task dosfstools-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task unfs3-native.do_configure attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_configure attempted to execute unexpectedly ERROR: Task parted-native.do_prepare_recipe_sysroot attempted to execute unexpectedly ERROR: Task mtools-native.do_configure attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_compile attempted to execute unexpectedly ERROR: Task unfs3-native.do_compile attempted to execute unexpectedly ERROR: Task parted-native.do_configure attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_compile attempted to execute unexpectedly ERROR: Task dosfstools-native.do_configure attempted to execute unexpectedly ERROR: Task parted-native.do_compile attempted to execute unexpectedly ERROR: Task dosfstools-native.do_compile attempted to execute unexpectedly ERROR: Task unfs3-native.do_install attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_install attempted to execute unexpectedly ERROR: Task mtools-native.do_compile attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_install attempted to execute unexpectedly ERROR: Task parted-native.do_install attempted to execute unexpectedly ERROR: Task qemu-helper-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dosfstools-native.do_install attempted to execute unexpectedly ERROR: Task gdb-cross-aarch64.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task mtools-native.do_install attempted to execute unexpectedly ERROR: Task unfs3-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task parted-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task dosfstools-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task mtools-native.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task cronie.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task nfs-utils.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task rpcbind.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task openssh.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: Task apt.do_populate_sysroot attempted to execute unexpectedly and should have been setscened ERROR: SDK preparation failed: error log written to /media/ubu/LocalDisk/imx-yocto/maaxboard/build/tmp/deploy/sdk/fsl-sdk/preparing_build_system.log
Cheers!
